SD057 1P6W
1-Line Uni-directional TVS Diode
Features
Ultra low leakage: nA level
Operating voltage: 5V
Low clamping voltage
2-pin leadless package
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 80A (5/50ns)
– IEC61000-4-5 (Lightning)80A (8/20 μs)
RoHS Compliant
Dimensions DFN1610-2
Pin Configuration
Applications
Mobile Phones and Accessories
Battery Protection
USB VBus
Power Line Protection
Hand Held Portable Applications
Mechanical Characteristics
Package: DFN1610-2
Lead Finish: NiPdAu
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Quantity Per Reel:3,000pcs
Reel Size:7 inch
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
Symbol
Ppp
VESD
Value
1280
±30
Unit
W
Kv
±30
Operating Temperature Range
TJ
-55 to +125
Storage Temperature Range
TSTJ
-55 to +150
Rev : 01.06.2014
1/3
www.leiditech.com
SD057 1P6W
Electrical Characteristics(TA=25°C unless otherwise specified)
Vc
Part Number
Device
Marking
VRWM
(V)
VBR
(V)
IT
(mA)
VC
@10A
91
5
6
1
9
SD0571P6W
(Max)
(@A)
16
80
IR
μA
(Max)
C
(Pf)
(Typ.)
1
650
Characteristic Curves
100
70
Clamping Voltage_VR (V)
Peak Pulse Power - PPP (kW)
TA = 25 OC
10
1
60
50
40
30
0.1
1
10
100
40
60
80
100
Peak Pulse Current_Ipp (A)
Pulse Duration - tp (µs)
Clamping Voltage vs. Peak Pulse Current
Junction Capacitance vs. Reverse Voltage
120
100
90
100
80
% of Rated Power
% of Peak Pulse Current
60
50
40
30
60
40
Time_t(uS)
60
80
25
50
75
100 125
Ambient Temperature_Ta(℃)
150
Power Derating Curve
8 X 20uS Pulse Waveform
Rev : 01.06.2014
www.leiditech.com
SD057 1P6W
DFN1610-2 Package Outline Drawing
e
D
h
h
SYM
b
E
A
L
A
Bottom View
DIMENSIONS
MILLIMETERS
INCHES
MIN
NOM
MAX
MIN
NOM
MAX
0.45
0.50
0.55
0.018
0.020
0.022
A1
0.00
0.02
0.05
0.000
0.001
0.002
b
0.75
0.80
0.85
0.030
0.032
0.034
c
0.10
0.15
0.20
0.004
0.006
0.008
D
1.55
1.60
1.65
0.062
0.064
0.066
A1
c
e
1.10 BSC
0.044 BSC
E
0.95
1.00
1.05
0.038
0.040
0.042
L
0.35
0.40
0.45
0.014
0.016
0.018
h
0.15
0.20
0.25
0.006
0.008
0.010
Suggested Land Pattern
SYM
Y3
Y2
MILLIMETERS
INCHES
X
1.00
0.040
Y1
0.62
0.025
Y2
0.60
0.024
Y3
1.22
0.049
Z
1.85
0.074
Y1
Z
DIMENSIONS
X
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2014
3/3
www.leiditech.com
很抱歉,暂时无法提供与“SD0571P6W”相匹配的价格&库存,您可以联系我们找货
