ESD5Z3L
ESD5Z3L
    LEIDITECH(雷卯电子)
    SOD-523(SC-79)
    SOD-523 100W 3.3V
ESD5Z3L 数据手册
ESD5Z3L Ultra Low Capacitance Uni-Directional TVS Diode Array Features  Ultra low capacitance: 0.6pF typical  Ultra low leakage: nA level  Operating voltage: 3.3V  Low clamping voltage  Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±25kV Contact discharge: ±20kV – IEC61000-4-5 (Lightning) 6A (8/20μs)  RoHS Compliant Dimensions SOD-523 Pin Configuration Applications  Cellular Handsets and Accessories  Display Ports  MDDI Ports  USB Ports  Digital Visual Interface (DVI)  PCI Express and Serial SATA Ports Mechanical Characteristics ● Package: SOD-523 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3,000pcs ● Reel Size:7 inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp VESD Value Unit 100 W ± 25 Kv ± 20 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2017 1/4 www.leiditech.com ESD5Z3L Electrical Characteristics(TA=25°C unless otherwise specified) Part Number Device Marking ESD5Z3L Rev : 01.06.2017 36 VRWM (V) 3.3 VBR (V) 4.2 IT (mA) VC @1A 1 9 2/4 Vc (Max) 16 (@A) 6 IR μA (Max) 0.2 C (Pf) (Typ.) 0.6 www.leiditech.com ESD5Z3L Typical Performance Characteristics (TA=25°C unless otherwise Specified) Junction Capacitance vs. Reverse Voltage Peak Pulse Power vs. Pulse Time Clamping Voltage vs. Peak Pulse Current Power Derating Curve Note:Data is taken with a 10x attenuator ESD Clamping Voltage 8 X 20μs Pulse Waveform Rev : 01.06.2017 8 kV Contact per IEC61000−4−2 3/4 www.leiditech.com ESD5Z3L SOD-523 Package Outline & Dimensions Millimeters Inches Symbol Soldering Footprint Min. Nom. Max. Min. Nom. Max. A 1.10 1.20 1.30 0.043 0.047 0.051 B 0.70 0.80 0.90 0.028 0.032 0.035 C 0.50 0.60 0.70 0.020 0.024 0.028 D 0.25 0.30 0.35 0.010 0.012 0.014 J 0.07 0.14 0.20 0.0028 0.0055 0.0079 K 0.15 0.20 0.25 0.006 0.008 0.010 L 1.50 1.60 1.70 0.059 0.063 0.067 Symbol Millimeters Inches E 1.40 0.0547 F 0.40 0.0157 G 0.40 0.0157 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2017 4/4 www.leiditech.com
ESD5Z3L 价格&库存
很抱歉,暂时无法提供与“ESD5Z3L”相匹配的价格&库存,您可以联系我们找货
ESD5Z3L
