ESD0506M8
6-Line Low Capacitance TVS Diode Array
Description
Mechanical Characteristics
The ESD0506M8 is a low capacitance TVS array, utiliz ing
leading monolithic silicon technology to provide fast response time and low ESD clamping voltage, making this
device an ideal solution for protecting voltage sensitive
high-speed data lines. The ESD0506M8 has low capacitance with a typical value at 8pF, and complies with the
IEC 61000-4-2 (ESD) standard with ±15kV air and ±8kV
contact discharge. It is assembled into a 8-pin lead-free
SO-8 package. The combination of small size, low capacitance and high level of ESD protection makes it ideal
for cellular, notebooks, desktops, and other portable application.
Package: TSSOP-8
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
Marking Information: See Below
Features
Low capacitance: 8pF typical (I/O to GND)
Ultra low leakage: nA level
Low operating voltage: 5V
Low clamping voltage
Up to 6 lines protects
JEDEC TTSOP-8 package
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±15kV
Contact discharge: ±8kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
Applications
Cellular Handsets and Accessories
Personal Digital Assistants
Notebooks and Handhelds
Portable Instrumentation
Digital Cameras
Peripherals
Audio Players
Keypads, Side Keys, LCD Displays
Marking Information
5V06U
01 03
548
Dot indicates pin1
5V06U= device marking code
RoHS Compliant
Dimensions and Pin Configuration
8
8
7
6
7
6
Ordering Information
5
Part Number
5
Packaging
Reel Size
ESD0506M8 2500/Tape & Reel
1
2
3
4
1
Circuit Schematic
Rev : 01.06.2014
13 inch
2
3
4
Pin Schematic
1/4
www.leiditech.com
ESD0506M8
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
25
W
Peak Pulse Current (8/20µs)
IPP
2
A
ESD per IEC 61000−4−2 (Air)
±15
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
kV
±8
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
Reverse Working Voltage
Breakdown Voltage
Symbol
Min
Typ
VRWM
VBR
Max
Unit
5
V
6
Test Condition
V
IT = 1mA, any I/O to GND
Reverse Leakage Current
IR
0.1
µA
VRWM = 5V
Clamping Voltage
VC
10.5
V
IPP = 1A (8 x 20µs pulse)
Clamping Voltage
VC
12.5
V
IPP = 2A (8 x 20µs pulse)
Junction Capacitance
CJ
8
pF
VR = 0V, f = 1MHz, any I/O to
GND
Note 1: I/O pins are 1, 2, 3, 4, 5 and 8.
GND pins are 6, 7.
Rev : 01.06.2014
2/4
www.leiditech.com
ESD0506M8
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
10
9
Peak Pulse Power_Ppp (W)
Junction Capacitance_Cj(pF)
10
8
7
6
5
4
3
2
1
1
0.1
0.01
2
3
4
5
Reverse Voltage_VR(V)
Junction Capacitance vs. Reverse Voltage
10
100
1000
Pulse Duration_tp (us)
Peak Pulse Power vs. Pulse Time
120
100
90
100
80
% of Rated Power
% of Peak Pulse Current
1
70
60
50
40
30
60
40
Time_t(uS)
60
80
50
75
100 125
Ambient Temperature_Ta(℃)
150
Power Derating Curve
8 X 20uS Pulse Waveform
ESD Clamping Voltage
8 kV Contact per IEC61000−4−2
Rev : 01.06.2014
3/4
www.leiditech.com
ESD0506M8
TSSOP-8 Package Outline Drawing
* SOLDERING FOOTPRINT
Contact Information
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2014
4/4
www.leiditech.com
很抱歉,暂时无法提供与“ESD0506M8”相匹配的价格&库存,您可以联系我们找货
