ESD0701P3
1-Line High Power TVS Diode
Features
5500W peak pulse power (8/20 μs)
Low leakage: nA level
Low operating voltage: 7V
Ultra low clamping voltage
One power line protects
Complies with following standards:
Dimensions DFN2020-3
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
Pin Configuration
– IEC61000-4-5 (Lightning) 250A (8/20μs)
RoHS Compliant
Lead Finish: NiPdAu
Applications
I/O Interfaces
Power lines
Automotive and Telecommunication
Computer & Consumer Electronics
Industrial Electronics
Microcontroller Input Protection
Mechanical Characteristics
Package: DFN2020-3
Lead Finish: NiPdAu
Case Material: “Green” Molding Compound
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
Marking Information: See Below
Absolute Maximum Ratings(Tamb=25°C unless otherwise specified)
Parameter
Peak Pulse Power (8/20µs)
ESD per IEC 61000−4−2 (Air)
Symbol
Ppp
Value
5500
Unit
W
±30
VESD
Kv
±30
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
-55 to +125
Storage Temperature Range
TSTJ
-55 to +150
Rev : 01.06.2018
1/4
www.leiditech.com
ESD0701P3
Electrical Characteristics(TA=25°C unless otherwise specified)
Vc
Part Number
Device
Marking
VRWM
(V)
VBR
(V)
IT
(mA)
VC
@1A
M07A
7
8
1
9
ESD0701P3
Rev : 01.06.2018
2/4
(Max)
16
(@A)
250
IR
μA
(Max)
C
(Pf)
(Typ.)
0.2
1500
www.leiditech.com
ESD0701P3
Typical
T Performance Characteristics (TA=25°C unless otherwise Specified)
Rev : 01.06.2018
3/4
www.leiditech.com
ESD0701P3
DFN2020-3 Package Outline Drawing
Suggested Land Pattern
Shanghai Leiditech Electronic Co.,Ltd
Email: sale1@leiditech.com
Tel : +86- 021 50828806
Fax : +86- 021 50477059
Rev : 01.06.2018
4/4
www.leiditech.com
很抱歉,暂时无法提供与“ESD0701P3”相匹配的价格&库存,您可以联系我们找货
