FP7209
Non-Synchronous PWM Boost Controller for LED Driver
General Description
The FP7209 is boost topology switching regulator for LED driver. It provides built-in gate driver
pin for driving external N-MOSFET. The non-inverting input of error amplifier connects to a 0.25V
reference voltage. It has programmable soft start time and switching frequency set by external
capacitor and resistor. There are four functions to protect system circuit, such as UVP, OVP, SCP and
OCP. The LED current can be adjusted by an external signal connecting to the DIM pin. DIM pin
accepts either a DC voltage or a PWM signal. The PWM signal filter components are contained within
the chip. Current mode control and external compensation network make is easy and flexible to
stabilize the system.
The FP7209 is available in the small footprint SOP-8L(EP) and TSSOP-14L(EP) packages to fit
in space-saving PCB layout for application fields.
Features
Start-up Voltage: 2.8V
Wide Supply Voltage Operating Range: 5V to 24V
Precision Feedback Reference Voltage: 0.25V (Max.)
Analog and Digital Dimming Control
Shutdown Current: 6μA (Max.) / TSSOP-14L(EP)
Programmable Switching Frequency: 100KHz~1000KHz
Programmable Soft Start Function (SS)
Input Under Voltage Protection (UVP)
Output Over Voltage Protection (OVP)
LED Short Circuit Protection (SCP)
Switching MOSFET Over Current Protection (OCP)
Over Temperature Protection (OTP)
Package: SOP-8L(EP), TSSOP-14L(EP)
Applications
LED Module
Display Backlight
Car Lighting
Portable LED Lighting
This datasheet contains new product information. Advanced Analog Technology reserves the rights to modify the product specification without
notice. No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product.
Rev. 0.60
1/23
FP7209
Typical Application Circuit
VLED
VIN
VDS
EXT
DIM
HVDD
FP7209
CS
COMP
FB
GND
OVP
VLED
VIN
VDS
EXT
DIM
GND
EN
GND
FP7209
COMP
HVDD
FB
CS
OVP
SC
RT
SS
notice.No liability is assumed as a result of the use of this product. No rights under any patent accompany the sales of the product.
Rev. 0.60
2/23
FP7209
Function Block Diagram
COMP
OVP
Error Amp.
LDO
OVP
OTP
VDDI
4.5V
Thermal
Regulation
Max.
0.25V
DIM
UVLO
0.7V
Soft
Start
FB
HVDD
Dimming
Control
VREF
VDS = 8V
LDO
Control
and
Driver
Logic
PWM
Comp.
EXT
OCP
0.1V
CS
Slope
Compensation
Oscillator
150KHz
VDS
GND
Current Sense
Amp.
COMP
0.4V
SS
Error Amp.
HVDD
UVLO
0.7V
Soft
Start
FB
LDO
OVP
OTP
Max.
0.25V
DIM
Dimming
Control
EN
Shutdown
Circuitry
RT
OVP
SCP
Oscillator
100KHz~1000KHz
VDDI
4.5V
Thermal
Regulation
VREF
VDS = 8V
LDO
Control
and
Driver
Logic
PWM
Comp.
VDS
EXT
OCP
Slope
Compensation
0.1V
CS
GND
Current Sense
Amp.
SCP
HICCUP
SC
Rev. 0.60
3/23
FP7209
Pin Descriptions
SOP-8L(EP)
Top View
1
8
EXT
DIM
2
7
HVDD
COMP
3
6
CS
FB
4
FP7209
XXx-XXL
VDS
OVP
5
Bottom View
EP
(GND)
Name
No.
I/O
DIM
2
I
Description
Power Supply for Internal Control Circuits
and Gate Drivers
VDS
1
P
COMP
3
O
Compensation
FB
4
I
Error Amplifier Inverting Input
OVP
5
I
CS
6
I
MOSFET Switch Current Sense
HVDD
7
P
IC Power Supply
EXT
8
O
GND
9(EP)
P
Gate Driver Output
IC Ground (Exposed PAD) – Must Connect to
Ground
Name
No.
