ESD0521C
ESD0521C
    LEIDITECH(雷卯电子)
    DFN2
    ESD保护 VRWM=5 V VBR(Min)=6 V VC=12 V IPP=3.5 A Ppp=40 W DFN2_0.6X0.3MM
ESD0521C 数据手册
ESD0521C 1-Line Ultra Small Bi-directional TVS Diode Features  Ultra small package: 0.6x0.3x0.3mm  low capacitance  Protects one data or power line  Ultra low leakage: nA level  Operating voltage: 5V  Low clamping voltage  2-Pin leadless package  Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±25kV Contact discharge: ±22kV Dimensions DFN0603 0.6 0.3 - 0.3 – IEC61000-4-5 (Lightning) 3.5A (8/20μs)  RoHS Compliant Pin Configuration Applications  Cellular Handsets and Accessories  Personal Digital Assistants  Notebooks and Handhelds  Portable Instrumentation  Digital Cameras  Peripherals  Audio Players  Keypads, Side Keys, USB 2.0, LCD Displays Mechanical Characteristics  Package: DFN0603-2 (0.6x0.3x0.3mm)  Case Material: “Green” Molding Compound.  Moisture Sensitivity: Level 3 per J-STD-020  Terminal Connections: See Diagram Below  Marking Information: See Below Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Value Ppp 40 Unit W ±25 Kv VESD ±22 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2018 1/4 www.leiditech.com ESD0521C Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number ESD0521C Rev : 01.06.2018 Device Marking VRWM (V) VBR (V) IT (mA) VC @1A A 5 6 1 8 2/4 (Max) 12 (@A) 3.5 IR μA (Max) 0.2 C (Pf) (Typ.) 5 www.leiditech.com ESD0521C Typical Performance Characteristics (TA=25°C unless otherwise Specified) Junction Capacitance vs. Reverse Voltage Peak Pulse Power vs. Pulse Time Clamping Voltage vs. Peak Pulse Current Power Derating Curve 200 Voltage (V) 150 TA = 25OC Corrected for 20dB attenuator 1M Ohm 100 50 0 -50 -20 0 20 Time (ns) 40 60 80 ESD Clamping Voltage 8 X 20μs Pulse Waveform Rev : 01.06.2018 8 kV Contact per IEC61000−4−2 3/4 www.leiditech.com ESD0521C DFN0603 Package Outline Drawing DIMENSIONS e D h SYM h MIN NOM MAX A 0.230 0.330 A1 0.000 0.020 0.050 b 0.215 0.245 0.275 c 0.120 0.150 0.180 D 0.550 0.600 0.650 - b E - MILLIMETERS L A Bottom View A1 c e 0.355 BSC E 0.250 L 0.160 h 0.300 0.350 0.190 0.220 0.079 BSC Suggested Land Pattern SYM ╋ Y3 MILLIMETERS INCHES X 0.30 0.012 Y1 0.25 0.010 Y2 0.15 0.006 Y3 0.40 0.016 Z 0.65 0.026 Y1 Y2 Z ╋ DIMENSIONS X Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2018 4/4 www.leiditech.com
ESD0521C
物料型号为ESD0521C,是Leiditech公司生产的1线超小型双向TVS二极管。
以下是该器件的详细信息:
器件简介: - 超小型封装:0.6x0.3x0.3mm - 低电容 - 保护一条数据线或电源线 - 超低漏电:nA级别 - 工作电压:5V - 低钳位电压 - 2引脚无引线封装
引脚分配: - 封装类型:DFN0603-2 - 引脚连接图示在文档中提供
参数特性: - 符合以下标准: - IEC 61000-4-2(ESD)免疫测试:空气放电±25kV,接触放电±22kV - IEC61000-4-5(雷击)3.5A(8/20μs) - 符合RoHS标准
功能详解: - 电气特性包括: - 工作电压:5V - 反向工作电压:6V - 漏电流:1mA - 1A时的钳位电压:8V - 最大钳位电压:12V - 最大脉冲峰值功率:40W(8/20μs)
应用信息: - 适用于手机和配件、个人数字助理、笔记本电脑和手持设备、便携式仪器、数码相机、外围设备、音频播放器、键盘、侧键、USB 2.0、LCD显示屏等。
封装信息: - 封装尺寸:DFN0603 - 封装材料:“绿色”模塑料 - 湿度敏感性等级:按照J-STD-020标准为3级
文档还提供了机械特性、电气特性和典型性能特性的详细数据。
更多详细信息可以参考Leiditech官方网站或联系公司获取。
ESD0521C 价格&库存
很抱歉,暂时无法提供与“ESD0521C”相匹配的价格&库存,您可以联系我们找货
