ULC33CP8
ULC33CP8
    LEIDITECH(雷卯电子)
    DFN-8(2x1)
    ESD保护 VRWM=3.3 V VBR(Min)=3.5 V VC=17 V IPP=13 A Ppp=200 W DFN8_2X1MM
ULC33CP8 数据手册
ULC33CP8 LIGHTNING AND ESD PROTECTION FOR GIGABIT ETHRNET INTERFACE Features ● 200 Watts Peak Pulse Power per Line (tp=8/20µs) ● Protects Up To Two Bidirectional I/O Lines ● Low Capacitance (0.4pF) For High-Speed Interfaces ● Working Voltages : 3.3V ● Ultra-small Package Requires Less Than 2.0x1.0mm of PCB area ● IEC61000-4-2 (ESD) ±30kV (air), ±30kV (contact) ● IEC61000-4-4 (EFT) 40A (5/50ηs) ● IEC61000-4-5 (LIGHTING) 13A (8/20μs) Dimensions DFN2010 Applications ● 10/100/1000 Ethernet ● Integrated magnetics/RJ-45 connectors ● LAN/WAN Equipment ● Security Cameras ● Industrial Controls ● Peripherals ● Notebooks & Desktop Computers Pin Configuration Mechanical Characteristics ● DFN 2.0x1.0mm Package ● Molding Compound Flammability Rating : UL 94V-O ● Weight 1 Millgrams (Approximate) ● Quantity Per Reel : 3,000pcs ● Reel Size : 7 inch ● Lead Finish : Lead Free Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value Unit 200 W ±30 VESD Kv ±30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2015 1/5 www.leiditech.com ULC33CP8 Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number ULC33CP8 Rev : 01.06.2015 Device Marking VRWM (V) U33 3 VBR (V) 3.5 IT (mA) VC @1A 1 7 2/5 (Max) 17 (@A) 13 IR μA (Max) 0.1 C (Pf) (Typ.) 0.4 www.leiditech.com ULC33CP8 CHARACTERISTICS 8 x 20μs Pulse Waveform Power Derating Curve Clamping Voltage vs. Peak Pulse Current (8x20μs) Reverse Leakage Current vs. Temperature Rev : 01.06.2015 3/5 www.leiditech.com ULC33CP8 I/O to I/O Schematic Diagram for Gigabit Ethernet Protection Rev : 01.06.2015 4/5 www.leiditech.com ULC33CP8 DFN2010 PACKAGE OUTLINE & DIMENSIONS Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2015 5/5 www.leiditech.com
ULC33CP8 价格&库存
很抱歉,暂时无法提供与“ULC33CP8”相匹配的价格&库存,您可以联系我们找货
