SLVU2.8-4L
SLVU2.8-4L
    LEIDITECH(雷卯电子)
    SOP-8
    ESD保护 VRWM=2.8 V VBR(Min)=3.5 V VC=10 V IPP=10 A Ppp=100 W SOP8
SLVU2.8-4L 数据手册
SLVU2.8-4L Ultra Low Capacitance Bi-Directional TVS Diode Array Features ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 2.8V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 10A (8/20μs) RoHS Compliant Dimensions SOP-08 Pin Configuration Applications  Base Station  Analog Inputs  Switch Systems  10/100/1000 Ethernet  WAN/LAN Equipment  Desktops, Servers, and Notebooks  Low Voltage Interfaces Mechanical Characteristics ● Package: SOP-08 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3,000pcs ● Reel Size:7 inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp VESD Value Unit 100 W ± 30 Kv ± 30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2018 1/4 www.leiditech.com SLVU2.8-4L Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number Device Marking VRWM (V) VBR (V) IT (mA) VC @1A 2.8-4 2.8 3.5 1 5.5 SLVU2.8-4 Rev : 01.06.2018 2/4 (Max) 10 (@A) 10 IR μA (Max) 0.05 C (Pf) (Typ.) 4.5 www.leiditech.com SLVU2.8-4L Typical Performance Characteristics (TA=25°C unless otherwise Specified) Junction Capacitance vs. Reverse Voltage Peak Pulse Power vs. Pulse Time Power Derating Curve Note:Data is taken with a 10x attenuator ESD Clamping Voltage 8 kV Contact per IEC61000−4−2 8 X 20μs Pulse Waveform Rev : 01.06.2018 3/4 www.leiditech.com SLVU2.8-4L SOP-08 Mechanical Data Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2018 4/4 www.leiditech.com
SLVU2.8-4L 价格&库存
很抱歉,暂时无法提供与“SLVU2.8-4L”相匹配的价格&库存,您可以联系我们找货
