BC337-25
BC337-25
    LGE(鲁光)
    TO92-3
    TO92 NPN 800mA 45V
BC337-25 数据手册
BC337/338(NPN) TO-92 Bipolar Transistors TO-92 1. COLLECTOR 2. BASE 3. EMITTER Features  Power dissipation MAXIMUM RATINGS (TA=25℃ unless otherwise noted) Symbol VCBO VCEO Parameter Collector-Base Voltage Collector-Emitter Voltage VEBO Emitter-Base Voltage IC Value BC337 50 BC338 30 BC337 45 BC338 25 Units V V Dimensions in inches and (millimeters) 5 V Collector Current -Continuous 800 mA PD Total Device Dissipation 625 mW Tj Junction Temperature 150 ℃ Tstg Storage Temperature -55-150 ℃ ELECTRICAL CHARACTERISTICS (Tamb=25℃ unless otherwise specified) Parameter Symbol Collector-base breakdown voltage BC337 BC338 Collector-emitter breakdown voltage BC337 BC338 Emitter-base breakdown voltage Collector cut-off current BC337 BC338 Collector cut-off current BC337 BC338 Emitter cut-off current BC337/BC338 BC337-16/BC338-16 BC337-25/BC338-25 BC337-40/BC338-40 DC current gain Collector-emitter saturation voltage Base-emitter saturation voltage VCBO conditions MIN IC= 10mA , VEBO ICBO ICEO IEBO hFE(1) hFE(2) VCE(sat) VBE(sat) VBE Transition frequency fT Collector Output Capacitance Cob ht t p : // TYP MAX UNIT IC= 100uA, IE=0 50 30 V V 45 25 5 V V V IB=0 VCEO Base-emitter voltage Revision:20170701-P1 Test IE= 10uA, IC=0 VCB= 45V, IE=0 VCB= 25V, IE=0 VCE= 40V, IB=0 VCE= 20V, IB=0 VEB= 4 V, IC=0 VCE=1V, IC= 100mA VCE=1V, IC= 300mA IC=500mA, IB= 50mA IC= 500mA, IB=50mA 100 100 160 250 60 VCE=1V, IC= 300mA VCE= 5V, IC= 10mA f = 100MHz VCB=10V,IE=0 f=1MHZ www.lgesem i .c o m 210 0.1 0.1 0.2 0.2 0.1 630 250 400 630 uA 0.7 1.2 V V 1.2 V uA uA MHz 15 pF mail:lge@lgesemi.com BC337/338(NPN) TO-92 Bipolar Transistors Typical Characteristics Revision:20170701-P1 ht t p : // www.lgesem i .c o m mail:lge@lgesemi.com BC337/338(NPN) TO-92 Bipolar Transistors Revision:20170701-P1 ht t p : // www.lgesem i .c o m mail:lge@lgesemi.com
BC337-25 价格&库存
很抱歉,暂时无法提供与“BC337-25”相匹配的价格&库存,您可以联系我们找货
BC337-25
    • 10+0.36980
    • 100+0.30122
    • 300+0.26687
    • 1000+0.21050
    • 5000+0.18987
    • 10000+0.17961
    库存:16484
    BC337-25
      • 1+0.09750
      • 100+0.09100
      • 300+0.08450
      • 500+0.07800
      • 2000+0.07475
      • 5000+0.07280
      BC337-25
      • 1+0.19470
      • 50+0.09735
      • 1000+0.07370
      库存:10265
