ULC0811CDN
ULTRA LOW CAPACITANCE BIDIRECTIONAL TVS DIODE
Features
Ultra low leakage: nA level
Operating voltage: 8V
Low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±25kV
Contact discharge: ±20kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
– IEC61000-4-5 (Lightning) 3.5A (8/20μs)
RoHS Compliant
Dimensions DFN1006DN
AEC-Q101 qualified
Pin Configuration
Applications
Smart phones
Display Ports
MDDI Ports
USB Ports
Digital Video Interface (DVI)
PCI Express and Serial SATA Ports
Mechanical Characteristics
Package: DFN1006DN
Lead Finish: Lead Free
UL Flammability Classification Rating 94V-0
Quantity Per Reel:10,000pcs
Reel Size:7 inch
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
Symbol
Value
Ppp
90
VESD
± 25
Unit
W
Kv
± 20
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
-55 to +150
Storage Temperature Range
TSTJ
-55 to +150
Rev : 01.06.2018
1/4
www.leiditech.com
ULC0811CDN
Electrical Characteristics(TA=25°C unless otherwise specified)
Vc
Part Number
ULC0811CDN
Rev : 01.06.2018
Device
Marking
VRWM
(V)
VBR
(V)
IT
(mA)
VC
@1A
81
8
9.5
1
18
2/4
(Max)
26
(@A)
3.5
IR
μA
(Max)
C
(Pf)
(Typ.)
0.5
0.3
www.leiditech.com
ULC0811CDN
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
Junction Capacitance vs. Reverse Voltage
Peak Pulse Power vs. Pulse Time
Power Derating Curve
Clamping Voltage vs. Peak Pulse Current
Note:Data is taken with a 10x attenuator
ESD Clamping Voltage
8 X 20μs Pulse Waveform
Rev : 01.06.2018
8 kV Contact per IEC61000−4−2
3/4
www.leiditech.com
ULC0811CDN
DFN1006-2 (0402)Package Outline Drawing
e
D
h
h
b
E
L
A1
c
A
Bottom View
A
DIMENSIONS
MILLIMETERS
INCHES
MIN
NOM
MAX
MIN
NOM
MAX
0.45
0.50
0.55
0.018
0.020
0.022
A1
0.00
0.02
0.05
0.000
0.001
0.002
b
0.45
0.50
0.55
0.018
0.020
0.022
c
0.12
0.15
0.18
0.005
0.006
0.007
D
0.95
1.00
1.05
0.037
0.039
0.041
SYM
e
0.65 BSC
0.026 BSC
E
0.55
0.60
0.65
0.022
0.024
0.026
L
0.20
0.25
0.30
0.008
0.010
0.012
h
0.07
0.12
0.17
0.003
0.005
0.007
Suggested Land Pattern
Y3
SYM
Y1
Y2
Z
DIMENSIONS
MILLIMETERS
INCHES
X
0.60
0.024
Y1
0.50
0.020
Y2
0.30
0.012
Y3
0.80
0.032
Z
1.30
0.052
X
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2018
4/4
www.leiditech.com
很抱歉,暂时无法提供与“ULC0811CDN”相匹配的价格&库存,您可以联系我们找货
