LC0564ST6
LC0564ST6
    LEIDITECH(雷卯电子)
    SOT26
    SOT26-6 225W 5V
LC0564ST6 数据手册
LC0564ST6 LOW CAPACITANCE TVS DIODE ARRAY Features  225 Watts Peak Pulse Power per Line (tp=8/20µs)  Protects Four Unidirectional I/O line Dimensions SOT-6  Low Clamping Voltage  Working Voltages : 5V  Low Leakage Current  IEC61000-4-2 (ESD) ±25kV (air), ±15kV (contact)  IEC61000-4-4 (EFT) 40A (5/50ηs)  IEC61000-4-5 (LIGHTING) 9A (8/20μs) Applications  Ethernet - 10/100/1000 Base T Pin Configuration  Cellular Phones  I2C Bus Protection  Parallel & Serial Port Protection  Personal Digital Assistant (PDA)   Microcontroller Input Protection  WAN/LAN Equipment ISDN S/T Interface Mechanical Characteristics  SOT-26 Package  Molding Compound Flammability Rating : UL 94V-O  Weight 16 Millgrams (Approximate)  Quantity Per Reel : 3,000pcs  Reel Size : 7 inch  Lead Finish : Lead Free Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value Unit 225 W ±25 VESD Kv ±15 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2018 1/7 www.leiditech.com LC0564ST6 Electrical Characteristics(TA=25°C unless otherwise specified) PART NUMBER DEVICE MARKING VRWM VB (V) (V) (max.) (min.) VC IT (IO to GND) @1A (mA) (I/O to GND) (max.) (max.) (@A) 8.5 20 9 VC LC0564ST6 Rev : 01.06.2018 56D 5 6 1 2/7 IR VC (pF) (max.) (typ.) 1.2 CT 1 (I/O to I/O) @1A (I/O to GND) (µA) VC (IO to I/O) CT (I/O to I/O) (pF) (max.) (max.) (@A) (typ.) 9.8 25 9 2.5 www.leiditech.com LC0564ST6 TYPIC CHARACTERISTICS Figure 2. Power Derating Curve Figure 1. 8 x 20μs Waveform Figure 3. Clamping Voltage vs. Peak Pulse Current (tp=8/20us) Rev : 01.06.2018 3/7 www.leiditech.com LC0564ST6 TYPIC CHARACTERISTICS Figure 4. Typic Capacitance vs. Reverse Voltage Figure 5. Typic Reverse Leakage vs. Temperature Rev : 01.06.2018 4/7 www.leiditech.com LC0564ST6 TYPIC CHARACTERISTICS Figure 6. Typic Breakdown Voltage vs. Temperature Rev : 01.06.2018 5/7 www.leiditech.com LC0564ST6 APPLICATION INFORMATION Gigabit Ethernet Protection Circuit Rev : 01.06.2018 6/7 www.leiditech.com LC0564ST6 SOT-26 Package Outline & Dimensions * SOLDERING FOOTPRINT Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2018 7/7 www.leiditech.com
LC0564ST6 价格&库存
很抱歉,暂时无法提供与“LC0564ST6”相匹配的价格&库存,您可以联系我们找货
LC0564ST6
