ULC0602N
ULC0602N
    LEIDITECH(雷卯电子)
    DFN10_2.6X2.6MM_EP
    ESD保护 VRWM=6 V VBR(Min)=6.8 V VC=25 V IPP=100 A Ppp=2 KW DFN10_2.6X2.6MM_EP
ULC0602N 数据手册
ULC0602N Urtra Low Capacitance TVS Diode Array Features ● ● ● ● Ultra low leakage: nA level Operating voltage: 5V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 80A (8/20μs) RoHS Compliant Dimensions DFN1616-6 1 2 GND 3 4 5 10 9 8 7 6 Pin Configuration Applications ● ● ● ● ● T3/E3 10/100/1000M Carrier Class Equipment ISDN interfaces Integrated Magnetic LINE 1 (1, 2, 3) Center Tab LINE 2 Mechanical Characteristics ● Package: DFN2626-10 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3,000pcs ● Reel Size:7 inch (8, 9, 10) Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (2/20µs) ESD per IEC 61000−4−2 (Air) ESD per IEC 61000−4−2 (Contact) Symbol Ppp VESD Value 2000 ±30 Unit W Kv ±30 Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2014 1/4 www.leiditech.com ULC0602N Electrical Characteristics(TA=25°C unless otherwise specified) Part Number Device Marking ULC0602N VRWM (V) 0602 VBR (V) 6.0 IT (mA) 6.8 VC @100A 2/20µs note1 1 20 Vc (Max) note2 25 (@A) IR μA (Max) C (Pf) (Typ.) 5 10 2/20µs 100 Note1: Vc between I/O line Note2: Vc between I/O line and ground Characteristic Curves Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) Fig1. 8/20µ s Pulse Waveform tr 100 100% TEST WAVEFORM PARAMETERS tr=8 s td=20 s Peak Value IPP 80 Percent of Peak Pulse Current % IPP - Peak Pulse Current - % of IPP 120 60 40 td=t IPP/2 20 0 0 5 10 15 20 25 10% tr = 0.7~1ns Time (ns) 30ns 30 60ns t - Time ( s) Fig3. 90% Power Derating Curve % of Rated Power 110 100 90 80 70 60 50 40 30 20 10 0 0 25 50 75 100 125 150 Ambient Temperature –TA (ºC) Rev : 01.06.2014 2/4 www.leiditech.com ULC0602N Applications Information These devices are designed to protect two high-speed data lines (one differential pair) from transient overvoltages which result from lightning and ESD. They can be configured to protect in differential (Line-to-Line) and common (Line-to-Ground) mode. Data line inputs/outputs are connected at pins 1, 2 and 3, and 8, 9 and 10 as shown. For proper operation, pins 1 - 3 must be connected together and pins 8 - 10 must be connected together. Pins 4, 5, 6, and 7 left unconnected. For differential operation, the center tab is also left not connected. For common mode op eration, the center tab is connected to ground. The ground connection should be made directly to a ground plane on the board for best results. The use of multiple vias is recommnded for reduced ground loop inductance. LINE 1 1 2 (1, 2, 3) Center Tab 3 4 5 LINE 2 GND 10 9 8 7 6 (8, 9, 10) Circuit Diagram Rev : 01.06.2014 Pin Configuration Pin Identification 1, 2, 3 Line 1 in/out 8, 9, 10 Line 2 in/out 4, 5, 6, 7 No Connect Center Tab Ground 3/4 www.leiditech.com ULC0602N DFN2626-10 Package Outline Drawing A D B DIM PIN 1 INDICATOR E A SEATING PLANE aaa C A2 D1 C A1 1 2 E/2 A A1 A2 b D D1 E E1 e L N aaa bbb DIMENSIONS MILLIMETERS INCHES MIN NOM MAX MIN NOM MAX .020 .022 .024 0.50 0.55 0.60 .000 .001 .002 0.00 0.03 0.05 (0.17) (.007) .007 .010 .012 0.20 0.25 0.30 .098 .102 .106 2.50 2.60 2.70 .079 .085 .089 2.00 2.15 2.25 .098 .102 .106 2.50 2.60 2.70 .044 .050 .054 1.11 1.26 1.36 .020 BSC 0.50 BSC .011 .014 .016 0.30 0.35 0.40 10 10 0.08 .003 0.10 .004 E1 LxN N e bxN bbb D/2 NOTES: 1. C A B CONTROLLING DIMENSIONS ARE IN MILLIMETERS (ANGLES IN DEGREES). COPLANARITY APPLIES TO THE EXPOSED PAD AS WELL AS THE TERMINALS. 2. Suggested Land Pattern X P Z F G (C) DIM B C F G P X Y Z DIMENSIONS INCHES MILLIMETERS .081 2.05 .100 2.50 .050 1.26 .073 1.85 .020 0.50 .012 0.30 .025 0.65 .124 3.15 Y B NOTES: 1. THIS LAND PATTERN IS FOR REFERENCE PURPOSES ONLY. CONSULT YOUR MANUFACTURING GROUP TO ENSURE YOUR COMPANY'S MANUFACTURING GUIDELINES ARE MET. Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2014 4/4 www.leiditech.com
ULC0602N 价格&库存
很抱歉,暂时无法提供与“ULC0602N”相匹配的价格&库存,您可以联系我们找货
