ULC0542T
ULC0542T
    LEIDITECH(雷卯电子)
    DFN6_1.6X1MM
    ESD保护 VRWM=5 V VBR(Min)=6 V VC=25 V IPP=4.5 A Ppp=110 W DFN6_1.6X1MM
ULC0542T 数据手册
ULC0542T 2-Line Ultra Low Capacitance TVS Diode Array Features ● ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 5V Ultra low capacitance:0.3pF typical Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±25kV Contact discharge: ±20kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 5A (8/20μs) RoHS Compliant Dimensions DFN1610-6 Pin Configuration Applications ● ● ● ● ● ● USB 3.0 line HDMI1.4 Set-top box and digital TV 10/100/1000 Ethernet Notebook Computers SATA Ports MDDI Ports Pin 1 Mechanical Characteristics ● Package: DFN1610-6 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3,000pcs ● Reel Size:7inch NC I/O 1 Pin 2 NC 3, 4 Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) ESD per IEC 61000−4−2 (Contact) Symbol Value Ppp 75 VESD ±25 Unit W Kv ±20 Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2017 1/4 www.leiditech.com ULC0542T Electrical Characteristics (TA=25°C unless otherwise specified) Vc Part Number Device Marking ULC0542T Rev : 01.06.2017 0522P VRWM (V) VBR (V) IT (mA) VC @1A 5 6 1 10 2/4 (Max) 15 (@A) 5 IR μA (Max) C (Pf) (Typ.) 0.5 0.3 www.leiditech.com ULC0542T Typical Performance Characteristics (TA=25°C unless otherwise Specified) Junction Capacitance vs. Reverse Voltage Peak Pulse Power vs. Pulse Time Clamping Voltage vs. Peak Pulse Current Power Derating Curve Note:Data is taken with a 10x attenuator ESD Clamping Voltage 8 X 20μs Pulse Waveform 8 kV Contact per IEC61000−4−2 Rev : 01.06.2017 3/4 www.leiditech.com ULC0542T DFN1610-6 Package Outline Drawing 1.55 1.60 1.65 Suggested Land Pattern P1 P DIM C G P P1 X Y Z Y Z (C) G X DIMENSIONS INCHES MILLIMETERS (.034) (0.87) .007 0.19 .020 0.50 .039 1.00 0.20 .008 .027 0.68 .061 1.55 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2017 4/4 www.leiditech.com
