ESD9L5V
ESD9L5V
    LEIDITECH(雷卯电子)
    SOD2_0.8X0.6MM
    ESD保护 VRWM=5 V VBR(Min)=5.4 V VC=19.8 V IPP=3 A Ppp=350 W SOD2_0.8X0.6MM
ESD9L5V 数据手册
ESD9L5V Ultra Low Capacitance Uni-Directional TVS Diode Features ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 5.0V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Contact discharge: ±10kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 12A (8/20μs) RoHS Compliant Dimensions SOD-923 Pin Configuration Applications ● ● ● ● ● ● USB 2.0 power and data line Set-top box and digital TV Digital video interface (DVI) Notebook Computers SIM Ports 10/100 Ethernet Mechanical Characteristics ● Package: SOD-923 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:8,000pcs ● Reel Size:7 inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) ESD per IEC 61000−4−2 (Contact) Symbol Ppp VESD Value Unit 350 W ± 15 Kv ± 10 Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2014 1/3 www.leiditech.com ESD9L5V Electrical Characteristics(TA=25°C unless otherwise specified) Part Number Device Marking VRWM (V) VBR (V) IT (mA) VC @1A D 5.0 5.4 1 9.8 ESD9L5V Vc (Max) (@A) 19.8 IR μA (Max) C (Pf) (Typ.) 1 0.5 3 Characteristic Curves Fig1. Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) 8/20µ s Pulse Waveform tr 100 100% TEST WAVEFORM PARAMETERS tr=8 s td=20 s Peak Value IPP 80 Percent of Peak Pulse Current % IPP - Peak Pulse Current - % of IPP 120 60 40 td=t IPP/2 20 0 0 5 10 15 20 25 10% tr = 0.7~1ns Time (ns) 30ns 30 60ns t - Time ( s) Fig3. 90% Power Derating Curve % of Rated Power 110 100 90 80 70 60 50 40 30 20 10 0 0 25 50 75 100 125 150 Ambient Temperature –TA (ºC) Rev : 01.06.2014 2/3 www.leiditech.com ESD9L5V SOD-923 Mechanical Data Soldering Footprint Dimensions: Millimeters Millimeters Dim Inches Min Nom Max Min Nom Max A 0.36 0.40 0.43 0.014 0.016 0.017 b 0.15 0.20 0.25 0.006 0.008 0.010 c 0.07 0.12 0.17 0.003 0.005 0.007 D 0.75 0.80 0.85 0.030 0.031 0.033 E 0.55 0.60 0.65 0.022 0.024 0.026 HE 0.95 1.00 1.05 0.037 0.039 0.041 L 0.05 0.10 0.15 0.002 0.004 0.006 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2014 3/3 www.leiditech.com
ESD9L5V
物料型号为ESD9L5V,是Leiditech公司生产的超低电容单向TVS二极管。
器件简介包括超低漏电流(纳安级别)、工作电压5.0V、低钳位电压,符合IEC 61000-4-2(ESD)、IEC61000-4-4(EFT)、IEC61000-4-5(Lightning)等标准,并且符合RoHS标准。
引脚分配为阴极、阳极,封装信息为SOD-923,无铅引脚,UL可燃性分类等级94V-0,每卷8000颗,卷径7英寸。
参数特性包括峰值脉冲功率350W(8/20us),ESD±15kV(空气放电)、±10kV(接触放电),工作温度范围-55至+125°C,存储温度范围-55至+150°C。
功能详解为USB 2.0电源和数据线、机顶盒和数字电视、数字视频接口(DVI)、笔记本电脑、SIM卡端口、10/100以太网等应用。
电气特性在25°C下,工作电压(VRWM)为5.0V,击穿电压(VBR)为5.4V,漏电流(Ir)为1mA,1A时的钳位电压(Vc@1A)为9.8V,最大漏电流(IR)为3A,电容(C)典型值为0.5pF。
特性曲线包括8/20us脉冲波形图、IEC 61000-4-2标准ESD脉冲波形图,以及功率降额曲线。
SOD-923封装的机械数据也给出了详细的尺寸信息。
ESD9L5V 价格&库存
很抱歉,暂时无法提供与“ESD9L5V”相匹配的价格&库存,您可以联系我们找货
