LC08CI
1-Line Low Capacitance Bi-directional TVS Diode
Features
450W peak pulse power (8/20μs)
Ultra low capacitance: 1pF typical
Dimensions SOD-323
Ultra low leakage: nA level
Low operating voltage: 5V
Low clamping voltage
Protects one power line or data line
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±15kV
Contact discharge: ±8kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
– IEC61000-4-5 (Lightning) 15A (8/20μs)
RoHS Compliant
Pin Configuration
Applications
USB Ports
Smart Phones
Wireless Systems
Ethernet 10/100/1000 Base T
Mechanical Characteristics
Package: SOD-323
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
Marking Information: See Below
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
Symbol
Ppp
VESD
Value
Unit
300
W
± 15
Kv
±8
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
-55 to +125
Storage Temperature Range
TSTJ
-55 to +150
Rev : 01.06.2017
1/3
www.leiditech.com
LC08CI
Electrical Characteristics(TA=25°C unless otherwise specified)
Vc
Part Number
Device
Marking
VRWM
(V)
BC
8.0
LC08CI
Rev : 01.06.2017
VBR
(V)
8.5
IT
(mA)
VC
@1A
1
13.4
2/3
(Max)
25
(@A)
IR
μA
(Max)
C
(Pf)
(Typ.)
15
1
1
www.leiditech.com
LC08CI
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
Rev : 01.06.2017
3/4
www.leiditech.com
LC08CI
SOD-323 Package Outline & Dimensions
Millimeters
Inches
Symbol
Min.
Nom.
Max.
Min.
Nom.
Max.
A
0.80
0.90
1.00
0.031
0.035
0.040
A1
0.00
0.05
0.10
0.000
0.002
0.004
A3
Soldering Footprint
0.15 REF
0.006 REF
b
0.25
0.32
0.40
0.010
0.012
0.016
C
0.089
0.12
0.177
0.003
0.005
0.007
D
1.60
1.70
1.80
0.062
0.066
0.070
E
1.15
1.25
1.35
0.045
0.049
0.053
L
0.08
HE
2.30
0.098
0.105
0.003
2.50
2.70
0.090
Symbol
Millimeters
Inches
F
1.60
0.063
G
2.85
0.112
J
0.83
0.033
K
0.63
0.025
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2017
4/4
www.leiditech.com
很抱歉,暂时无法提供与“LC08CI”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.72734
- 50+0.58545
- 150+0.51445
- 500+0.46114
- 3000+0.40582
- 6000+0.38454
