FP7208
Non-Synchronous PWM Boost Controller for LED Driver
General Description
The FP7208 is boost topology switching regulator for LED driver. It provides built-in gate driver
pin for driving external N-MOSFET. The non-inverting input of error amplifier connects to a 0.2V
reference voltage. It has programmable soft start time set by external capacitor, and over voltage
protection set by external resistor. The LED current can be adjusted by an external signal connecting
to the EN pin. EN pin accepts either a DC voltage or a PWM signal. The PWM signal filter components
are contained within the chip.
Features
Start-up Voltage: 2.5V
Wide Supply Voltage Operating Range: 4.5V to 24V
Precision Feedback Reference Voltage: 0.2V (Max.)
Analog and Digital Dimming Control
Shutdown Current: 6μA (Max.)
Internal Fixed Switching Frequency: 300KHz
Programmable Soft Start Function (SS)
Programmable Over Voltage Protection (OVP)
Over Temperature Protection (OTP)
Package: SOP-8L(EP)
Applications
LED Module
Display Backlight
Car Lighting
Portable LED Lighting
Typical Application Circuit
VLED
VIN
EXT
VDS
HVDD
EN
FP7208
COMP
FB
OVP
SS
VIN
GND
This datasheet contains new product information. Feeling Technology reserves the rights to modify the product specification without notice.
No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product.
Website: http://www.feeling-tech.com.tw
Rev. 0.64
1/13
FP7208
Function Block Diagram
COMP
GND
SS
HVDD
UVLO
Soft
Start
Error Amp.
LDO
FB
VDDI = 3.5V
Max.
LDO
VDS = 8.5V
VDS
0.2V
PWM
Comp.
DIM
EN
VRAMP
Shutdown
Circuit
Control
and
Driver
Logic
Oscillator
300KHz
OVP
EXT
Level = 0.7V
OVP
Pin Descriptions
SOP-8L (EP)
Top View
1
8
EXT
EN
2
7
HVDD
COMP
3
6
OVP
FB
4
5
SS
FP7208
XXx-XXL
VDS
Bottom View
EP
(GND)
Name
No.
I/O
VDS
1
P
EN
2
I
Description
Power Supply for Internal Control Circuits and
Gate Drivers
Enable and Dimming Control
COMP
3
O
Compensation
FB
4
I
Error Amplifier Inverting Input
SS
5
I
Soft Start Programming
OVP
6
I
HVDD
7
P
IC Power Supply
EXT
8
O
GND
9
P
Gate Driver Output
IC Ground (Exposed PAD) – Must Connect to
Ground
Rev. 0.64
2/13
FP7208
Marking Information
SOP-8L(EP)
FP7208
XXx - XXL
Halogen Free
Lot Number
Internal ID
Per - Half Month
Year
Halogen Free: Halogen free product indicator
Lot Number: Wafer lot number’s last two digits
For Example
Lot : 123456
XXx-56L
Internal ID: Internal Identification Code
Per-Half Month: Production period indicator in half month time unit
For Example : A → First Half Month of January
B → Second Half Month of January
C → First Half Month of February
D → Second Half Month of February
Year: Production year’s last digit
Rev. 0.64
3/13
FP7208
Ordering Information
Part Number
Operating Temperature
Package
MOQ
Description
-25°C ~ 85°C
SOP-8L(EP)
2500EA
Tape & Reel
FP7208XR-G1
Absolute Maximum Ratings
Symbol
Conditions
Min.
Typ.
Max.
Unit
HVDD
V
VDS,EXT Voltage
V
Others Pin Voltage
V
Parameter
Supply Voltage
Thermal Resistance (Junction to Ambient)
θJA
SOP-8L (EP)
+60
°C / W
Thermal Resistance (Junction to Case)
θJC
SOP-8L (EP)
+10
°C / W
Junction Temperature
TJ
+150
°C
TOP
-25
+85
°C
Storage Temperature
TST
-65
+150
°C
(soldering, 10 sec)
+260
°C
Lead Temperature
IR Re-flow Soldering Curve
Rev. 0.64
4/13
FP7208
Recommended Operating Conditions
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Unit
HVDD
4.5
24
V
TA
Ambient Temperature
-25
+85
°C
Supply Voltage
Operating Temperature Range
DC Electrical Characteristics (HVDD=12V, TA=25°C, unless otherwise specified)
Symbol
Conditions
Min.
Start-up Voltage
HVDD
2.5
Input Supply Range
HVDD
4.5
24
V
Under Voltage Lockout
VUVLO
2.2
V
Parameter
Typ.
Max.
