ESD9D12V
ESD9D12V
    LEIDITECH(雷卯电子)
    SOD2_0.8X0.6MM
    ESD保护 VRWM=12 V VBR(Min)=13.5 V VC=23.7 V IPP=5.9 A Ppp=140 W SOD2_0.8X0.6MM
ESD9D12V 数据手册
ESD9D12V UNIDIRECTIONAL TVS DIODE Features ● ● ● ● Ultra low leakage: nA level Operating voltage: 12V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Contact discharge: ±8kV Dimensions SOD-923 – IEC61000-4-5 (Lightning) 5.9A (8/20μs) ● RoHS Compliant Pin Configuration Applications ● ● ● ● ● ● USB 2.0 power and data line Set-top box and digital TV Digital video interface (DVI) Notebook Computers SIM Ports 10/100 Ethernet Mechanical Characteristics ● Package: SOD-923 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:8,000pcs ● Reel Size:7 inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp VESD Value Unit 140 W ± 15 Kv ± 8 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2015 1/4 www.leiditech.com ESD9D12V Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number Device Marking ESD9D12V Rev : 01.06.2015 - VRWM (V) VBR (V) IT (mA) VC @1A 12 13.5 1 - 2/4 (Max) (@A) 23.7 5.9 IR μA (Max) C (Pf) (Typ.) 1 30 www.leiditech.com ESD9D12V TYPICAL CHARACTERISTICS Figure 1. Typical Breakdown Voltage versus Temperature Figure 3. Fig 2. Typical Leakage Current versus Temperature 8*20 μs Pulse Waveform Figure 4. Positive 8kV contact per IEC 61000-4-2-LESD9D5.0T5G Rev : 01.06.2015 Fig 5. Negative 8kV contact per IEC 61000-4-2-LESD9D5.0T5G 3/4 www.leiditech.com ESD9D12V SOD-923 Mechanical Data Soldering Footprint Dimensions: Millimeters Millimeters Dim Inches Min Nom Max Min Nom Max A 0.36 0.40 0.43 0.014 0.016 0.017 b 0.15 0.20 0.25 0.006 0.008 0.010 c 0.07 0.12 0.17 0.003 0.005 0.007 D 0.75 0.80 0.85 0.030 0.031 0.033 E 0.55 0.60 0.65 0.022 0.024 0.026 HE 0.95 1.00 1.05 0.037 0.039 0.041 L 0.05 0.10 0.15 0.002 0.004 0.006 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2015 4/4 www.leiditech.com
ESD9D12V 价格&库存
很抱歉,暂时无法提供与“ESD9D12V”相匹配的价格&库存,您可以联系我们找货
