BAV21W
BAV21W
    LGE(鲁光)
    SOD-123
    表面贴装快速开关二极管 SOD123-2
BAV21W 数据手册
BAV19W-BAV21W Surface Mount Fast Switching Diode SOD-123 Features 0.022(0.55) Typ. Min. 0.053(1.35) Max.  Fast Switching Speed  Surface Mount Package Ideally Suited for Automatic Insertion For General Purpose Switching Applications  0.152(3.85) 0.140(3.55) Mechanical Data      0.112(2.85) 0.100(2.55) 0.010(0.25) Min. Case: SOD-123, Molded Plastic Case Material: UL Flammability Rating Classification 94V-0 Polarity: Cathode Band Type Code: BAV19W: A8 or T2 or T3 BAV20W: T2 or T3 BAV21W: T3 Weight: 0.01 grams (approx.) 0.067(1.70) 0.055(1.40) 0.006(0.15) Typ. Min. 0.004(0.10) Max. Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25oC ambient temperature unless otherwise specified. Maximum Ratings Characteristic Symbol Peak Repetitive Reverse Voltage BAV19W BAV20W BAV21W Unit 120 200 250 V VR 100 150 200 V VR(RMS) 71 106 141 V VRRM VRWM Working Peak Reverse Voltage DC Blocking Voltage RMS Reverse Voltage Forward Continuous Current IFM 400 mA Average Rectified Output Current IO 200 mA Non-Repetitive Peak Forward Surge Current @ t = 1.0ms @ t = 1.0s IFSM 2.5 0.5 A Repetitive Peak Forward Surge Current IFRM 625 mA Pd 250 mW RqJA 500 °C/W Tj , TSTG -65 to +150 °C (Note 2) Power Dissipation Thermal Resistance Junction to Ambient Air (Note 2) Operating and Storage Temperature Range Electrical Characteristics Characteristic Symbol Min Max Unit V(BR)R 120 200 250 ¾ V IR = 100mA Forward Voltage (Note 1) VFM ¾ 1.0 1.25 V IF = 100mA IF = 200mA Peak Reverse Current @ Rated DC Blocking Voltage (Note 1) IRM ¾ 100 15 nA mA Tj = 25°C Tj = 100°C Total Capacitance CT ¾ 5.0 pF VR = 0, f = 1.0MHz ns IF = IR = 30mA, Irr = 0.1 x IR, RL = 100W Reverse Breakdown Voltage (Note 1) BAV19W BAV20W BAV21W trr Reverse Recovery Time Notes: 50 1. Short duration pulse test used to minimize self-heating effect. ht t p : // Revision:20170701-P1 ¾ Test Condition www.lgesemi .c o m mail:lge@lgesemi.com BAV19W-BAV21W Surface Mount Fast Switching Diode Pd, POWER DISSIPATION (mW) 250 200 150 100 50 0 25 0 50 75 100 125 150 IF, INSTANTANEOUS FORWARD CURRENT (mA) 300 1000 Tj = 25°C 100 10 1.0 0.1 0.01 0 T , AMBIENT TEMPERATURE (ºC) A Fig. 1 Power Derating Curve 2 1 VF, INSTANTANEOUS FORWARD VOLTAGE (V) Fig. 2 Typical Forward Characteristics IR, LEAKAGE CURRENT (µA) 100 10 1 0.1 0.01 0 100 200 Tj, JUNCTION TEMPERATURE (°C) Fig. 3 Leakage Current vs Junction Temperature PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SOD-123 3000/REEL 90000 40X20X22 5.00 4.00 ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com
BAV21W 价格&库存
很抱歉,暂时无法提供与“BAV21W”相匹配的价格&库存,您可以联系我们找货
BAV21W
  • 50+0.12270
库存:230
BAV21W
  • 50+0.13522
  • 500+0.10606
  • 3000+0.08662
  • 6000+0.07690
  • 24000+0.06848
  • 51000+0.06394
库存:2943