Unit
System Supply Input
V
UVLO Hysteresis
0.1
V
Average Current
ICC
FB=0V, Switching
5
mA
Quiescent Current
ICC
FB=0.55V, No Switching
245
µA
Shutdown Current
ICC
VEN=GND
6
µA
Input Supply Voltage
VDS
HVDD=12V, IDS=0A
8.5
V
Operation Frequency
fOSC
FB=0V
250
300
350
KHZ
Maximum Duty Ratio
FB=0V
90
ISS
Vss=0V
1.5
µA
VFB
Connect EN to VDS with a
100kΩ, EN≒3V
0.191
0.200
0.209
V
Enable Voltage
VEN
0.20
0.25
0.30
V
Shutdown Voltage
VEN
0.07
V
Oscillator
Soft Start
Soft-Start bias Current
Reference Voltage
Feedback Voltage
Enable Control
External Transistor Connection current
EXT Pull-UP Resistance
REXTH
VDS=8.5V
1
Ω
EXT Pull-Down Resistance
REXTL
VDS=8.5V
1
Ω
OVP Threshold
Thermal Shutdown
Thermal Shutdown
Threshold
VOVP
0.65
0.70
0.75
V
TTS
+150
°C
Rev. 0.64
5/13
FP7208
Typical Operating Characteristics
(VIN=12V, TA=25℃, unless otherwise specified)
Rev. 0.64
6/13
FP7208
Rev. 0.64
7/13
FP7208
Function Description
Operation
The FP7208 is voltage mode boost controller for LED driver. It operates with pulse width
modulation (PWM), and changes to PSM mode when output is light load. The internal resistive divider
provides 0.2V reference for the error amplifier, which can reduce the power dissipation in the current
sense resistor.
Soft Start Function
Soft start time is programmable to connect capacitor between SS pin to ground. After the IC is
enabled, the output of error amplifier is clamped by the internal soft-start function, which causes PWM
pulse width increasing slowly and thus reducing input surge current during power on. The soft start
bias current is 1.5µA.
Enable Mode / Shutdown Mode
Drive the EN pin to ground to shutdown the IC. Shutdown mode forces to turn off all internal
circuitry, and reduces the HVDD supply current to 6uA (max). EN pin rising threshold is 0.25V.
DC Dimming Control
The DC voltage is connected to EN pin adjust the voltage to change feedback voltage (VFB). EN
internal voltage is clamped in 2.25V (VEN) when external voltage exceeds 2.25V. The valid EN voltage
is from 0.25V to 2.25V. The maximum feedback voltage is 0.2V. The LED current (ILED) can be
calculated using formula below.
VFB
V
VEN 0.25V
ILED FB
RS
10
PWM Dimming Control
The PWM signal is connected to EN pin adjust duty cycle to change feedback voltage (VFB). EN
internal voltage is clamped in 2.25V (VPWM) when external PWM voltage exceeds 2.25V, and internal
filter regulates PWM signal become a DC voltage. The DC voltage is valid from 0.25V to 2.25V. The
PWM signal is recommended above 10KHz. The LED current (ILED) can be calculated using formula
below.
VFB
V
VPWM Duty 0.25V
ILED FB
RS
10
Rev. 0.64
8/13
FP7208
FB Voltage Setting
How to set FB voltage when LEDs don’t need dimming control. The resistor 100KΩ is connected
between VDS and EN, which cause EN voltage more than 2.25V. The FB voltage is constant 0.2V.
The gate driver signal is turned off when OVP pin voltage exceeds 0.7V. The voltage (VOVP) can
be calculated using formula below, and circuit is shown as below.
VOVP
R3
0.7V 1
R4
LED+
R3
OVP
R4
Application Information
Inductor Selection
Inductance value is decided based on different condition. 4.7µH to 68uH inductance value is
recommended for general application circuit. There are three important inductor specifications, DC
resistance, saturation current and core loss. Low DC resistance has better power efficiency.
Capacitor Selection
The output capacitor is required to maintain the DC voltage during switching. Low ESR
capacitors are preferred to reduce the output voltage ripple. Ceramic capacitor of X5R and X7R are
recommended, which have low equivalent series resistance (ESR) and wider operation temperature
range.
Diode Selection
Schottky diodes with fast recovery times and low forward voltages are recommended. Ensure the
diode average and peak current rating exceed the average output current and peak inductor current. In
addition, the diode’s reverse breakdown voltage must exceed the output voltage.
