BC847B
BC847B
    CBI(创基)
    SOT-23
    SOT23-3 100mA 100MHz 200mW
BC847B 数据手册
TRANSISTOR(NPN) FEATURE SOT-23 Ideally suited for automatic insertion For Switching and AF Amplifier Applications 1.BASE 2.EMITTER 3.COLLECTOR MAXIMUM RATINGS (TA=25℃ unless otherwise noted) Symbol VCBO VCEO Parameter Collector-Base Voltage Collector-Emitter Voltage BC846 BC847 BC848 BC846 BC847 BC848 Value 80 Units V 50 30 65 V 45 30 VEBO Emitter-Base Voltage 6 V IC Collector Current –Continuous 0.1 A PC* Collector Power Dissipation 200 mW TJ Junction Temperature 150 ℃ Tstg Storage Temperature -65-150 ℃ DEVICE MARKING BC846A=1A; BC846B=1B; BC847A=1E; BC847B=1F; BC847C=1G; BC848A=1J; BC848B=1K: BC848C=1L 1 of 5 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. ELECTRICAL CHARACTERISTICS (Tamb=25℃ unless otherwise specified) Symbol Parameter Collector-base breakdown voltage Test conditions Collector-emitter breakdown voltage VCBO IC= 10µA, IE=0 30 BC846 65 VCEO IC= 10mA, IB=0 Collector cut-off current VEBO Collector cut-off current ICBO BC846 VCE=60 V , IB=0 ICEO BC846A,847A,848A BC846B,847B,848B BC847C,BC848C V 6 V VCE=45 V , IB=0 0.1 µA 0.1 µA 0.1 µA VCE=30 V , IB=0 IEBO Emitter cut-off current 45 VCB=50 V , IE=0 VCB=30 V , IE=0 BC848 DC current gain IE= 10µA, IC=0 BC848 BC847 V VCB=70 V , IE=0 BC846 BC847 UNIT 30 BC848 Emitter-base breakdown voltage MAX 50 BC848 BC847 TYP 80 BC846 BC847 MIN hFE VEB=5 V , VCE= 5V, IC=0 IC= 2mA 110 220 200 450 420 800 Collector-emitter saturation voltage VCE(sat) IC=100mA, IB= 5mA 0.5 V Base-emitter saturation voltage VBE(sat) IC=100mA, IB= 5mA 1.1 V Transition frequency Collector output capacitance fT Cob VCE= 5 V, IC= 10mA f=100MHz VCB=10V, 100 f=1MHz 2 of 5 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. MHz 4.5 pF Typical Characteristics BC846A,B;BC847A, B, C;BC848A, B, C 3 of 5 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. 4 of 5 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd. PACKAGE OUTLINE Plastic surface mounted package; 3 leads SOT-23 5 of 5 Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
BC847B
### 物料型号 - BC846A/B/C:这些是NPN型晶体管,用于一般放大应用。 - BC847A/B/C:这些是NPN型晶体管,用于低噪声放大应用。 - BC848A/B/C:这些是NPN型晶体管,用于高速开关应用。
### 器件简介 这些器件是硅NPN通用晶体管,广泛应用于音频和射频放大器、开关应用等。
### 引脚分配 - BC846A/B/C:集电极(C)、基极(B)、发射极(E)。 - BC847A/B/C:集电极(C)、基极(B)、发射极(E)。 - BC848A/B/C:集电极(C)、基极(B)、发射极(E)。
### 参数特性 - 最大电流(Ic):通常在100mA左右。 - 最大电压(Vceo):通常在45V左右。 - 截止频率(fT):BC846A/B/C较低,BC847A/B/C和BC848A/B/C较高。
### 功能详解 - BC846A/B/C:适用于一般放大应用,如音频放大器。 - BC847A/B/C:适用于低噪声放大应用,如音频前置放大器。 - BC848A/B/C:适用于高速开关应用,如数字电路。
### 应用信息 - BC846A/B/C:一般放大器、开关。 - BC847A/B/C:低噪声放大器、音频前置放大器。 - BC848A/B/C:高速开关、数字电路。
### 封装信息 这些晶体管通常采用SOT-23、SOT-89、TO-92等封装形式。
BC847B 价格&库存
很抱歉,暂时无法提供与“BC847B”相匹配的价格&库存,您可以联系我们找货
BC847B
    • 10+0.03680
    • 50+0.03404
    • 200+0.03174
    • 600+0.02944
    • 1500+0.02760
    • 3000+0.02645
    BC847B
      • 50+0.07496
      • 500+0.05919
      • 3000+0.04515
      • 6000+0.03986
      • 24000+0.03532
      • 51000+0.03284
      库存:4963
