KH-RFECA3216060A1T_V09 数据手册
深圳市金航标电子有限公司
Approval sheet
FEATURES
1. Surface Mounted Devices with a small dimension of 3.2 X 1.6 X 0.6 mm3 meet future miniaturization trend.
2. LTCC process.
3. High stability in Temperature / Humidity Change.
4. Superb performance to place on the middle of PCB edge and excellent peak/ average gain observed by
field test application.
APPLICATIONS
1. ISM Band 2.4GHz applications.
2. Bluetooth..
CONSTRUCTION
PIN
Connection
1
Feeding
2
Soldering terminal
DIMENSIONS
Figure
Page 2 of 12
Symbol
Dimension (mm)
L
3.10 ± 0.20
W
1.60 ± 0.20
T
0.60 ± 0.10
A
0.25 ± 0.20
ASC_RFECA3216060A1T_V09
Aug. 2018
深圳市金航标电子有限公司
Approval sheet
SOLDER LAND PATTERN DESIGN
Type-1: Empty Space 8.0mm x 3.0 mm
Figure (Empty Space 8.0 mm x 3.0 mm)
The limited size for ECA3216 is L>30mm and D>6mm
Land Pattern
TYPE-1 TEST BOARD ELECTRONIC CHARACTERISTICS
*Note 1.
Page 3 of 12
Item
Specification
Working Frequency Range
2.4GHz~2.4835GHz (Note-1)
Gain
2 dBi (Typical)
VSWR
2.0 max.
Polarization
Linear
Azimuth Beamwidth
Omni-directional
Impedance
50
Power Capacity
3 W max.
Maximum Input Power
5 Watts for 5 minutes
Central Frequency should be defined after customers’ application approval.
Aug. 2018
深圳市金航标电子有限公司
Approval sheet
Type-2: Empty Space 6.3mm x 4.0 mm
Figure (Empty Space 6.3 mm x 4.0 mm)
Land Pattern
TYPE-2 TEST BOARD ELECTRONIC CHARACTERISTICS
Item
Specification
Gain
2 dBi (Typical)
VSWR
2.0 max.
Polarization
Linear
Azimuth Beamwidth
Omni-directional
Impedance
50
Power Capacity
3 W max.
Maximum Input Power
*Note 1. Central Frequency should be defined after customers’ application approval.
Page 4 of 12
Aug. 2018
深圳市金航标电子有限公司
Approval sheet
Antenna on Type-1 Test Board ( Empty Space 8x3 mm &Thick ness 0.8mm)
Antenna S11 on Type-1 Test Board
-11.0208 dB @ 2.40 GHz
-17.0222 dB @ 2.45 GHz
-10.7612 dB @ 2.50 GHz
Antenna VSWR on Type-1 Test Board
1.782 @ 2.40 GHz
1.328 @ 2.45 GHz
1.816 @ 2.50 GHz
Page 5 of 12
Aug. 2018
深圳市金航标电子有限公司
Approval sheet
Antenna on Type-2 Test Board ( Empty Space 6.3x4 mm &Thick ness 0.8mm)
Antenna S11 on Type-2 Test Board
-14.6741 dB @ 2.40 GHz
-20.2120 dB @ 2.45 GHz
-11.4374 dB @ 2.50 GHz
Antenna VSWR on Type-2 Test Board
1.453 @ 2.40 GHz
1.216 @ 2.45 GHz
1.732 @ 2.50 GHz
Page 6 of 12
Aug. 2018
深圳市金航标电子有限公司
Approval sheet
RADIATION PATTERN
Radiation Pattern and Gain were dependent on measurement board design. The specification of RFECA3216060A1T
antenna was measured based on the PCB size and installation position as shown in the below figure Test Board.
ZX plane
ZY plane
XY plane
Frequency
[MHz]
Max Value
[dB]
Average
[dB]
Max Value
[dB]
Average
[dB]
Max Value
[dB]
Average
[dB]
2400
0.29
-3.32
1.82
-0.51
1.49
-2.87
2450
0.55
-2.88
2.09
-0.21
1.95
-2.48
2500
-0.15
-3.44
1.82
-0.62
1.82
-2.73
Page 7 of 12
Aug. 2018
深圳市金航标电子有限公司
Approval sheet
ZX plane
ZY plane
XY plane
Frequency
[MHz]
Max Value
[dB]
Average
[dB]
Max Value
[dB]
Average
[dB]
Max Value
[dB]
Average
[dB]
2400
1.57
-2.83
1.95
-0.76
1.10
-2.93
2450
1.70
-2.62
2.02
-0.62
1.57
-2.61
2500
1.46
-2.82
1.90
-0.71
1.75
-2.68
Page 8 of 12
Aug. 2018
深圳市金航标电子有限公司
Approval sheet
RELIABILITY TEST
Test condition / Test method
Test item
Solderability
*Solder bath temperature:235 5C
Specification
At least 95% of a surface of each terminal
JIS C 0050-4.6
*Immersion time:2 0.5 sec
electrode must be covered by fresh solder.
JESD22-B102D
Solder:Sn3Ag0.5Cu for lead-free
Leaching
*Solder bath temperature:260 5C
(Resistance to
*Leaching immersion time:30 0.5 sec
dissolution of
Loss of metallization on the edges of each
electrode shall not exceed 25%.