I/O
VDS
1
P
DIM
2
I
Description
and Gate Drivers
TSSOP-14L(EP)
Top View
1
DIM
2
EN
3
COMP
4
FB
5
OVP
6
RT
7
FP7209
XXx- XXL
VDS
Bottom View
EP
14
EXT
13
GND
12
GND
EN
3
I
Enable Control
11
HVDD
COMP
4
O
Compensation
10
CS
FB
5
I
OVP
6
I
RT
7
I
Frequency Programming
9
SC
8
SS
SS
8
I
Soft Start Programming
SC
9
O
LED Short Circuit Control
CS
10
I
HVDD
11
P
IC Power Supply
GND
12
P
IC Ground
GND
13
P
IC Ground
EXT
14
O
Gate Driver Output
EP
15
Exposed PAD Connect to Ground
Rev. 0.60
4/23
FP7209
Marking Information
SOP-8L(EP)
FP7209
XXx-XXL
Halogen Free
Lot Number
Internal ID
Per - Half Month
Year
TSSOP-14L(EP)
FP7209
XXx-XXL
Halogen Free
Lot Number
Internal ID
Per -Half Month
Year
Halogen Free: Halogen free product indicator
Lot Number: Wafer lot number’s last two digits
For Example
Lot : 123456
XXx-56L
Internal ID: Internal Identification Code
Per-Half Month: Production period indicator in half month time unit
For Example : A → First Half Month of January
B → Second Half Month of January
C → First Half Month of February
D → Second Half Month of February
Year: Production year’s last digit
Rev. 0.60
5/23
FP7209
Ordering Information
Part Number
Operating Temperature
Package
MOQ
Description
FP7209XR-G1
-25°C ~ +85°C
SOP-8L(EP)
2500EA
Tape & Reel
FP7209mR-G1
-25°C ~ +85°C
TSSOP-14L(EP)
2500EA
Tape & Reel
Absolute Maximum Ratings
Symbol
Conditions
Min.
Typ.
Max.
Unit
HVDD
-0.3
26
V
VDS,SC,EXT Voltage
-0.3
16
V
Others Pin Voltage
-0.3
6
V
SOP-8L(EP)
+60
°C / W
TSSOP-14L(EP)
+55
°C / W
SOP-8L(EP)
+10
°C / W
TSSOP-14L(EP)
+9
°C / W
Parameter
Supply Voltage
Thermal Resistance (Junction to Ambient)
θJA
Thermal Resistance (Junction to Case)
θJC
Junction Temperature
TJ
+150
°C
TOP
-25
+85
°C
Storage Temperature
TST
-65
+150
°C
(soldering, 10 sec)
+260
°C
Lead Temperature
IR Re-flow Soldering Curve
Rev. 0.60
6/23
FP7209
Recommended Operating Conditions
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Unit
HVDD
5
24
V
TA
Ambient Temperature
-25
+85
°C
Supply Voltage
Operating Temperature Range
DC Electrical Characteristics (HVDD=12V, TA=25°C, unless otherwise specified)
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Unit
System Supply Input
Start-up Voltage
HVDD
2.8
Input Supply Range
HVDD
5
Under Voltage Lockout
VUVLO
V
24
2.6
UVLO Hysteresis
V
V
0.2
V
2
mA
800
µA
Average Current
ICC
FB=0V, Switching
Quiescent Current
ICC
FB=0.3V, No Switching
Shutdown Current
ICC
Shutdown Current
ICC
Input Supply Voltage
VDS
VEN=0V or VDIM=0V,Note1
VDIM=0V, HVDD=12V
SOP-8L(EP)
HVDD=12V, IDS=0A
7.5
8.0
8.5
V
RT=NC
120
150
180
KHZ
RT=51KΩ
320
370
420
KHZ
6
120
µA
µA
Oscillator
Operation Frequency
fOSC
Maximum Duty Ratio
FB=0V
90
ISS
Vss=0V
3.5
µA
0.275
V
Soft Start
Soft-Start bias Current
DIM Voltage
DIM Start-up Voltage
Vst_up
VEN>1.5V, Switching
DIM Shutdown Voltage
VDIM
VEN>1.5V, ICC
很抱歉,暂时无法提供与“FP7209XR-G13”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.56000
- 30+2.48000
- 100+2.32000
- 500+2.16000
- 1000+2.08000
