ULC0502P3
ULC0502P3
    LEIDITECH(雷卯电子)
    DFN3_1X0.6MM
    ESD保护 VRWM=5 V VBR(Min)=6 V VC=13 V IPP=5 A Ppp=75 W DFN3_1X0.6MM
ULC0502P3 数据手册
ULC0502P3 2-Line Uitra Low Capacitance TVS Diode Features        Ultra small package: 1.0x0.6x0.5mm Ultra low capacitance: 0.3pF typical(I/O-I/O) Ultra low leakage: nA level Low operating voltage: 5V Low clamping voltage 3-pin leadless package Up to 2-line protects  Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±25kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 5A (8/20μs) RoHS Compliant  Dimensions DFN1006DN 0.5 Pin Configuration Applications          Cellular Handsets and Accessories Display Ports MDDI Ports USB 2.0 and 3.0 Ports HDMI 1.3 and 1.4 Digital Video Interface (DVI) PCI Express and Serial SATA Ports Notebook Computer IEEE 1394 Mechanical Characteristics        Package: DFN1006-3 (1.0×0.6×0.5mm) Lead Finish: NiPdAu Case Material: “Green” Molding Compound. UL Flammability Classification Rating 94V-0 Moisture Sensitivity: Level 3 per J-STD-020 Terminal Connections: See Diagram Below Marking Information: See Below Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Value Ppp 75 VESD ± 30 Unit W Kv ± 25 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +150 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2017 1/4 www.leiditech.com ULC0502P3 Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number ULC0502P3 Rev : 01.06.2017 Device Marking 25 VRWM (V) VBR (V) IT (mA) 5 6 1 VC @1A 10 2/4 (Max) 13 (@A) 5 IR μA (Max) C (Pf) (Typ.) 0.5 0.6 www.leiditech.com ULC0502P3 Typical Performance Characteristics (TA=25°C unless otherwise Specified) 10 0.8 Peak Power_Ppp(W) Junction Capacitance_Cj (pF) 1 0.6 0.4 0.2 1 0.1 0.01 0 0 1 2 3 4 Reverse Voltage_VR (V) 5 0.1 Junction Capacitance vs. Reverse Voltage 100 Peak Pulse Power vs. Pulse Time 16 120 14 100 12 % of Rated Power Clamping Voltage_Vc (V) 1 10 Pulse Duration_tp(uS) 10 8 6 4 80 60 40 20 2 0 0 0 1 2 3 4 5 Peak Pulse Current_Ipp (A) 6 0 Clamping Voltage vs. Peak Pulse Current 25 50 75 100 125 Ambient Temperature_Ta(℃) 150 Power Derating Curve 100 % of Peak Pulse Current 90 80 70 60 50 40 30 20 10 0 0 Rev : 01.06.2017 20 40 60 Time_t(uS) 8 X 20uS Pulse Waveform ESD Clamping Voltage 80 8 kV Contact per IEC61000−4−2 3/4 www.leiditech.com ULC0502P3 DFN1006-3 Package Outline Drawing SY M A A1 b b1 c D e E E1 L L1 DIMENSIONS MILLIMETERS INCHES MIN NOM MAX MIN NOM MAX 0.45 0.50 0.55 0.018 0.020 0.022 0.00 0.02 0.05 0.000 0.001 0.002 0.45 0.50 0.55 0.018 0.020 0.022 0.10 0.15 0.20 0.004 0.006 0.008 0.12 0.15 0.18 0.005 0.006 0.007 0.95 1.00 1.05 0.037 0.039 0.041 0.65 BSC 0.026 BSC 0.55 0.60 0.65 0.022 0.024 0.026 0.15 0.20 0.25 0.006 0.008 0.010 0.20 0.25 0.30 0.008 0.010 0.012 0.0002 REF 0.05 REF Suggested Land Pattern Y1 SYM Y2 Y3 X Z C DIMENSIONS MILLIMETERS INCHES C 0.25 0.010 X 0.65 0.024 Y1 0.50 0.020 Y2 0.50 0.020 Y3 0.25 0.010 Z 0.20 0.008 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2017 4/4 www.leiditech.com
ULC0502P3 价格&库存
很抱歉,暂时无法提供与“ULC0502P3”相匹配的价格&库存,您可以联系我们找货
