SDA05DT4
SDA05DT4
    LEIDITECH(雷卯电子)
    SOT-143
    用于esd和锁存保护的TVS二极管阵列 SOT-143 100W 5V
SDA05DT4 数据手册
SDA05DT4 TVS DIODE ARRAY FOR ESD AND LATCH-UP PROTECTION Features ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 5V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Contact discharge: ±8kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 5A (8/20μs) RoHS Compliant Dimensions SOT-143 Pin Configuration Applications ● ● ● ● ● ● USB 2.0 power and data line Set-top box and digital TV Digital video interface (DVI) Notebook Computers SIM Ports 10/100 Ethernet Mechanical Characteristics ● Package: SOT-143 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3,000pcs ● Reel Size:7inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value Unit 100 W ±15 VESD Kv ±8 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2014 1/3 www.leiditech.com SDA05DT4 Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number Device Marking VRWM (V) VBR (V) IT (mA) VC @1A 05D 5 6 1 9.8 SDA05DT4 (Max) (@A) 15 IR μA (Max) C (Pf) (Typ.) 1 30 5 Characteristic Curves Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) Fig1. 8/20µ s Pulse Waveform 120 IPP - Peak Pulse Current - % of IPP 100 100% TEST WAVEFORM PARAMETERS tr=8 s td=20 s Peak Value IPP 80 Percent of Peak Pulse Current % tr 60 40 td=t IPP/2 20 0 0 5 10 15 20 25 10% tr = 0.7~1ns Time (ns) 30ns 30 60ns t - Time ( s) Fig3. 90% Power Derating Curve % of Rated Power 110 100 90 80 70 60 50 40 30 20 10 0 0 25 50 75 100 125 150 Ambient Temperature –TA (ºC) Rev : 01.06.2014 2/3 www.leiditech.com SDA05DT4 SOT-143 Package Outline & Dimensions Inches Symbol Min. θ Nom. Max. Min. Nom. Max. A 0.031 - 0.048 0.80 - 1.22 A1 0.000 - 0.008 0.013 - 0.15 A2 0.020 0.035 0.042 0.75 0.90 1.07 0.011 0.30 - 0.51 b - 0.020 b1 0.029 - 0.037 0.76 - 0.94 c 0.003 - 0.008 0.08 - 0.20 D 0.110 0.114 0.120 2.80 2.90 3.04 E 0.082 0.093 0.104 2.10 2.37 2.64 E1 0.047 0.051 0.055 1.20 1.30 1.40 e 0.075 1.92 BSC e1 0.008 0.20 BSC L 0.015 0.020 0.024 L1 (0.021) N 0.40 0° - 0.50 0.60 (0.54) 4 θ Soldering Footprint Millimeters 4 8° 0° - aaa 0.006 0.15 bbb 0.008 0.20 ccc 0.004 0.10 8° Symbol Inches Millimeters C (0.087) (2.20) E1 0.076 1.92 E2 0.068 1.72 G 0.031 0.80 X1 0.039 1.00 X2 0.047 1.20 Y 0.055 1.40 Z 0.141 3.60 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2014 3/3 www.leiditech.com
SDA05DT4
物料型号:SDA05DT4
器件简介:超低漏电流(nA级别),工作电压5V,低钳位电压,符合IEC 61000-4-2 (ESD)、IEC61000-4-4 (EFT)和IEC61000-4-5 (Lightning)标准,符合RoHS标准。
引脚分配:SOT-143封装,无具体引脚分配图。
参数特性:包括最大脉冲功率、ESD保护等级、工作温度范围、存储温度范围等。
功能详解:文档提供了特性曲线图,包括8/20μs脉冲波形和ESD脉冲波形。
应用信息:适用于USB 2.0电源和数据线、机顶盒和数字电视、DVI接口、笔记本电脑、SIM卡端口、10/100以太网等。
封装信息:SOT-143封装,无铅引脚,UL可燃性等级94V-0,每卷3000件,卷径7英寸。
