ULC0544M
ULC0544M
    LEIDITECH(雷卯电子)
    MSOP10_3X3MM
    ESD保护 VRWM=5 V VBR(Min)=6 V VC=20 V IPP=5 A Ppp=100 W MSOP10_3X3MM
ULC0544M 数据手册
ULC0544M 4-Line Ultra Low Capacitance TVS Diode Array Features ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 5V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 5A (8/20μs) RoHS Compliant Dimensions MSOP-10 Pin Configuration Applications ● ● ● ● ● ● USB 2.0 power and data line Set-top box and digital TV Digital video interface (DVI) Notebook Computers SIM Ports 10/100 Ethernet Mechanical Characteristics ● Package: MSOP-10 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3,000pcs ● Reel Size:13 inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value 100 Unit W ±30 VESD Kv ±30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2014 1/3 www.leiditech.com ULC0544M Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number Device Marking VRWM (V) VBR (V) IT (mA) VC @1A 544M 5 6 1 12 ULC0544M (Max) (@A) 20 IR μA (Max) C (Pf) (Typ.) 0.5 0.6 5 Characteristic Curves Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) Fig1. 8/20µ s Pulse Waveform 120 IPP - Peak Pulse Current - % of IPP 100 100% TEST WAVEFORM PARAMETERS tr=8 s td=20 s Peak Value IPP 80 Percent of Peak Pulse Current % tr 60 40 td=t IPP/2 20 0 0 5 10 15 20 25 10% tr = 0.7~1ns Time (ns) 30ns 30 60ns t - Time ( s) Fig3. 90% Power Derating Curve % of Rated Power 110 100 90 80 70 60 50 40 30 20 10 0 0 25 50 75 100 125 150 Ambient Temperature –TA (ºC) Rev : 01.06.2014 2/3 www.leiditech.com ULC0544M MSOP-10 Package Outline Drawing e A DIM D N SEE DETAIL 2X SIDE VIEW E/2 E E1 PIN 1 INDICATOR H ccc C 1 2 2X N/2 TIPS c GAGE PLANE B 0.25 L 01 (L1) D DETAIL aaa C A2 SEATING PLANE A DIMENSIONS INCHES MILLIMETERS NOM MIN NOM MAX MIN MAX A A1 A2 b c D E1 E e L L1 N 01 aaa bbb ccc .043 .006 .000 .037 .030 .007 .011 .009 .003 .114 .118 .122 .114 .118 .122 .193 BSC .020 BSC .016 .024 .032 (.037) 10 8° 0° .004 .003 .010 1.10 0.15 0.00 0.95 0.75 0.17 0.27 0.23 0.08 2.90 3.00 3.10 2.90 3.00 3.10 4.90 BSC 0.50 BSC 0.40 0.60 0.80 (.95) 10 0° 8° 0.10 0.08 0.25 A A A1 C bxN bbb C A-B D NOTES: 1. CONTROLLING DIMENSIONS ARE IN MILLIMETERS (ANGLES IN DEGREES). 2. DATUMS -A- AND -B- TO BE DETERMINED AT DATUM PLANE -H- 3. DIMENSIONS "E1" AND "D" DO NOT INCLUDE MOLD FLASH, PROTRUSIONS OR GATE BURRS. 4. REFERENCE JEDEC STD MO-187, VARIATION BA. Suggested Land Pattern X DIM (C) G C G P X Y Z Z Y DIMENSIONS INCHES MILLIMETERS (.161) .098 .020 .011 .063 .224 (4.10) 2.50 0.50 0.30 1.60 5.70 P NOTES: 1. THIS LAND PATTERN IS FOR REFERENCE PURPOSES ONLY. CONSULT YOUR MANUFACTURING GROUP TO ENSURE YOUR COMPANY'S MANUFACTURING GUIDELINES ARE MET. Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2014 3/3 www.leiditech.com
ULC0544M 价格&库存
很抱歉,暂时无法提供与“ULC0544M”相匹配的价格&库存,您可以联系我们找货
