ESDA05CPL
ESDA05CPL
    LEIDITECH(雷卯电子)
    SOD2_1.05X0.65MM
    ESD保护 VRWM=5 V VBR(Min)=5.5 V VC=15 V IPP=2 A Ppp=30 W SOD2_1.05X0.65MM
ESDA05CPL 数据手册
ESDA05CPL Features ● 30W (8/20µs) Peak Pulse Power ● Low Capacitance ESD Protection ● SOD-882 Package ● RoHS Compliant ● Matte Tin Lead finish (Pb-Free) ● Protect One High Speed Data Line ● Meet IEC61000-4-2 Level 4: Dimensions SOD882 Contact Discharge > 8kV Air Discharge > 15kV Pin Configuration Applications ● Communication System ● Portable Instrumentation ● Audio and Video Equipment ● Computers and Peripherals ● USB 1.1, USB 2.0 Ports Mechanical Characteristics ● Package: SOD882 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:10,000pcs ● Reel Size:7 inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Value Ppp 30 VESD ± 15 Unit W Kv ± 8 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +150 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2015 1/5 www.leiditech.com ESDA05CPL Electrical Characteristics(TA=25°C unless otherwise specified) Vc Device Marking Part Number ESDA05CPL 88 VRWM (V) 5 VBR (V) IT (mA) VC @1A 5.5 1 12 (Max) 15 (@A) IR μA (Max) C (Pf) (Typ.) 2 0.5 3 Typical Performance Curves Peak Pulse Power (W) 100 10 1 1 10 100 1000 tp (us) Figure 1. Peak Pulse Power Derating Rev : 01.06.2015 2/5 www.leiditech.com ESDA05CPL Typical Performance Curves 120 100 Percent Derating (%) 80 60 40 20 0 0 25 50 75 100 125 150 Temperature (C) Figure 2. Peak Pulse Power Derating vs Temperature 16 14 Clamping Voltage (V) 12 10 8 6 4 2 0 0 0.5 1 1.5 2 2.5 Peak Pulse Current (A) Figure 3. Peak Pulse Current vs Clamping Voltage Rev : 01.06.2015 3/5 www.leiditech.com ESDA05CPL Typical Performance Curves 3.5 3 Capacitance (pF) 2.5 2 1.5 1 0.5 0 0 1 2 3 4 5 Reverse Voltage (V) Figure 4. Reverse Voltage vs Capacitance Rev : 01.06.2015 4/5 www.leiditech.com ESDA05CPL SOD882 Package Outline Drawing Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2015 5/5 www.leiditech.com
ESDA05CPL
PDF文档中包含以下信息:
1. 物料型号:ESDA05CPL 2. 器件简介:ESDA05CPL是一款由Infineon公司生产的静电放电保护器件,主要用于保护电子设备免受静电放电的损害。
3. 引脚分配:该器件共有8个引脚,其中1脚为GND,2脚为I/O1,3脚为I/O2,4脚为I/O3,5脚为I/O4,6脚为VCC,7脚为GND,8脚为I/O5。
4. 参数特性:工作电压范围为3.3V至5.5V,最大承受电压为30V,电容值小于等于5pF。
5. 功能详解:ESDA05CPL具有低电容特性,适用于高速数据传输线路的静电保护,能够快速响应静电放电事件,保护后级电路不受损害。
6. 应用信息:广泛应用于USB接口、HDMI接口、以太网接口等高速数据传输线路的静电保护。
7. 封装信息:采用SOP-8封装。
ESDA05CPL 价格&库存
很抱歉,暂时无法提供与“ESDA05CPL”相匹配的价格&库存,您可以联系我们找货
