MBR20150CT-MBR20200CT
Schottky Barrier Rectifiers
Reverse Voltage: 150,200V
Forward Current: 20A
TO-220AB
2.8± 0.1
Features
Metal-Semiconductor junction with guard ring
Epitaxial construction
Low forward voltage drop, low swithing losses
High surge capacity
For use in low voltage, high frequency inverters free
wheeling, and polarity protection applications
The plastic material carries U/L recognition 94V-0
4.5± 0.2
10.2± 0.2
1.4± 0.2
1
8.9± 0.2
19.0± 0.5
? 3.8± 0.15
PIN
2 3
13.8± 0.5
3.5± 0.3
2.6± 0.2
0.9± 0.1
Mechanical Data
0.5± 0.1
2.5± 0.1
PIN 1
Case: JEDEC TO-220AB, molded plastic body
PIN 3
Polarity: As marked
Mounting Position: Any
Weight: 0.071 ounce, 2.006 grams
CASE
PIN 2
Dimensions in millimeters
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25°C ambient temperature unless otherwise specified.
Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%.
Parameter
Symbol
MBR20150CT
Maximum recurrent peak reverse voltage
VRRM
150
200
V
Maximum RMS voltage
VRWS
135
140
V
Maximum DC blocking voltage
VDC
150
200
V
Maximum average forward tolal device
rectified current @TC=100°C
I(AV)
A
Peak forward surge current
8.3ms single half sine-wave
superimposed on rated load
IFSM
150
A
VF
0.95
V
Maximum instantaneous
forward voltage @10A
Maximum reverse current @TA=25°C
IR
at rated DC blocking voltage @TA=100°C
MBR20200CT
0.2
UNITS
mA
50
Maximum thermal resistance (Note1)
RθJC
1.5
°C/W
Operating junction temperature range
TJ
-55 --- +150
°C
TSTG
-55 --- +150
°C
Storage temperature range
NOTES: 1. Thermal resistance from junction to case.
Revision:20170701-P1
ht t p : //
www.lgesem i .c o m
mail:lge@lgesemi.com
Ratings AND Charactieristic Curves
FIG.1 TYPICAL FORWARD CHARACTERISTICS
FIG.2 FORWARD DERATING CURVE
Average Forward Rectified
Current, (A)
Instantaneous Forward Current, (A)
100
10
1.0
16
12
8.0
4.0
0.8
0.9
1.0
1.1
1.2
1.3
1.4
Instantaneous Forward Voltage, ( V )
FIG.3 TYPICAL REVERSE CHARACTERISTICS
75
100
125
150
FIG.4 PEAK FORWARD SURGE CURRENT
150
Peak Forward Surge Current,
(A)
Instantaneous Reverse Leakage
µ )
mA
Current, (μ
μ
50
Case Temperature, ( °C )
1000
100
10
TA=100°C
1.0
TA=25°C
0.1
120
90
60
30
60
80
100
120
140
Percent Of Rated Peak Reverse Voltage, %
25
ht t p : //
1
10
100
Number Of Cycles At 60Hz
www.lgesem i .c o m
很抱歉,暂时无法提供与“MBR20200CT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.30640
- 10+1.21440
- 30+1.19600
