ULC0514M
ULC0514M
    LEIDITECH(雷卯电子)
    MSOP10_3X3MM
    ESD保护 VRWM=5 V VBR(Min)=6 V VC=20 V IPP=5 A Ppp=100 W MSOP10_3X3MM
ULC0514M 数据手册
ULC0514M 4-Line Ultra Low Capacitance TVS Diode Array Features  Ultra low capacitance: 0.6pF typical  Ultra low leakage: nA level  Low operating voltage: 5V   Low clamping voltage Protects one power line and four data lines  Flow-through package  Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Contact discharge: ±8kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 5A (8/20μs) RoHS Compliant  Dimensions MSOP-10 Pin Configuration Applications  DVI Ports  HDMI Ports   Set Top Box Projection TV  Notebook Computers  10/100/1000 Ethernet  Monitors and Flat Panel Displays Mechanical Characteristics  Package: MSOP-10   Lead Finish: Matte Tin Case Material: “Green” Molding Compound.  UL Flammability Classification Rating 94V-0  Moisture Sensitivity: Level 3 per J-STD-020   Terminal Connections: See Diagram Below Marking Information: See Below Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value 100 Unit W ±15 VESD Kv ±8 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2017 1/4 www.leiditech.com ULC0514M Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number Device Marking VRWM (V) VBR (V) IT (mA) VC @1A 504M 5 6 1 12 ULC0514M Rev : 01.06.2017 2/4 (Max) 20 (@A) 5 IR μA (Max) C (Pf) (Typ.) 0.5 0.6 www.leiditech.com ULC0514M Typical Performance Characteristics (TA=25°C unless otherwise Specified) 10 Peak Pulse Power_Ppp (W) Junction Capacitance_Cj (pF) 1 0.8 0.6 0.4 0.2 1 0.1 0.01 0 0 1 2 3 4 Reverse Voltage_VR (V) 0.1 5 10 100 1000 Pulse Duration_tp (us) Peak Pulse Power vs. Pulse Time Junction Capacitance vs. Reverse Voltage 16 120 14 100 12 % of Rated Power Clamping Voltage_Vc (V) 1 10 8 6 4 80 60 40 20 2 0 0 0 1 2 3 4 5 Peak Pulse Current_Ipp (A) 6 0 Clamping Voltage vs. Peak Pulse Current 25 50 75 100 125 Ambient Temperature_Ta(℃) 150 Power Derating Curve 100 % of Peak Pulse Current 90 80 70 60 50 40 30 20 10 0 0 20 40 Time_t(uS) 60 80 ESD Clamping Voltage 8 X 20uS Pulse Waveform 8 kV Contact per IEC61000−4−2 Rev : 01.06.2017 3/4 www.leiditech.com ULC0504M MSOP-10 PACKAGE OUTLINE & DIMENSIONS * SOLDERING FOOTPRINT Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2017 4/4 www.leiditech.com
ULC0514M 价格&库存
很抱歉,暂时无法提供与“ULC0514M”相匹配的价格&库存,您可以联系我们找货
