LC3304EP8
LC3304EP8
    LEIDITECH(雷卯电子)
    SOP-8
    ESD保护 VRWM=3.3 V VBR(Min)=3.5 V VC=18 V IPP=25 A Ppp=450 W SOP8
LC3304EP8 数据手册
LC3304EP8 Ultra Low Capacitance Bi-Directional TVS Diode Array Features ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 2.8V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 30A (8/20μs) RoHS Compliant Dimensions SOP-08 Pin Configuration Applications  Base Station  Analog Inputs  Switch Systems  10/100/1000 Ethernet  WAN/LAN Equipment  Desktops, Servers, and Notebooks  Low Voltage Interfaces Mechanical Characteristics ● Package: SOP-08 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3,000pcs ● Reel Size:7 inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp VESD Value Unit 600 W ± 30 Kv ± 30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2018 1/3 www.leiditech.com LC3304EP8 Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number Device Marking VRWM (V) VBR (V) IT (mA) 2.8-4 2.8 3 1 LC3304EP8 VC @2A (Max) 5 21 (@A) IR μA (Max) C (Pf) (Typ.) 1 2 30 Characteristic Curves Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) Fig1. 8/20µ s Pulse Waveform 120 IPP - Peak Pulse Current - % of IPP 100 100% TEST WAVEFORM PARAMETERS tr=8 s td=20 s Peak Value IPP 80 Percent of Peak Pulse Current % tr 60 40 td=t IPP/2 20 0 0 5 10 15 20 25 10% tr = 0.7~1ns Time (ns) 30ns 30 60ns t - Time ( s) Fig3. 90% Power Derating Curve % of Rated Power 110 100 90 80 70 60 50 40 30 20 10 0 0 25 50 75 100 125 150 Ambient Temperature –TA (ºC) Rev : 01.06.2018 2/3 www.leiditech.com LC3304EP8 SOP-08 Mechanical Data Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2018 3/3 www.leiditech.com
LC3304EP8 价格&库存
很抱歉,暂时无法提供与“LC3304EP8”相匹配的价格&库存,您可以联系我们找货