Solder : SN63A
metallization)
IEC 60068-2-58
Resistance to soldering
heat
JIS C 0050-5.4
*Preheating temperature:120~150℃,
No mechanical damage.
1 minute.
Electrical specification shall satisfy the
*Solder temperature:2705C
descriptions in electrical characteristics under
*Immersion time:101 sec
Measurement to be made after keeping at
the operational temperature range within -40
~ 85°C.
room temperature for 242 hrs
Drop Test
JIS C 0044
Customer’s specification.
*Height:75 cm
*Test Surface:Rigid surface of concrete or
steel.
*Times:6 surfaces for each units;2 times for
each side.
Vibration
JIS C 0040
~ 85°C.
*Frequency:10Hz~55Hz~10Hz(1min)
*Total amplitude:1.5mm
*Test times:6hrs.(Two hrs each in three
mutually perpendicular directions)
~ 85°C.
Adhesive Strength
of Termination
JIS C 0051- 7.4.3
Page 9 of 12
*Pressurizing force:
5N(≦0603);10N(>0603)
No remarkable damage or removal of the
termination.
*Test time:10±1 sec
Aug. 2018
深圳市金航标电子有限公司
Approval sheet
Bending test
The middle part of substrate shall be
JIS C 0051- 7.4.1
pressurized by means of the pressurizing rod Electrical specification shall satisfy the
at a rate of about 1 mm/s per second until the descriptions in electrical characteristics under
deflection becomes 1mm/s and then pressure the operational temperature range within -40
shall be maintained for 51 sec.
~ 85°C.
room temperature for 242 hours
Temperature cycle
JIS C 0025
1. 303 minutes at -40C3C,
2. 10~15 minutes at room temperature,
3. 303 minutes at +85C3C,
4. 10~15 minutes at room temperature,
Total 100 continuous cycles
~ 85°C.
High temperature
JIS C 0021
*Temperature:85C2C
*Test duration:1000+24/-0 hours
~ 85°C.
Humidity
(steady conditions)
JIS C 0022
*Humidity:90% to 95% R.H.
*Temperature:402C
*Time:1000+24/-0 hrs.
at room temperature for 242 hrs
~ 85°C.
※ 500hrs measuring the first data then
1000hrs data
Low temperature
JIS C 0020
*Temperature:-40C2C
~ 85°C.
Page 10 of 12
Aug. 2018
深圳市金航标电子有限公司
Approval sheet
SOLDERING CONDITION
Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2
Fig 2. Infrared soldering profile
ORDERING CODE
RF
Walsin
RF
device
ECA
321606
Dimension code
Unit of
dimension
Product
code
Per 2 digits of
ANT :
Antenna
Length, Width,
Thickness :
A
0 : 0.1 mm
1
T
Application
Specification
Packing
A : 2.4GHz ISM
Band
Design Code
T : Reeled
1 : 1.0 mm
e.g. :
321606 =
Length 32,
Width 16,
Thickness 06
Minimum Ordering Quantity: 2000 pcs per reel.
PACKAGING
Plastic Tape specifications (unit :mm)
E
Index
Dimension (mm)
Index
Dimension (mm)
Page 11 of 12
E
E
E
E
Ao
Bo
D
T
W
1.85 0.10
3.45 0.10
1.55 0.05
0.75 0.10
8.00 0.30
E
F
Po
P1
P2
1.75 0.10
3.50 0.05
4.00 0.10
4.00 0.10
2.00 0.10
Aug. 2018
深圳市金航标电子有限公司
Approval sheet
Reel dimensions
C
Index
Dimension (mm)
A
B
A
B
C
Φ178.0
Φ60.0
Φ13.0
Taping Quantity:2000 pieces per 7” reel
CAUTION OF HANDLING
Limitation of Applications
Please contact us before using our products for the applications listed below which require especially high reliability for the
prevention of defects, which might directly cause damage to the third party’s life, body or property.
(1) Aircraft equipment
(2) Aerospace equipment
(3) Undersea equipment
(4) Medical equipment
(5) Disaster prevention / crime prevention equipment
(6) Traffic signal equipment
(7) Transportation equipment (vehicles, trains, ships, etc.)
(8) Applications of similar complexity and /or reliability requirements to the applications listed in the above.
Storage condition
(1) Products should be used in 6 months from the day of WALSIN outgoing inspection.
(2) Storage environment condition.
Products should be storage in the warehouse on the following conditions.
Products should be storage on the palette for the prevention of the influence from humidity, dust and son on.
Temperature
: +5 to +40℃
Humidity
: 30 to 70% relative humidity
Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of
electrode, resulting in poor solderability.
Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on.
Products should be storage under the airtight packaged condition.
Page 12 of 12
Aug. 2018
KH-RFECA3216060A1T_V09 价格&库存
很抱歉,暂时无法提供与“KH-RFECA3216060A1T_V09”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.51948
- 100+0.41580
- 300+0.36396
- 2000+0.31428
- 4000+0.28318
- 10000+0.26752
- 国内价格
- 1+0.38280
- 50+0.22550
- 2000+0.20240
