SRV0504
4-line uitra low capacitance tvs array
Features
Ultra low capacitance: 0.3pF typical (I/O to I/O)
Ultra low leakage: nA level
Operating voltage: 5V
Low clamping voltage
Up to four data lines and one power line protects
JEDEC SOT-23 6L package
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±25kV
Contact discharge: ±20kV
– IEC61000-4-5 (Lightning) 5A (8/20μs)
RoHS Compliant
Dimensions SOT-23-6L
Pin Configuration
Applications
USB 2.0 Power and Data lines protection
Digital Visual Interface (DVI)
Monitors and Flat Panel Displays
Video Graphic Cards
Notebook and PC Computers
Mechanical Characteristics
Package: SOT-23 6L
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
Marking Information: See Below
Quantity Per Reel:3,000pcs
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
Symbol
Value
Ppp
75
Unit
W
±25
VESD
Kv
±20
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
-55 to +125
Storage Temperature Range
TSTJ
-55 to +150
Rev:May 8th 2018
1/6
www.leiditech.com
SRV0504
Electrical Characteristics(TA=25°C unless otherwise specified)
Vc
Part Number
SRV0504
Device
Marking
VRWM
(V)
VBR
(V)
IT
(mA)
0504A
5
6
1
Rev:May 8th 2018
VC
@1A
10
2/6
(Max)
15
(@A)
5
IR
μA
(Max)
C
(Pf)
(Typ.)
0.5
0.8
www.leiditech.com
SRV0504
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
Junction Capacitance vs. Reverse Voltage
Peak Pulse Power vs. Pulse Time
Clamping Voltage vs. Peak Pulse Current
Power Derating Curve
Note:Data is taken with a 10x attenuator
ESD Clamping Voltage
8 X 20μs Pulse Waveform
Rev:May 8th 2018
8 kV Contact per IEC61000−4−2
3/6
www.leiditech.com
SRV0504
Typical Application
The SRV0504 is designed to protect four data lines from transient over -voltages by clamping them to fixed reference. When the voltage on the protected line exceeds the reference voltage (plus diode VF) the steering diodes are
forward biased, conducting the transient current away from the sensitive circuitry. Data lines are connected at pins 1,
3, 4 and 6. The negative reference (REF1) is connected at pin 2. This pin should be connected directly to a ground
plane on the board for best results. The path length is kept as short as possible to minimize parasitic inductance.
The positive reference (REF2) is connected at pin 5.
I/O 1
To Protected IC
I/O 2
6
1
2
5
3
4
VCC
I/O 3
I/O 4
To Protected IC
SRV0504 on USB 3.0 Port Application
1
VBus
D
D+
ID
6
1
GND
VCC
2
5
3
4
SSTx
SSTx+
GND - Drain
SSRx
10
Rev:May 8th 2018
SSRx+
4/6
www.leiditech.com
SRV0504
SRV0504 on HDMI Port Application
TMDS D2+
GND
TMDS D2TMDS D1+
GND
TMDS D1TMDS D0+
GND
TMDS D0HDMI Graphic Video
Controller
TMDS Clock+
GND
TMDS ClockCEC
NC
SCL
SDA
6
1
GND
2
5
3
4
5V Power
Hot Plug Detect
SRV0504 on USB Port Application
Vbus
D+
D-
USB Port
Vbus
6
5
4
1
2
3
GND
USB
Controller
Vbus
D+
D-
USB Port
GND
Rev:May 8th 2018
5/6
www.leiditech.com
SRV0504
SOT-23-6L Package Outline & Dimensions
Inches
Symbol
Min.
A
θ
Nom. Max. Min. Nom. Max.
0.035
0.057 0.90
1.45
A1
0.000
0.006 0.00
0.15
A2
0.035 0.045 0.051 0.90 1.15 1.30
b
0.010
0.020 0.25
0.50
0.009 0.08
0.22
c
0.003
D
0.110 0.114 0.122 2.80 2.90 3.10
E1
0.060 0.063 0.069 1.50 1.60 1.75
E
0.110 BSC
2.80 BSC
e
0.037 BSC
0.95 BSC
e1
0.075 BSC
1.90 BSC
L
0.012 0.018 0.024 0.30 0.45 0.60
L1
θ
Soldering Footprint
Millimeters
(0.024)
0°
(0.60)
10°
0°
10°
aaa
0.004
0.10
bbb
0.008
0.20
ccc
0.008
0.20
Symbol
Inches
Millimeters
C
(0.098)
(2.50)
G
0.055
1.40
P
0.037
0.95
X
0.024
0.60
Y
0.043
1.10
Z
0.141
3.60
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev:May 8th 2018
6/6
www.leiditech.com
很抱歉,暂时无法提供与“SRV0504”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.59990
- 50+0.47425
- 150+0.41143
- 500+0.36429
- 3000+0.32656
- 6000+0.30774
- 国内价格
- 1+0.58630
- 200+0.37950
- 1500+0.32890
- 3000+0.29260