LED Current Programming
The LED current is set by a resistor from the FB pin to ground. The LED current is:
ILED
VFB
RS
Rev. 0.64
9/13
FP7208
Input Current Limit Setting
The SS voltage is adjusted using a resistive voltage divider connected from input voltage to D3
cathode, D3 Anode connects to SS pin. The input occur inrush current to cause input voltage drop off
then SS voltage also drop less than 1.5V, PWM duty of EXT pin can be limited, which reduces inrush
current to protect switching MOSFET. The level of internal oscillator is from 0.5V to 1.5V. D3 is
unconnected the SS voltage is 3.6V. The circuit and detailed figure are shown as below.
Voltage
SS
3.6V
SS Voltage Drop
EXT Duty Limit
OSC
1.5V
VIN
D3
1N4148
SS
R8
OSC
0.5V
Time
Voltage
SS
EXT
R9
Time
Rev. 0.64
10/13
FP7208
Layout Considerations
1.
The power traces, consisting of the GND trace, the MOS drain trace and the VIN trace should
be kept short, direct and wide.
2.
Layout switching node MOS drain, inductor and schottky diode connection traces wide and short
to reduce EMI.
3.
Place C8 nearby HVDD pin as closely as possible to maintain input voltage steady and filter
noise.
4.
The sense resistor RS must be connected to FB pin directly and as closely as possible.
5.
FB is a sensitive node. Please keep it away from switching node, MOS drain.
6.
The GND of the Q2, C1, C2, C12 and C13 should be connected close and together directly to a
ground plane.
7.
The output capacitor C12 and C13 should be connected close and together directly to the ground
of Q2.
L1
D1
VIN
C1
C2
Q2
C3
Via to
Control
1
VDS
2
EN
EXT
8
HVDD
7
FP7208
C4
3
COMP
4
FB
C12
Via to VIN
C8
R3
OVP
6
SS
5
R4
C6
GND
R7
C13
Via to
VLED
Via to GND
Via to GND
Via to
SS
GND
D3
R9
RS
R8
Via to
VIN
VLED
Via to GND
Suggested Layout
Rev. 0.64
11/13
FP7208
Q2
AP83T03GMT
C2
22μF
EXT
VDS
R3
100K
R13
C3
1μF
C1
22μF
VLED 12V
Max. 2A
D1
SVM1545LB
L1
4.7μH
VIN 3V~4.2V
C12
100μF
C15
C13
10μF
R4
4.99K
C8
0.1μF
RS
0.1Ω
HVDD
EN
C4
0.1uF
FP7208
OVP
COMP
R8
36K
FB
SS
GND
R7
10K
R9
30K
Q2
AP83T03GMT
C3
1μF
C2
0.1μF
EXT
VDS
VLED 18V
Max. 2A
D1
SVM1045V2
L1
10μH
VIN 6V~8.4V
C1
100μF
VIN
D3
1N4148
C6
0.1μF
R3
130K
R13
C12
100μF
C15
C13
10μF
R4
4.3K
C8
0.1μF
RS
0.1Ω
HVDD
EN
C4
0.1uF
FP7208
OVP
COMP
R8
62K
FB
SS
GND
R7
10K
R9
20K
D1
SVM1045V2
L1
15μH
VIN 12V
Q2
AP0504GMT
C3
1μF
C1
100μF
C2
0.1μF
EXT
VDS
R6
100K
VLED 24V/2A
R3
120K
R13
C12
100μF
C15
C13
0.1μF
R4
3K
C8
0.1μF
RS
0.1Ω
HVDD
EN
C4
0.1uF
FP7208
COMP
OVP
R8
62K
FB
R7
10K
VIN
D3
1N4148
C6
0.1μF
SS
GND
C6
0.1μF
VIN
D3
1N4148
R9
8.2K
Note:
1.
2.
The X5R and X7R of ceramic capacitors are recommended to choose.
R13 and C15 are added for reducing EMI (Electromagnetic Interference).
Rev. 0.64
12/13
FP7208
Package Outline
SOP-8L (EP)
UNIT: mm
Symbols
Min. (mm)
Max. (mm)
A
1.30
1.70
A1
A2
1.25
1.55
D
4.70
5.10
E
3.80
4.00
H
5.80
6.20
L
0.40
1.27
Symbols
Min. (mm)
Max. (mm)
D1
2.60
3.45
E1
1.90
2.56
Exposed PAD Dimensions:
Note:
1.
Package dimensions are in compliance with JEDEC outline: MS-012 AA.
2.
Dimension ”D” does not include molding flash, protrusions or gate burrs.
3.
Dimension “E” does not include inter-lead flash or protrusions.
Rev. 0.64
13/13
很抱歉,暂时无法提供与“FP7208AXR-G1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.36800
- 10+2.20800
- 30+2.17600
- 100+2.08000
