LC03-6
LC03-6
    LEIDITECH(雷卯电子)
    SO-8
    ESD保护 VRWM=6 V VBR(Min)=6.8 V VC=20 V IPP=100 A Ppp=2 KW SO8
LC03-6 数据手册
LC03-6 Low Capacitance TVS Features ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 6V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Contact discharge: ±8kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 100A (8/20μs) RoHS Compliant Dimensions SO-8 Pin Configuration Applications ● ● ● ● ● ● USB 2.0 power and data line Set-top box and digital TV Digital video interface (DVI) Notebook Computers SIM Ports 10/100 Ethernet Mechanical Characteristics ● Package: SO-8 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:500pcs ● Reel Size:7 inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp VESD Value 2000 ± 15 Unit W Kv ± 8 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2018 1/4 www.leiditech.com LC03-6 Electrical Characteristics(TA=25°C unless otherwise specified) Vc Part Number Device Marking VRWM (V) VBR (V) IT (mA) VC @50A LC-6 6 6.7 1 15 LC03-6 Rev : 01.06.2018 2/4 (Max) 20 (@A) 100 IR μA (Max) C (Pf) (Typ.) 5 8 www.leiditech.com LC03-6 Typical Characteristics Figure 2: Power Derating Curve 100 Percent of Rated Power for Ipp Ppp – Peak Pulse Power - Ppp(KW) Figure 1: Peak Pulse Power vs. Pulse Time 10 2000w 8/20µs Waveform 1 110 100 90 80 70 60 50 40 30 20 10 0 0.1 0.1 1 10 100 1,000 0 25 td – Pulse Duration - µs tr=8µs Waveform Paramters tr=8µs td=20µs 90 22 Clamping Voltage–VC (V) 100 Percent Ipp 100 125 80 70 60 50 40 Half Value Ipp/2 30 td=20µs Line to Line 20 18 16 Line to Ground 14 12 10 10 8 Test Waveform Parameters tr=8µs td=20µs 6 4 2 0 0 5 10 15 20 25 0 30 10 0 Time (µs) 20 30 40 50 60 90 100 110 Figure 6: Forward Voltage vs. Forward Current 1.1 8 1.0 F=1MHz 7 Forward Voltage–VF(V) 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 6 5 4 3 Test Waveform Paramters tr=8µs td=20µs 2 1 0.1 0 0 2 4 6 8 10 0 Reverse Voltage -VR(V) Rev : 01.06.2018 80 70 Peak Pulse Current–IPP (A) Figure 5: Capacitance vs. Reverse Voltage 0 150 24 110 Cj(VR)/Cj(VR=0) 75 Figure 4: Clamping Voltage vs. Peak Pulse Current Figure3: Pulse Waveform 20 50 Ambient Temperature - TA (℃) 10 20 30 40 50 60 70 80 90 100 Forward Current–IF(A) 3/4 www.leiditech.com LC03-6 SO-08 Package Outline & Dimensions PACKAGE OUTLINE A D e N DIMENSIONS 2X E/2 E1 SEE DETAIL A E SIDE VIEW 1 2X DIM h e/2 H B h NOM MAX MIN NOM A .053 - .069 1.35 - 1.75 A1 .004 - .009 0.10 - 0.225 A2 .051 - .060 1.30 - 1.50 b .015 - .019 0.39 - 0.48 c .008 - .010 0.21 - 0.26 D .185 .193 .201 4.70 4.90 5.10 E1 .146 .154 .161 3.70 3.90 4.10 D aaa C A2 A SEATING PLANE c GAGE PLANE 0.25 L A1 C (L1) bxN bbb bbb M C A-B D θ1 MILLIMETERS MIN 2 ccc C N/2 TIPS INCHES E DETAIL A .236BSC e MAX 6.00BSC .050 BSC 1.27 BSC h .010 - .020 0.25 - 0.50 L .020 .028 .031 0.50 0.72 0.80 1. Controlling Dimensions Are In Millimeters (Angles In Degrees). θ1 0° - 8° 0° - 8° 2. Datums -A- And -B- To Be Determined At Datum Plane -H- . L1 N 8 8 3. Dimensions “E1” And “D” Do Not Include Mold Flash,Protrusions Or Gate Burrs. aaa .004 0.10 4. Reference JEDEC STD MS-012,VARITION AA. bbb .010 0.25 ccc .008 0.20 NOTES: (C) G Y P Z (1.04) Notes DIMENSIONS X (.041) DIM INCHES MILLIMETERS C (.205) G .118 3.00 P .050 1.27 X .024 0.60 Y .087 2.20 Z .291 7.40 1. This Land Pattern Is For Reference Purposes Only.Consult Your Manufacturing Group To Ensure Your Company's Manufacturing (5.20) Guidelines Are Met. 2. Reference IPC-SM-782A, RLP NO. 300A. Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2018 4/4 www.leiditech.com
LC03-6 价格&库存
很抱歉,暂时无法提供与“LC03-6”相匹配的价格&库存,您可以联系我们找货
