ESDA05
1. Electrical Specification
1-1 Test condition
Varistor voltage
Leakage current
Maximum clamping voltage
In = 1 mA DC
Vdc = 5.5 V DC
Ic = 1 A
Rated peak single pulse transient current
8 / 20 ㎲ waveform, +/- each 1 time induce
Capacitance
10/1000 ㎲ waveform
Insulation resistance after reflow soldering
f = 1MHz, Vrms = 0.5 V
Soldering paste : Tamura (Japan) RMA-20-21L
Stencil : SUS, 120 ㎛ thickness
Reflow soldering condition
Pad size : 0.8 (Width) x 0.9 (Length)
0.8 (Distance between pads)
Soldering profile : 260±5 ℃, 5 sec.
1-2 Electrical specification
Maximum allowable continuous DC voltage
5.5
V
trigger voltage / Varistor voltage / breakdown voltage
12
V
25
V
Maximum
1
A
Maximum
Nonlinearity coefficient
> 12
Leakage current at continuous DC voltage
< 0.1
Response time
< 0.5
ns
Varistor voltage temperature coefficient
< 0.05
5
pF
Capacitance measured at 1MHz
Capacitance tolerance
-50 to +80
Insulation resistance after reflow soldering on PCB
> 10
Operating ambient temperature
-55 to +125
Storage temperature
-55 to +125
Rev : 01.06.2018
1/5
Typical
MΩ
www.leiditech.com
ESDA05
1-3 Reliability testing procedures
Reliability
parameter
Pulse current
capability
Electrostatic
discharge
capability
Test
Imax
8/20 ㎲
ESD
C=150 pF,
R=330Ω
Environmenta
l reliability
Thermal shock
Test methods and remarks
Test requirement
IEC 1051-1, Test 4.5.
dVn/Vn≤ 10%
10 pulses in the same direction at 2
pulses per minute at maximum peak
current
no visible damage
IEC 1000-4-2
dVn/Vn≤ 10%
Each 10 times in positive/negative
direction in 10 sec at 8KV contact
discharge (Level 4)
no visible damage
IEC 68-2-14
dVn/Vn≤ 5%
Condition for 1 cycle
Step 1 : Min. –40℃, 30±3 min.
no visible damage
Step 2 : Max. +125℃, 30±3 min.
Number of cycles: 30 times
Low temperature
IEC 68-2-1
dVn/Vn≤ 5%
Place the chip at -40±5℃ for 1000±
no visible damage
12hrs. Remove and place for 24±2hrs at
room temp. condition, then measure
High temperature
IEC 68-2-2
dVn/Vn≤ 5%
Place the chip at 125±5℃ for 1000±
no visible damage
24hrs. Remove and place for 24±2hrs at
Heat resistance
IEC 68-2-3
dVn/Vn≤ 5%
Apply the rated voltage for 1000±48hrs at
no visible damage
85±3℃. Remove and place for 24±2hrs
at room temp. condition, then measure
Humidity
resistance
IEC 68-2-30
dVn/Vn≤ 10%
Place the chip at 40±2℃ and 90 to 95%
no visible damage
humidity for 1000±24hrs. Remove and
Pressure cooker
test
Rev : 01.06.2018
room
temp.
Place the chip at 2 atm, 120℃, 85%RH
dVn/Vn≤ 10%
for 60 hrs. Remove and place for 24±
2hrs at room temp. condition, then
measure
no visible damage
2/5
www.leiditech.com
ESDA05
ESD
Operating life
Mechanical
Solderability
Reliability
dVn/Vn≤ 10%
125±3℃. Remove and place for 24±2hrs
no visible damage
IEC 68-2-58
At least 95% of terminal
electrode is covered by
new solder
Solder bath method, 230±5℃, 2s
Resistance to
soldering heat
Bending strength
IEC 68-2-58
dVn/Vn≤ 5%
Solder bath method,
260±5℃, 10±0.5s, 270±5℃, 3±0.5s
IEC 68-2-21
dVn/Vn≤ 5%
Warp:2mm, Speed:0.5mm/sec, Duration:
10sec. The measurement shall be made
with board in the bent position
Adhesive strength
no visible damage
IEC 68-2-22
no visible damage
Strength>10 N
Applied force on SMD chip by fracture
from PCB
no visible damage
2. Material Specification
Body
ZnO based ceramics
Internal electrode
Silver – Palladium
External electrode
Silver – Nickel – Tin
Thickness of Ni/Sn plating layer
Nickel > 1 ㎛, Tin > 2 ㎛
3. Dimension Specification
L
T
W
Size
L(mm)
W(mm)
T(mm)
M(mm)
0402
1.0±0.10
0.5±0.10
≤ 0.6
0.20±0.10
0603
1.6±0.15
0.8±0.15
≤ 0.9
0.35±0.10
M
Rev : 01.06.2018
3/5
www.leiditech.com
ESDA05
ESD
4. Soldering Recommendations
4-1 Soldering profile
4-1-1 Pb free solder paste
4-1-2 Repair soldering
Allowable time and temperature for making correction with a soldering iron
: 350 ± 10 ℃, 3 sec.
Optimum solder amount when corrections are made using a soldering iron
4-2 Soldering guidelines
Our chip varistors are designed for reflow soldering only. Do not use flow soldering
Use non-activated flux (Cl content 0.2% max.)
Follow the recommended soldering conditions to avoid varistor damage.
Rev : 01.06.2018
4/5
www.leiditech.com
ESDA05
4-3 Solder pad layout
5. Storage condition
Storage environment must be at an ambient temperature of 25~35 ℃ and an ambient
humidity of 40~60 % RH
Chip varistors can experience degradation of termination solderability when subjected to
high temperature of humidity, or if exposed to sulfur or chlorine gases.
Avoid mechanical shock (ex. Falling) to the chip varistor to prevent mechanical cracking
inside of the ceramic dielectric due to its own weight.
Use chips within 6 months.
If 6 months of more have elapsed, check solderability before use.-
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2018
5/5
www.leiditech.com
很抱歉,暂时无法提供与“ESDA05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.69840
- 200+0.23280
- 2000+0.14520
- 4000+0.11556
- 国内价格
- 20+0.20274
- 200+0.16058
- 600+0.13717
- 4000+0.11102
- 8000+0.09880
- 20000+0.09234
