LC0504W
LC0504W
    LEIDITECH(雷卯电子)
    SOT26
    SOT26-6 60W 5V
LC0504W 数据手册
LC0504W Features ● ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 5V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Contact discharge: ±12kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 3.5A (8/20 μs) RoHS Compliant Dimensions SOT-26 AEC -Q101 qualified. Pin Configuration Applications ● ● ● ● ● ● USB 2.0 power and data line Set-top box and digital TV Digital video interface (DVI) Notebook Computers SIM Ports 10/100/1000 Ethernet Pin 5 P in 1 Package: SOT-26 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3,000pcs ● Reel Size:7inch Pin 6 Pin 2 Mechanical Characteristics ● Pin 4 Pin 3 GND Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Value Ppp 60 Unit W ±15 VESD Kv ±12 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2018 1/4 www.leiditech.com LC0504W Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number Device Marking VRWM (V) VBR (V) IT (mA) VC @1A V5V 5 6 1 - LC0504W Rev : 01.06.2018 2/4 (Max) 12 (@A) 3.5 IR nA (Max) 50 C (Pf) (Typ.) 0.35 www.leiditech.com LC0504W Characteristic Curves Fig.1 Peak Pulse Power RatingCurve Fig.2 Pulse DeratingCurve Percent of Rated Power for Ipp Peak Pulse Power –PPP (KW) 10 1 60w 8/20μs waveform 0.1 0.01 0.1 1 10 100 Pulse Duration tp (μs) 60 40 20 0 0 100%IPP , 8μS 150 100% 90% 50%IPP, 20μS e-t 60 Percent of IPP 30ns 80 40 20 0 25 50 75 100 1 Ambient Temperature—TA(℃) Fig.4 PulseWaveform-ESD(IEC61000-4-2) 100 Percent of IPP 80 1000 Fig.3 PulseWaveform-8/20μs 120 110 100 60ns 10% 0 5 10 15 20 25 30 tr 0.7 to 1ns 0 30 Time (μs) 60 Time (ns) Fig.5 Eye Diagram - HDMI mask at 5.0Gbpsper channel Fig.6 Insertion Loss S21 - I/O toGND 2 3.2GHz @ -1dB Horizontal: 50 ps/div Vertical: 200 mV/div Insertion Loss (dB) 0 -2 -4 5GHz @ -3dB -6 -8 -10 100k 1M 10M 100M 1G 10G Frequency (Hz) Rev : 01.06.2018 3/4 www.leiditech.com LC0504W DIMENSIONS PACKAGE OUTLINE SYMBOL E E1 b SEE DETAIL A e1 D 0.2 A 0.041 0.049 1.050 1.250 0.000 0.004 0.000 0.100 A2 0.041 0.045 1.050 1.150 D 0.111 0.119 2.820 3.020 E 0.059 0.067 1.500 1.700 E1 0.104 0.116 2.650 2.950 b 0.012 0.020 0.300 0.500 A 0.037(BSC) 0.950(BSC) e1 0.071 0.079 1.800 2.000 L 0.012 0.024 0.300 0.600 θ 0o 8o 0o 8o θ A2 MILLIMETER MIN MAX A1 e e INCHES MAX MIN c L A1 1.0 0.039 1.4 3.6 0.055 0.141 1.9 0.074 0.7 0.028 0.95 0.037 Notes 1. This land pattern is for reference purposes only consult your manufacturing group to ensure your company's manufacturing guidelines are met. Reference ipc-sm-782a.. Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2018 4/4 www.leiditech.com
LC0504W 价格&库存
很抱歉,暂时无法提供与“LC0504W”相匹配的价格&库存,您可以联系我们找货
LC0504W
