PESD1542U005
PESD1542U005
    LEIDITECH(雷卯电子)
    0402的ESD保护二极管
PESD1542U005 数据手册
PESD1542U005 Ultal Low Capacitance ESD Protection Diode in 0402 Features ■ ESD protection for high speed data lines to IEC61000-4-2 ■ ESD contact discharge typical 8KV, max 15KV ■ ESD air discharge typical 15KV, max 25KV 1 2 ■ Surface mount ■ Extremely low capacitance ■ Very low leakage current ■ Fast response time ■ Bi-directional ESD protection ■ Lead free solder termination ■ The best ESD protection for high frequency, low voltage applications Mechanical Data Applications ■ Case: 0402 (plastic package). Lead free; RoHS compliant ■ USB3.0, Firewire, DVI, HDMI, S-ATA ■ Molding Compound Flammability Rating: UL 94 V-0 ■ Mobile HDMI Link, MDDI, MIPI, SWP / NFC ■ Terminals: High temperature soldering guaranteed: 260 °C/10 sec. at terminals ■ Thunderbolt, Display Port Absolute Maximum Ratings Ratings at 25 °C, ambient temperature unless otherwise specified Parameter Symbol Value Unit Maximum Contact discharge voltage Per IEC61000-4-2 --- 15KV V Maximum Air discharge voltage Per IEC61000-4-2 --- 25KV V Maximum Operating temperature TOPER -40 to +90  Maximum Storage temperature TSTG -55 to +125  TL 260  Maximum lead temperature for soldering during 10s Electrical Characteristics (TA = 25 °C unless otherwise specified) Parameter Symbol Test Conditions Min Typ Max Units Rated Voltage VR --- 15 V Trigger voltage VT IEC61000-4-2 8KV contact discharge 300 V Clamping voltage VC IEC61000-4-2 8KV contact discharge 35 V Leakage current IL DC 12V shall be applied on component Capacitance CP VR = 0V, f = 1MHz 0.10 0.05 uA pF Note: 1 Trigger and clamping voltage are measured per IEC 61000-4-2, 8KV contact discharge method. 2 After reliability tests such as high temp storage, temp cycles, continuous ESD strike etc, the maximum leakage current is less than 10uA. Rev : 01.06.2017 1/3 www.leiditech.com PESD1542U005 ESD Clamping Test ESD TESTER RZ 450 Ω RG 223/U 50 Ω coax 4 GHz DIGITAL 10× OSCILLOSCOPE ATTENUATOR CZ 50 Ω DUT (DEVICE UNDER TEST) IEC 61000-4-2 network CZ = 150 pF; RZ = 330 Ω ESD Clamping Test Waveforms ESD Wave after Clamping IPP 400 100% 90% 10% 0 tr = 0.7 ns to 1ns 30 ns t -50 60 ns Rev : 01.06.2017 2/3 50 150 250 www.leiditech.com PESD1542U005 Product Dimension Dim millmeters min max A 0.90 1.20 B 0.45 0.65 C 0.30 0.40 D 0.00 0.05 E F G H 0.125REF 0.40 0.50 0.65BSC 0.25 0.35 Ordering information Order code Package Packaging option Base quantity Packaging specification PESD1542U005 0402 Tape and reel 10000pcs / reel EIA STD RS-481 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2017 3/3 www.leiditech.com
PESD1542U005 价格&库存
很抱歉,暂时无法提供与“PESD1542U005”相匹配的价格&库存,您可以联系我们找货
PESD1542U005
