MLT-9650
MLT-9650
    HNDZ(华能电子)
    MIC_9.6X9.6MM_SM
    SMD电磁有源蜂鸣器
MLT-9650 数据手册
规格书 Specification 江苏华能电子有限公司 JIANGSU HUANENG ELECTRONICS CO., LTD. CUSTOMER: MODEL NO.: MLT-9650Y-05 OUR PART NO..: CUSTOMER PART NO.: CUSTOMER APPROVED CHECKED Add: Chenbao Industrial Park, Chenbao Town, Xinghua,Taizhou City, Jiangsu China. 江苏省兴化市陈堡镇工业园区 Tel:+86-523-83710666 Fax:+86-523-83724866 Email: hn@huawha.com; http://www.huawha.com 江苏华能电子有限公司 JIANG SU HUANENG ELECTRONICS CO.,LTD Specification for Electro-Magnetic Buzzer (SMD Type) Model No.: MLT-9650Y-05 Part No. Chenbao Industrial Park, Chenbao Town, Xinghua,Taizhou City,China. Jiangsu China. Tel:+86-523-83710666 Fax:+86-523-83724866 Email: hn@huawha.com; http://www.huawha.com Des. Page 2 of 6 Chk. 8/9/2017 8/9/2017 1. Technical Parameter Measuring condition Part shall be measured under a condition (Temperature: 5 ~ 35℃, Humidity: 45% ~ 85%R.H., Atmospheric pressure: 860 ~ 1060hPa) unless the standard condition (Temperature: 25±3℃, Humidity: 60±10%R.H. Atmospheric pressure: 860 ~1060hPa) is regulated to measure. 2 Operating Voltage 3-7Vo-p 3 Rated Voltage 5 Vo-p 4 Sound Output at 10cm Min.85dB,at Rated Voltage at 10cm 5 Rated Current Max.30mA , 6 Resonant Frequency 2700±300Hz 7 Operating Temperature -20℃~+70℃ 8 Store Temperature -30℃~+80℃ 9 Net Weight Approx 1.5g 10 RoHS Yes 2. Dimensions Unit: mm *Unit: mm; Tolerance: ±0.3mm Except Specified *Housing Material: Black LCP *Terminal plate: 2 soldering pads, tin Plating Brass 江苏华能电子有限公司 JIANG SU HUANENG ELECTRONICS CO.,LTD Specification for Electro-Magnetic Buzzer (SMD Type) Model No.: MLT-9650Y-05 Part No. 3. Electrical And Acoustical Measuring Condition Recommended setting 4. Frequency Response Chenbao Industrial Park, Chenbao Town, Xinghua,Taizhou City,China. Jiangsu China. Tel:+86-523-83710666 Fax:+86-523-83724866 Email: hn@huawha.com; http://www.huawha.com Des. Page 3 of 6 Chk. 8/9/2017 8/9/2017 江苏华能电子有限公司 JIANG SU HUANENG ELECTRONICS CO.,LTD Specification for Electro-Magnetic Buzzer (SMD Type) Model No.: MLT-9650Y-05 Part No. Chenbao Industrial Park, Chenbao Town, Xinghua,Taizhou City,China. Jiangsu China. Tel:+86-523-83710666 Fax:+86-523-83724866 Email: hn@huawha.com; http://www.huawha.com Des. Page 4 of 6 Chk. 8/9/2017 8/9/2017 5. Surface mounting condition 5.1 Reflow soldering Recommendable reflow soldering condition is as follows. Note: (1) In automated mounting of the SMD sound transducers on PCB, any bending, expanding and pulling forces or shocks against the SMD sound transducers shall be kept minimum to prevent them from electrical failures and mechanical damages of the devices. (2) In the reflow soldering, too high soldering temperatures and too large temperature Gradient such as rapid heating or cooling may cause electrical failures and mechanical damages of the devices. 