LC2504P8
LC2504P8
    LEIDITECH(雷卯电子)
    DFN10_26X2.6MM_EP
    ESD保护 VRWM=2.5 V VBR(Min)=2.7 V VC=10.5 V IPP=10 A Ppp=450 W DFN10_26X2.6MM_EP
LC2504P8 数据手册
LC2504P8 4-Line Ultra Low Capacitance TVS Diode Array Features ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 2.5V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±25kV Contact discharge: ±15kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 5A (8/20μs) RoHS Compliant Dimensions DFN2626-10 Pin Configuration Applications ● ● ● ● ● ● USB 2.0 power and data line Set-top box and digital TV Digital video interface (DVI) Notebook Computers SIM Ports 10/100 Ethernet Mechanical Characteristics ● Package: DFN2626-10 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3,000pcs ● Reel Size:7inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value Unit 450 W ±25 VESD Kv ±15 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2014 1/3 www.leiditech.com LC2504P8 Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number LC2504P8 Device Marking 2504N VRWM (V) VBR (V) IT (mA) VC @1A 2.5 2.7 1 4.5 (Max) 10.5 (@A) IR μA (Max) C (Pf) (Typ.) 0.5 3.8 10 Characteristic Curves Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) Fig1. 8/20µ s Pulse Waveform 120 IPP - Peak Pulse Current - % of IPP 100 100% TEST WAVEFORM PARAMETERS tr=8 s td=20 s Peak Value IPP 80 Percent of Peak Pulse Current % tr 60 40 td=t IPP/2 20 0 0 5 10 15 20 25 10% tr = 0.7~1ns Time (ns) 30ns 30 60ns t - Time ( s) Fig3. 90% Power Derating Curve % of Rated Power 110 100 90 80 70 60 50 40 30 20 10 0 0 25 50 75 100 125 150 Ambient Temperature –TA (ºC) Rev : 01.06.2014 2/3 www.leiditech.com LC2504P8 DFN2626-10 Package Outline Drawing A B D DIM PIN 1 INDICATOR E A SEATING PLANE aaa C A2 D1 C A1 A A1 A2 b D D1 E E1 e L N aaa bbb DIMENSIONS INCHES MILLIMETERS MIN NOM MAX MIN NOM MAX .020 .022 .024 0.50 0.55 0.60 .000 .001 .002 0.00 0.03 0.05 (.007) (0.17) .007 .010 .012 0.20 0.25 0.30 .098 .102 .106 2.50 2.60 2.70 .079 .085 .089 2.00 2.15 2.25 .098 .102 .106 2.50 2.60 2.70 .044 .050 .054 1.11 1.26 1.36 .020 BSC 0.50 BSC .011 .014 .016 0.30 0.35 0.40 10 10 .003 0.08 .004 0.10 1 2 E/2 E1 e LxN N bxN bbb D/2 NOTES: 1. 2. C A B CONTROLLING DIMENSIONS ARE IN MILLIMETERS (ANGLES IN DEGREES). COPLANARITY APPLIES TO THE EXPOSED PAD AS WELL AS THE TERMINALS. Suggested Land Pattern X P Z F G (C) DIM B C F G P X Y Z DIMENSIONS INCHES MILLIMETERS .081 2.05 .100 2.50 1.26 .050 .073 1.85 .020 0.50 .012 0.30 .025 0.65 .124 3.15 Y B NOTES: 1. THIS LAND PATTERN IS FOR REFERENCE PURPOSES ONLY. CONSULT YOUR MANUFACTURING GROUP TO ENSURE YOUR COMPANY'S MANUFACTURING GUIDELINES ARE MET. Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2014 3/3 www.leiditech.com
LC2504P8 价格&库存
很抱歉,暂时无法提供与“LC2504P8”相匹配的价格&库存,您可以联系我们找货
