LC3304P8
4-Line Ultra Low Capacitance TVS Diode Array
Features
Ultra low leakage: nA level
Operating voltage: 3.3V
Low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
– IEC61000-4-5 (Lightning) 25A (8/20
μs)
RoHS Compliant
Dimensions DFN2626-10
Pin Configuration
Applications
USB 2.0 power and data line
Set-top box and digital TV
Digital video interface (DVI)
Notebook Computers
SIM Ports
10/100/1000 Ethernet
Mechanical Characteristics
Package: DFN2626-10
Lead Finish: Lead Free
UL Flammability Classification Rating 94V-0
Quantity Per Reel:3,000pcs
Reel Size:7inch
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
Symbol
Ppp
Value
Unit
450
W
±30
VESD
Kv
±30
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
-55 to +125
Storage Temperature Range
TSTJ
-55 to +150
Rev : 01.06.2018
1/3
www.leiditech.com
LC3304P8
Electrical Characteristics(TA=25°C unless otherwise specified)
Vc
Part Number
Device
Marking
VRWM
(V)
VBR
(V)
IT
(mA)
VC
@1A
3304N
3.3
3.8
1
5.5
LC3304P8
(Max)
18
(@A)
IR
μA
(Max)
C
(Pf)
(Typ.)
0.5
3.8
25
Characteristic Curves
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
80
Percent of Peak Pulse Current %
tr
60
40
td=t IPP/2
10
15
10%
tr = 0.7~1ns
Time (ns)
30ns
30
60ns
t - Time ( s)
Fig3.
90%
Power Derating Curve
% of Rated Power
110
100
90
80
70
60
50
40
30
50
75
100
125
150
Ambient Temperature –TA (ºC)
Rev : 01.06.2018
2/3
www.leiditech.com
LC3304P8
DFN2626-10 Package Outline Drawing
A
B
D
DIM
PIN 1
INDICATOR
E
A
SEATING
PLANE
aaa C
A2
D1
C
A1
A
A1
A2
b
D
D1
E
E1
e
L
N
aaa
bbb
DIMENSIONS
INCHES
MILLIMETERS
MIN NOM MAX MIN NOM MAX
.020 .022 .024 0.50 0.55 0.60
.000 .001 .002 0.00 0.03 0.05
(.007)
(0.17)
.007 .010 .012 0.20 0.25 0.30
.098 .102 .106 2.50 2.60 2.70
.079 .085 .089 2.00 2.15 2.25
.044 .050 .054 1.11 1.26 1.36
.020 BSC
0.50 BSC
.011 .014 .016 0.30 0.35 0.40
10
10
.003
0.08
.004
0.10
1 2
E/2
E1
e
LxN
N
bxN
bbb
D/2
NOTES:
1.
2.
C A B
CONTROLLING DIMENSIONS ARE IN MILLIMETERS (ANGLES IN DEGREES).
COPLANARITY APPLIES TO THE EXPOSED PAD AS WELL AS THE TERMINALS.
Suggested Land Pattern
X
P
Z
F
G
(C)
DIM
B
C
F
G
P
X
Y
Z
DIMENSIONS
INCHES
MILLIMETERS
.081
2.05
.100
2.50
1.26
.050
.073
1.85
.020
0.50
.012
0.30
.025
0.65
.124
3.15
Y
B
NOTES:
1. THIS LAND PATTERN IS FOR REFERENCE PURPOSES ONLY.
CONSULT YOUR MANUFACTURING GROUP TO ENSURE YOUR
COMPANY'S MANUFACTURING GUIDELINES ARE MET.
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2018
3/3
www.leiditech.com
很抱歉,暂时无法提供与“LC3304P8”相匹配的价格&库存,您可以联系我们找货