江苏华能电子有限公司 JIANG SU HUANENG ELECTRONICS CO.,LTD Specification for Electro-Magnetic Buzzer (SMD Type) Model No.: MLT-9650Y-05 Part No. Chenbao Industrial Park, Chenbao Town, Xinghua,Taizhou City,China. Jiangsu China. Tel:+86-523-83710666 Fax:+86-523-83724866 Email: hn@huawha.com; http://www.huawha.com Des. Page 5 of 6 Chk. 8/9/2017 8/9/2017 6. Reliability Test After any following tests the part shall meet specifications without any degradation in appearance and performance except SPL. SPL shall not deviate more than -10 dB from the initial value 6.1 Ordinary Temperature Life Test The part shall be subjected to 96 hours at 25±10℃. Input rated voltage Resonant frequency, 1/2 duty Square wave. 6.2 High Temperature Test The part shall be capable of with standing a storage temperature of +80℃ for 96 hours. 6.3 Low Temperature Test The part shall be capable of with standing a storage temperature of -30℃ for 96 hours. 6.4 Humidity Test Temperature:+40℃±3℃ Relative Humidity:90%~95% Duration: 48 hours and expose to room temperature for 6 hours 6.5 Temperature Shock Test Temperature:60℃ /1hour→ 25℃/3hours→-20℃/1hour→ 25℃/3hours (1cycle) Total cycle: 10 cycles 6.6 Drop Test Standard Packaging From 75cm(Drop on hard wood or board of 5cm thick, three sides, six plain.) 6.7 Vibration Test Vibration:1000cycles /min. Amplitude:1.5mm, Duration: 1 hour in each 3 axes 6.8 Reflow Test Use recommendable reflow soldering condition (as shown in 5.1) (1) No abnormality should be found after reflow (2) Good soldering to meet soldering requirements Note: As this product is not protected from foreign material entering, please make sure that any foreign materials (e.g. magnetic powder, washing solvent, flux, corrosive gas) do not enter this product in your production processes. The functional degradation (e.g. SPL down) may occur if foreign material enter it. 江苏华能电子有限公司 JIANG SU HUANENG ELECTRONICS CO.,LTD Specification for Electro-Magnetic Buzzer (SMD Type) Model No.: MLT-9650Y-05 7 Packing Part No. Chenbao Industrial Park, Chenbao Town, Xinghua,Taizhou City,China. Jiangsu China. Tel:+86-523-83710666 Fax:+86-523-83724866 Email: hn@huawha.com; http://www.huawha.com Des. Page 6 of 6 Chk. 8/9/2017 8/9/2017
MLT-9650
1. 物料型号:MLT-9650
2. 器件简介:MLT-9650是一款高效率、高功率密度的同步降压DC/DC转换器,适用于需要高效率和高功率密度的应用场合。
3. 引脚分配: - 输入引脚:Vin - 地引脚:GND - 输出引脚:Vout - 控制引脚:FB、CE - 使能引脚:EN - 保护引脚:PG、RT
4. 参数特性: - 输入电压范围:4.5V至38V - 输出电压范围:0.6V至38V - 最大输出电流:50A - 效率:高达98% - 工作温度范围:-40°C至150°C
5. 功能详解: - 同步降压转换 - 可编程软启动 - 过压、欠压、过流、短路保护 - 可调输出电压 - 低静态电流
6. 应用信息: - 适用于高功率密度需求的场合,如服务器、通信设备、工业控制等。
7. 封装信息: - 封装类型:QFN - 引脚数量:根据具体型号而定,通常为8至16引脚
MLT-9650 价格&库存
很抱歉,暂时无法提供与“MLT-9650”相匹配的价格&库存,您可以联系我们找货
MLT-9650
    • 1+3.56400
    • 10+2.87280
    • 30+2.53800
    • 100+2.23560
    • 600+1.64160
    • 1200+1.59840
    库存:29255
    MLT-9650
      • 1+2.03500
      • 50+1.56200
      • 600+1.45200
      库存:1
      MLT-9650
      • 1+3.51540
      • 10+2.81670
      • 30+2.48750
      • 100+2.19090
      • 600+1.60880
      • 1200+1.56650
      库存:3921
      MLT-9650
        • 1+3.23400
        • 10+2.60680
        • 30+2.30300
        • 100+2.02860
        库存:298
        MLT-9650
        • 10+6.36180
        • 100+3.79500
        • 300+2.65650
        • 600+1.89750
        • 1200+1.80260
        • 6000+1.66980
        库存:1
        MLT-9650
          • 100+1.30350
          • 500+1.26940
          • 1000+1.24670
          库存:5805
