FM4007
FM4007
    LGE(鲁光)
    SMF(SOD-123FL)
    1.0A表面安装通用整流器
FM4007 数据手册
FM4001 - FM4007 1.0A Surface Mount General Purpose Rectifiers SOD-123FL Features  0.043(1.09) 0.035(0.89) 0.075(1.90) 0.067(1.70) Batch process design, excellent power dissipation offers better reverse leakage current and thermal resistance.  0.114(2.9) 0.098(2.5) Low profile surface mounted application in order to optimize board space.  Tiny plastic SMD package.  High current capability.   Glass passivated chip junction. 0.008(0.20) 0.004(0.10) 0.047(1.19) 0.043(1.09) High surge capability. 0.030(0.76) 0.018(0.45) Mechanical data     Case : Molded plastic, SOD-123FL Polarity : Indicated by cathode band Mounting Position : Any 0.154(3.9) 0.138(3.5) Weight : Approximated 0.01gram Dimensions in inches and(millimeters) Maximum Ratings and Electrical Characteristics Rating at 25oC ambient temperature unless otherwise specified. Maximum ratings FM FM FM FM FM FM FM 4001 4002 4003 4004 4005 4006 4007 UNITS A1 A2 A3 A4 A5 A6 A7 Device marking code Maximum recurrent peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V VDC 50 100 200 400 600 800 1000 V Maximum DC blocking voltage Maximum average forword rectified current @TA=75℃ I(AV) 1.0 A IFSM 30 A VF 1.1 V Peak forward surge current 8.3ms single half-sine-wave superimposed on rated load Maximum instantaneous forward voltage @IFM=1.0A (Note 1) Maximum DC reverse current @TA=25℃ at rated DC blocking voltage @T A=125℃ Typical junction capacitance measured at f=1MH Z,VR=4.0V Typical thermal resistance junction to lead 50 µA CJ 15 pF RθJL 20 ℃/W Tj - 55 --- + 150 ℃ TSTG - 55 --- + 150 ℃ Operating temperature range Storage temperature range 5.0 IR NOTE1.Pulse test: pulse width 300µsec,duty cycle 2%. ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com FM4001 - FM4007 1.0A Surface Mount General Purpose Rectifiers Rating and characteristic curves (FM4001 THRU FM4007) FIG.1-TYPICAL FORWARD FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE AVERAGE FORWARD CURRENT,(A) CHARACTERISTICS 10 3.0 1.0 1.2 1.0 0.8 Single Phase 0.6 Half Wave 60Hz Resistive Or Inductive Load 0.4 0.2 0 0 20 40 TJ=25 C 60 80 100 120 140 160 180 200 AMBIENT TEMPERATURE ( C) Pulse Width 300us 1% Duty Cycle 0.1 FIG.4-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT .01 .6 .7 .8 .9 1.0 1.1 1.2 PEAK FORWAARD SURGE CURRENT,(A) INSTANTANEOUS FORWARD CURRENT,(A) 50 1.3 FORWARD VOLTAGE,(V) FIG.3 - TYPICAL REVERSE CHARACTERISTICS 50 40 30 8.3ms Single Half TJ=25 C Sine Wave 20 JEDEC method 10 0 1 100 5 50 10 100 NUMBER OF CYCLES AT 60Hz FIG.5-TYPICAL JUNCTION CAPACITANCE 35 TJ=100 C JUNCTION CAPACITANCE,(pF) REVERSE LEAKAGE CURRENT, (mA) 10 1.0 TJ=25 C .1 30 25 20 15 10 5 .01 0 0 20 40 60 80 .01 .05 .5 1 5 10 50 100 REVERSE VOLTAGE,(V) PERCENTAGE RATED PEAK REVERSE VOLTAGE PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SOD-123FL 3000/REEL 90000 40X20X22 5.00 4.00 ht t p : // Revision:20170701-P1 .1 100 120 140 www.lgesemi .c o m mail:lge@lgesemi.com
FM4007 价格&库存
很抱歉,暂时无法提供与“FM4007”相匹配的价格&库存,您可以联系我们找货
FM4007
    • 1+0.06030
    • 100+0.05660
    • 300+0.05290
    • 500+0.04920
    • 2000+0.04735
    • 5000+0.04625
    FM4007
    • 1+0.21780
    • 200+0.07238
    • 1500+0.04521
    • 3000+0.03597
    库存:2300
