ULC9L5V
1-Line Uni- directional TVS Diode
Features
Dimensions SOD-923
Ultra low capacitance: 0.6pF typical
Ultra low leakage: nA level
Operating voltage: 5V
Low clamping voltage
6
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±20kV
Contact discharge: ±20kV
– IEC61000-4-5 (Lightning) 4.5A (8/20μs)
Y
RoHS Compliant
Pin Configuration
Applications
Serial ATA
1
USB Ports
2
PIN 1. CATHODE
2. ANODE
MDDI Ports
Display Port
PCI Express
Digital Visual Interface (DVI)
Cellular Handsets and Accessories
Mechanical Characteristics
Package: SOD-923
Lead Finish: Matte Tin
Quantity Per Reel:8,000pcs
Reel Size:7 inch
Device Marking:D
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
Symbol
Value
Ppp
70
VESD
± 20
Unit
W
Kv
± 20
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
-55 to +125
Storage Temperature Range
TSTJ
-55 to +150
Rev 2.0 : 12.01.2019
1/4
www.leiditech.com
ULC9L5V
Electrical Characteristics(TA=25°C unless otherwise specified)
Parameter
Reverse Working Voltage
Breakdown Voltage
Symbol Test Condition
Min
Typ
Max
Unit
5
V
VRWM
VBR
6
IT = 1mA
V
Reverse Leakage Current
IR
VRWM = 5V
1
µA
Clamping Voltage
VC
IPP = 1A (8 x 20 μs pulse)
9
V
Clamping Voltage
VC
IPP = 4.5A (8 x 20 μs pulse)
15
V
Junction Capacitance
CJ
VR = 0V, f = 1MHz
0.9
pF
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
Figure 1. ESD Clamping Voltage Screenshot
Positive 8 kV Contact per IEC61000−4−2
Figure 2. ESD Clamping Voltage Screenshot
Negative 8 kV Contact per IEC61000−4−2
2/4
www.leiditech.com
ULC9L5V
Vc-Clamping Voltage(V)
CJ-Junction Capacitance (pF)
1
0.9
0.8
0.7
0.6
0.5
0.4
0.3
0.2
0.1
16
12
8
4
2
3
4
VR—Reverse Voltage(V)
2
3
4
5
Ipp-Peak Pulse Current(A)
Clamping Voltage vs. Peak Pulse Current
Junction Capacitance vs. Reverse Voltage
10
Voltage (V)
Peak Power_Ppp(kW)
100
1
0.1
0.01
0.1
1
10
-20
100
120
100
100
80
60
40
75
100
125
150
100
80
60
40
-20
Ambient Temperature_Ta(℃)
60
T-Time(us)
8 X 20us Pulse Waveform
Power Derating Curve
80
IEC61000−4−2 Pulse Waveform
Ipp-Peak Pulse Current-%of Ipp
% of Rated Power
Peak Pulse Power vs. Pulse Time
25
60
Time (nS)
Pulse Duration_tp(uS)
3/4
www.leiditech.com
ULC9L5V
DFN1006
PACKAGE
OUTLINE & DIMENSIONS
SOD-923
Mechanical
Data
Soldering Footprint
Dimensions: Millimeters
Millimeters
Dim
Inches
Min
Nom
Max
Min
Nom
Max
A
0.35
0.40
0.45
0.013
0.016
0.017
b
0.15
0.20
0.25
0.006
0.008
0.010
c
0.07
0.12
0.17
0.003
0.005
0.007
D
0.75
0.80
0.85
0.030
0.031
0.033
E
0.55
0.60
0.65
0.022
0.024
0.026
HE
0.95
1.00
1.05
0.037
0.039
0.041
L
0.05
0.10
0.15
0.002
0.004
0.006
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
4/4
www.leiditech.com
很抱歉,暂时无法提供与“ULC9L5V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.09688
- 100+0.08554
- 300+0.07987
- 1000+0.07560
- 5000+0.07220
- 8000+0.07053
