ULC0544P10
ULTRA LOW CAPACITANCE TVS DIODE ARRAY
Features
Ultra low capacitance: 0.3pF typical (I/O to I/O)
Ultra low leakage: nA level
Low operating voltage: 5V
Low clamping voltage
Up to 4 lines protects
Leadless flow-through package
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±25kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
– IEC61000-4-5 (Lightning) 5A (8/20µs)
Dimensions DFN2510P10
Pin Configuration
NC
NC
GND
NC
NC
I/O_1
I/O_2
GND
I/O_3
I/O_4
RoHS Compliant
Applications
HDMI 1.3 & 1.4, USB 2.0 & 3.0 and MDDI ports
Monitors and flat panel displays
Set-top box and Digital TV
Video graphics cards
Digital Video Interface (DVI)
Notebook Computers
PCI Express and Serial SATA Ports
Marking Information
0524S = Device Marking Code
YYWW = Date Code
Dot denotes Pin1
0524S
YYWW
Mechanical Characteristics
Package: DFN2510-10 (2.5×1.0×0.5mm)
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Part Number
Terminal Connections: See Diagram Below
ULC0544P10 3000/Tape & Reel
Marking Information: See Below
Rev : 01.06.2014
Ordering Information
1/9
Packaging
Reel Size
7 inch
www.leiditech.com
ULC0544P10
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
100
W
Peak Pulse Current (8/20µs)
IPP
5
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
kV
±25
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
Reverse Working Voltage
Breakdown Voltage
Symbol
Min
Typ
VRWM
VBR
Max
Unit
5
V
Any I/O pin to ground
V
IT = 1mA, any I/O pin to ground
6
Test Condition
Reverse Leakage Current
IR
0.5
µA
VRWM = 5V, any I/O pin to ground
Clamping Voltage
VC
15
V
IPP = 1A (8 x 20µs pulse), any I/O
pin to ground
Clamping Voltage
VC
V
IPP = 5A (8 x 20µs pulse), any I/O
pin to ground
Junction Capacitance
CJ
0.4
pF
VR = 0V, f = 1MHz, between I/O
pins
CJ
0.8
pF
VR = 0V, f = 1MHz, any I/O pin to
ground
Rev : 01.06.2014
0.3
2/9
www.leiditech.com
ULC0544P10
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
10
Peak Pulse Power_Ppp (W)
Junction Capacitance_Cj (pF)
1
0.8
0.6
0.4
0.2
0.1
0.01
2
3
4
Reverse Voltage_VR (V)
5
0.1
10
100
1000
Pulse Duration_tp (us)
Peak Pulse Power vs. Pulse Time
Junction Capacitance vs. Reverse Voltage
16
120
14
100
12
% of Rated Power
Clamping Voltage_Vc (V)
1
10
8
6
4
80
60
40
2
3
4
5
Peak Pulse Current_Ipp (A)
6
Clamping Voltage vs. Peak Pulse Current
25
50
75
100 125
Ambient Temperature_Ta(℃)
150
Power Derating Curve
100
% of Peak Pulse Current
90
80
70
60
50
40
30
Time_t(uS)
60
80
ESD Clamping Voltage
8 X 20uS Pulse Waveform
Rev : 01.06.2014
8 kV Contact per IEC61000−4−2
3/9
www.leiditech.com
ULC0544P10
Typical Application
The ULC0544P10 is designed for easy PCB layout by allowing the traces to run straight through the device
. The PCB
traces could be used to connect the pin pairs for each line. For example, line 1 enters at pin 1 and exits at pin 10 and
the PCB trace connects Pin 1 and Pin 10 together. Ground is connected at Pin 3 and Pin 8.
1
10
2
9
3
8
4
7
5
6
ULC0544P10 on USB 3.0 Port Application
Vbus
Vbus
DD+
ID
GND
MicB_SSTX-
MicB_SSTX+
GND_DRAIN
MicB_SSRX-
MicB_SSRX+
Rev : 01.06.2014
4/9
www.leiditech.com
ULC0544P10
ULC0544P10 on DVI Port Application
Rev : 01.06.2014
5/9
www.leiditech.com
ULC0544P10
ULC0544P10 on HDMI Port Application
TMDS D2+
GND
TMDS D2TMDS D1+
GND
TMDS D1TMDS D0+
GND
TMDS D0HDMI Graphic Video
Controller
TMDS Clock+
GND
TMDS ClockCEC
NC
SCL
SDA
GND
5V Power
Hot Plug Detect
Rev : 01.06.2014
6/9
www.leiditech.com
ULC0544P10
ULC0544P10 on VGA Port Application
ULC0544P10 on eSATA Port Application
Rev : 01.06.2014
7/9
www.leiditech.com
ULC0544P10
ULC0544P10 on MDDI Port Application
ULC0544P10
ULC0544P10
ULC0511CDN
ULC0511CDN
ULC0511CDN
SD05
ULC0511CDN
SD05
ULC0544P10 on 10/100 Base Ethernet Port Application
Rev : 01.06.2014
8/9
www.leiditech.com
ULC0544P10
DFN2510-10 Package Outline Drawing
INCHES
NOM
MAX
E
SYM
DIMENSIONS
MILLIMETERS
MIN
NOM
MAX
MIN
TOP VIEW
L2
L1
L
SIDE VIEW
A
0.45
0.50
0.55
0.018
0.020
0.022
A1
0.00
0.02
0.05
0.000
0.001
0.002
b
0.15
0.20
0.25
0.006
0.008
0.010
b1
0.35
0.40
0.45
0.014
0.016
0.018
b2
0.20
0.25
0.30
0.008
0.010
0.012
c
0.10
0.15
0.20
0.004
0.006
0.008
D
2.45
2.50
2.55
0.098
0.100
0.102
e
0.50BSC
0.020BSC
Nd
2.00BSC
0.080BSC
E
0.95
1.00
1.05
0.038
0.040
0.042
L
0.35
0.40
0.45
0.014
0.016
0.018
L1
0.075REF
0.003REF
L2
0.050REF
0.002REF
h
0.08
0.12
0.15
0.003
0.005
0.006
R
0.05
0.10
0.15
0.002
0.004
0.006
BOTTOM VIEW
Suggested Land Pattern
SYM
DIMENSIONS
MILLIMETERS
INCHES
X1
0.200
0.008
X2
0.400
0.016
X3
0.500
0.020
Y
0.600
0.024
Z
1.400
0.056
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2014
9/9
www.leiditech.com
很抱歉,暂时无法提供与“ULC0544P10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.64055
- 50+0.51182
- 150+0.44745
- 500+0.39917
