ES2M
ES2M
    LGE(鲁光)
    SMA(DO-214AC)
    超快速表面贴装整流器
ES2M 数据手册
ES2A thru ES2M Super Fast Surface Mount Rectifiers Reverse Voltage 50 to 1000 Volts Forward Current 2.0 Amperes Features ‹ Glass passivated chip ‹ Super fast switching for high efficiency ‹ For surface mounted applications ‹ Low forward voltage drop and high current capability ‹ Low reverse leakage current ‹ Plastic material has UL flammability classification 94V-0 Mechanical Data ‹ Case : Molded plastic ‹ Polarity : Indicated by cathode band ‹ Weight : 0.002 ounce, 0.064 gram Maximum Ratings and Electrical Characteristics Ratings at 25oC ambient temperature unless otherwise specified. Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20% Symbols ES 2A ES 2B Maximum repetitive peak reverse voltage VRRM 50 Maximum RMS voltage VRMS 35 Maximum DC blocking voltage V DC 50 Parameter Maximum average forward rectified current ES 2C ES 2D ES 2F ES 2G ES 2J ES 2K ES 2M 100 150 200 300 400 70 105 140 210 280 600 800 1000 Volts 420 560 700 Volts 100 150 200 300 400 600 800 1000 Volts Units I(AV) 2.0 Amps Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) IFSM 50.0 Amps Maximum instantaneous forward voltage @ 2.0A DC VF Maximum DC reverse current at rated DC blocking voltage @TL=110oC @ TJ=25oC @ TJ=125oC 0.92 1.25 IR nS trr 75 Typical junction capacitance (Note 2) CJ 25 Typical thermal resistance (Note 3) Storage temperature range Notes: pF o RθJL 20 TJ -55 to +150 o C -55 to +150 o C TSTG C/W 1. Reverse Recovery Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A 2. Measured at 1.0MHz and applied reverse voltage of 4.0V DC. 3. Thermal Resistance junction to Lead. ht t p : // Revision:20170701-P1 Volts uA uA Maximum reverse recovery time (Note 1) Operating junction temperature range 1.7 5.0 350 www.lgesemi .c o m mail:lge@lgesemi.com ES2A thru ES2M Super Fast Surface Mount Rectifiers Reverse Voltage 50 to 1000 Volts Forward Current 2.0 Amperes RATINGS AND CHARACTERISTIC CURVES ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com
很抱歉,暂时无法提供与“ES2M”相匹配的价格&库存,您可以联系我们找货
ES2M
    • 10+0.17999
    • 50+0.16559
    • 200+0.15359
    • 600+0.14159
    • 1500+0.13199
    • 3000+0.12599
    库存:1315
