ULC3304P10
ULC3304P10
    LEIDITECH(雷卯电子)
    DFN2510-10
    ESD抑制器/TVS二极管 VRWM=3.3V VBR(Min)=4.5V VC=12V IPP=5A DFN10_2.5X1MM
ULC3304P10 数据手册
ULC3304P10 Ultra Low Capacitance TVS Diode Array Features ● ● ● ● ● ● ● Ultra low capacitance: 0.4pF typical (I/O to I/O) Ultra low leakage: nA level Low operating voltage: 3.3V Low clamping voltage with snap back technology Up to 4 lines protects Leadless flow -through package Complies with following standards: Dimensions DFN2510P10 – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30 kV ● – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 5A (8/20µs) RoHS Compliant Pin Configuration Applications ● HDMI 1.3 & 1.4, USB 2.0 & 3.0 and MDDI ports ● Monitors and flat panel displays ● Set - top box and Digital TV ● Video graphics cards ● Digital Video Interface (DVI) ● Notebook Computers ● PCI Express and Serial SATA Ports Mechanical Characteristics ● Package: DFN2510P10 ● Lead Finish: Matte Tin ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3000pcs ● Reel Size:7inch ● Device Marking:3324 Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value 60 Unit W ±30 VESD Kv ±30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.07.2021 1/9 www.leiditech.com ULC3304P10 Electrical Characteristics(TA=25°C unless otherwise specified) Parameter Symbol Reverse Working Voltage Breakdown Voltage Min Typ VRWM VBR Max Unit 3.3 V Any I/O pin to ground V IT = 1mA, any I/O pin to ground 4.5 Test Condition Reverse Leakage Current IR 0.5 µA VRWM = 3.3V,any I/O pin to ground Clamping Voltage VC 3.5 V IPP = 1A (8 x 20µs pulse), any I/O pin to ground Clamping Voltage VC 12 V IPP = 5A (8 x 20µs pulse), any I/O pin to ground Junction Capacitance CJ 0.4 pF VR = 0V, f = 1MHz, between I/O pins Junction Capacitance CJ 0.6 pF VR = 0V, f = 1MHz, any I/O pin to ground Characteristic Curves 10 Peak Pulse Power_Ppp (W) Junction Capacitance_Cj (pF) 1 0.8 0.6 0.4 0.2 0 1 0.1 0.01 0 1 2 3 4 Reverse Voltage_VR (V) 0.1 5 120 8.00 100 % of Rated Power Clamping Voltage_Vc (V) 10.00 4.00 2.00 10 100 1000 Pulse Duration_tp (us) Peak Pulse Power vs. Pulse Time Junction Capacitance vs. Reverse Voltage 6.00 1 80 60 40 20 0.00 0 1 2 3 4 5 Peak Pulse Current_Ipp (A) Rev : 01.07.2021 01.06.2014 0 6 0 2/9 2/3 25 50 75 100 125 ℃ 150 www.leiditech.com ULC3304P10 Clamping Voltage vs. Peak Pulse Current Power Derating Curve 100 % of Peak Pulse Current 90 80 70 60 50 40 30 20 10 0 0 20 40 Time_t(uS) 60 80 ESD Clamping Voltage 8 X 20uS Pulse Waveform 8 kV Contact per IEC61000−4−2 Typical Application The ULC3304P10 is designed for easy PCB layout by owing all the traces to run straight through the device. The PCB traces could be used to connect the pin pairs for each line. For example, line 1 enters at pin 1 and exits at pin 10 and the PCB trace connects Pin 1 and Pin 10 together. Ground is connected at Pin 3 and Pin 8. 10 1 9 2 8 3 7 4 6 5 Rev : 01.07.2021 3/9 www.leiditech.com ULC3304P10 ULC3304P10 on USB 3.0 Port Application Vbus Vbus DD+ ID GND MicB_SSTX- MicB_SSTX+ GND_DRAIN MicB_SSRX- MicB_SSRX+ Rev : 01.07.2021 4/9 www.leiditech.com ULC3304P10 ULC3304P10 on DVI Port Application Rev : 01.07.2021 5/9 www.leiditech.com ULC3304P10 ULC3304P10 on HDMI Port Application TMDS D2+ GND TMDS D2TMDS D1+ GND TMDS D1TMDS D0+ GND TMDS D0HDMI Graphic Video Controller TMDS Clock+ GND TMDS ClockCEC NC SCL SDA GND 5V Power Hot Plug Detect Rev : 01.07.2021 6/9 www.leiditech.com ULC3304P10 ULC3304P10 on MDDI Port Application ULC3304P10 ULC3304P10 ULC0511CDN ULC0511CDN ULC0511CDN ULC0511CDN ULC3304P10 on 10/100 Base Ethernet Port Application Rev : 01.07.2021 7/9 www.leiditech.com ULC3304P10 ULC3304P10 on VGA Port Application ULC3304P10 on eSATA Port Application Rev : 01.07.2021 8/9 www.leiditech.com ULC3304P10 DFN2510P10 PACKAGE OUTLINE & DIMENSIONS * SOLDERING FOOTPRINT Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.07.2021 9/9 www.leiditech.com
ULC3304P10 价格&库存
很抱歉,暂时无法提供与“ULC3304P10”相匹配的价格&库存,您可以联系我们找货
