ULC7524T
ULC7524T
    LEIDITECH(雷卯电子)
    DFN5_1.3X0.8MM
    ESD保护 VRWM=5 V VBR(Min)=6 V VC=25 V IPP=2.6 A Ppp=65 W DFN5_1.3X0.8MM
ULC7524T 数据手册
ULC7524T ULTRA CAPACITANCE TVS DIODE ARRAY Features ● 65 Watts Peak Pulse Power per Line (tp=8/20μs) ● Protects Four I/O High Speed Lines ● Low Clamping Voltage ● RoHS Compliant ● IEC61000-4-2 (ESD) ±15kV (air), ±10kV (contact) ● IEC61000-4-4 (EFT) 40A (5/50ηs) ● IEC61000-4-5 (LIGHTING) 2.6A (8/20μs) Dimensions DFN1308P5 Pin Configuration Applications ● Microprocessor based equipment ● USD 3.0 High Speed Lines ● HDMI 2.0 Protection ● Notebooks, Desktops, and Servers ● MDDI Ports ● PCI Express Mechanical Characteristics ● DFN1308P5 Package ● Molding Compound Flammability Rating : UL 94V-O ● Weight 2.5 Millgrams (Approximate) ● Reel Size : 7 inch ● Lead Finish : Lead Free Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Value Ppp 65 VESD ± 15 Unit W Kv ± 10 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2018 1/5 www.leiditech.com ULC7524T Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number Device Marking VRWM (V) VBR (V) IT (mA) U41P 5 6 1 ULC7524T VC @1A 12.8 (Max) 25 (@A) 2.6 IR μA (Max) C (Pf) (Typ.) 0.1 0.25 Characteristic Curves Figure 1. 8 x 20μs Waveform Figure 2. Power Derating Curve Figure 3. Clamping Voltage vs. Peak Pulse Current (tp=8/20μs) Rev : 01.06.2018 2/5 www.leiditech.com ULC7524T TYPIC CHARACTERISTICS Figure 4. Typic Capacitance vs. Reverse Voltage Figure 5. TRANSMISSION LINE PULSE (TLP) Rev : 01.06.2018 3/5 www.leiditech.com ULC7524T Application Information Application Information HDMI 1.4 Type A Connector ULC7524T ULC7524T HDMI 1.4 Layout with ULC7524T ULC7524T VBus TMDSTMDS+ CBUS GND MHL Layout with ULC7524T Rev : 01.06.2018 4/5 www.leiditech.com ULC7524T DFN1308P5 PACKAGE OUTLINE & DIMENSIONS Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2018 5/5 www.leiditech.com
ULC7524T 价格&库存
很抱歉,暂时无法提供与“ULC7524T”相匹配的价格&库存,您可以联系我们找货
