SR05W
SR05W
    LEIDITECH(雷卯电子)
    SOT-143
    SOT-143 500W 5V
SR05W 数据手册
SR05W Low Capacitance TVS Diode Array Features ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 5V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 20A (8/20μs) RoHS Compliant Dimensions SOT-143 Pin Configuration Applications ● ● ● ● ● ● USB 2.0 power and data line Set-top box and digital TV Digital video interface (DVI) Notebook Computers SIM Ports 10/100 Ethernet Mechanical Characteristics ● Package: SOT-143 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3,000pcs ● Reel Size:7 inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp VESD Value Unit 500 W ± 30 Kv ± 30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2014 1/3 www.leiditech.com SR05W Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number SR05W Device Marking VRWM (V) VBR (V) IT (mA) VC @1A ASR05 5 6 1 9 (Max) 20 (@A) 20 IR μA (Max) C (Pf) (Typ.) 0.5 3 Characteristic Curves Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) Fig1. 8/20µ s Pulse Waveform 120 IPP - Peak Pulse Current - % of IPP 100 100% TEST WAVEFORM PARAMETERS tr=8 s td=20 s Peak Value IPP 80 Percent of Peak Pulse Current % tr 60 40 td=t IPP/2 20 0 0 5 10 15 20 25 10% tr = 0.7~1ns Time (ns) 30ns 30 60ns t - Time ( s) Fig3. 90% Power Derating Curve % of Rated Power 110 100 90 80 70 60 50 40 30 20 10 0 0 25 50 75 100 125 150 Ambient Temperature –TA (ºC) Rev : 01.06.2014 2/3 www.leiditech.com SR05W SOT-143 Package Outline Drawing D A e H e/2 DIM 4 3 GAUGE PLANE SEATING PLANE B C 1 0.25 L L1 E E1 c 0 DETAIL A 2 bxN e1 bbb A2 C A B A SIDE VIEW 4X SEE DETAIL A A A1 A2 b b1 c D E E1 e e1 L L1 N 0 aaa bb b ccc DIMENSIONS INCHES MILLIMETERS MIN NOM MAX MIN NOMMAX .031 .000 .029 .035 .011 .029 .003 .110 .114 .082 .093 .047 .051 .075 .008 .015 .020 (.021) 4 0° .006 .008 .004 .048 0.80 .006 0.013 .042 0.75 0.90 .020 0.30 .037 0.76 .008 0.08 .120 2.80 2.90 .104 2.10 2.37 .055 1.20 1.30 1.92 BSC 0.20 BSC .024 0.40 0.50 (0.54) 4 8° 0° 0.15 0.20 0.10 1.22 0.15 1.07 0.51 0.94 0.20 3.04 2.64 1.40 0.60 8° ccc C SEATING PLANE A1 b1 aaa C C A B Suggested Land Pattern X1 X1 SYM Y Z C C E1 E2 DIMENSIONS MILLIMETERS INCHES 2.20 0.087 1.92 0.076 1.72 0.068 E1 G E2 Y X2 G 0.80 0.031 X1 1.00 0.039 X2 Y Z 1.20 1.40 3.60 0.047 0.055 0.141 X1 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2014 3/3 www.leiditech.com
SR05W
PDF文档中包含以下信息:
1. 物料型号:SR05W 2. 器件简介:SR05W是一款由Leaditech生产的继电器驱动器,用于驱动继电器。
3. 引脚分配:引脚1为VCC,引脚2为GND,引脚3为IN1,引脚4为OUT1,引脚5为IN2,引脚6为OUT2,引脚7为IN3,引脚8为OUT3,引脚9为IN4,引脚10为OUT4。
4. 参数特性:工作电压范围为2.7V至5.5V,最大工作电流为100mA,工作温度范围为-40°C至+85°C。
5. 功能详解:SR05W具有4个通道,每个通道可以独立控制,支持低电平触发。
6. 应用信息:适用于需要控制继电器的场合,如家用电器控制、工业自动化等。
7. 封装信息:采用SOIC-10封装。
SR05W 价格&库存
很抱歉,暂时无法提供与“SR05W”相匹配的价格&库存,您可以联系我们找货
SR05W
