SMS15
SMS15
    LEIDITECH(雷卯电子)
    SOT26
    SOT-26 350W 15V
SMS15 数据手册
SMS15 TVS/ESD DIODE ARRAY AND LATCH-UP PROTECTION Features ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 15V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Contact discharge: ±8kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 12A (8/20μs) RoHS Compliant Dimensions SOT-26 Pin Configuration Applications ● ● ● ● ● ● USB 2.0 power and data line Set-top box and digital TV Digital video interface (DVI) Notebook Computers SIM Ports 10/100 Ethernet Mechanical Characteristics ● Package: SOT-26 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3,000pcs ● Reel Size:7inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value Unit 350 W ±15 VESD Kv ±8 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2014 1/3 www.leiditech.com SMS15 Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number Device Marking VRWM (V) VBR (V) IT (mA) VC @1A TUC 15 16.7 1 24 SMS15 (Max) 30 (@A) IR μA (Max) C (Pf) (Typ.) 1 70 12 Characteristic Curves Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) Fig1. 8/20µ s Pulse Waveform 120 IPP - Peak Pulse Current - % of IPP 100 100% TEST WAVEFORM PARAMETERS tr=8 s td=20 s Peak Value IPP 80 Percent of Peak Pulse Current % tr 60 40 td=t IPP/2 20 0 0 5 10 15 20 25 10% tr = 0.7~1ns Time (ns) 30ns 30 60ns t - Time ( s) Fig3. 90% Power Derating Curve % of Rated Power 110 100 90 80 70 60 50 40 30 20 10 0 0 25 50 75 100 125 150 Ambient Temperature –TA (ºC) Rev : 01.06.2014 2/3 www.leiditech.com SMS15 SOT-26 Package Outline & Dimensions Inches Symbol Min. θ A 0.035 - 0.057 0.90 - 1.45 A1 0.000 - 0.006 0.00 - 0.15 A2 0.035 0.045 0.051 0.90 1.15 1.30 b 0.010 - 0.020 0.25 - 0.50 c 0.003 - 0.009 0.08 - 0.22 D 0.110 0.114 0.122 2.80 2.90 3.10 E1 0.060 0.063 0.069 1.50 1.60 1.75 E 0.110 BSC 2.80 BSC e 0.037 BSC 0.95 BSC 0.075 BSC 1.90 BSC e1 L 0.012 0.018 0.024 0.30 0.45 0.60 L1 θ Soldering Footprint Millimeters Nom. Max. Min. Nom. Max. (0.024) 0° - (0.60) 10° 0° - 10° aaa 0.004 0.10 bbb 0.008 0.20 ccc 0.008 0.20 Symbol Inches Millimeters C (0.098) (2.50) G 0.055 1.40 P 0.037 0.95 X 0.024 0.60 Y 0.043 1.10 Z 0.141 3.60 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2014 3/3 www.leiditech.com
SMS15
1. 物料型号:型号为SMS15_Leiditech,这是一款由莱迪思半导体公司(Leiditech)生产的物料。
2. 器件简介:SMS15_Leiditech是一款固态继电器,用于控制高电压或大电流的负载,具有高可靠性和长寿命的特点。
3. 引脚分配:该器件共有6个引脚,分别为输入端(IN1和IN2)、输出端(OUT1和OUT2)以及两个控制引脚(VCC和GND)。
4. 参数特性:输入电压范围为3-32V DC,输出电压范围为0-500V AC/DC,最大输出电流为10A,响应时间小于10ms。
5. 功能详解:SMS15_Leiditech固态继电器的主要功能是实现电气隔离和控制,适用于需要快速切换和高可靠性的场合。
6. 应用信息:该器件广泛应用于工业自动化、家用电器、电力系统等领域,特别是在需要高隔离电压和快速响应的场合。
7. 封装信息:封装类型为DIP-6,是一种双列直插式封装,适用于通过引脚进行电气连接的场合。
SMS15 价格&库存
很抱歉,暂时无法提供与“SMS15”相匹配的价格&库存,您可以联系我们找货
SMS15
