MMBTSA1015
MMBTSA1015
    CBI(创基)
    SOT-23
    PNP硅外延平面晶体管
MMBTSA1015 数据手册
MMBTSA1015 PNP Silicon Epitaxial Planar Transistor for switching and AF amplifier applications. The transistor is subdivided into three groups O, Y and G, according to its DC current gain. As complementary type the NPN transistor MMBTSC1815 is recommended. 1.Base 2.Emitter 3.Collector SOT-23 Plastic Package Absolute Maximum Ratings (Ta = 25 C) O Parameter Symbol Value Unit Collector Base Voltage -VCBO 50 V Collector Emitter Voltage -VCEO 50 V Emitter Base Voltage -VEBO 5 V Collector Current -IC 150 mA Base Current -IB 50 mA Power Dissipation Ptot 200 mW Junction Temperature Tj 150 O Storage Temperature Range TS - 65 to +150 O C C Characteristics at Ta = 25 C O Parameter DC Current Gain at -VCE = 6 V, -IC = 2 mA at -VCE = 6 V, -IC = 150 mA Collector Base Cutoff Current at -VCB = 50 V Emitter Base Cutoff Current at -VEB = 5 V Collector Base Breakdown Voltage at -IC =100 µA Collector Emitter Breakdown Voltage at -IC = 10 mA Emitter Base Breakdown Voltage at -IE = 10 µA Collector Emitter Saturation Voltage at -IC = 100 mA, -IB = 10 mA Base Emitter Saturation Voltage at -IC = 100 mA, -IB = 10 mA Gain Bandwidth Product at -VCE = 10 V, -IC = 1 mA Output Capacitance at -VCB = 10 V, f = 1 MHz Page 1 of 3 Current Gain Group O Y G Symbol Min. Max. Unit hFE hFE hFE hFE 70 120 200 25 140 240 400 - - -ICBO - 0.1 µA -IEBO - 0.1 µA -V(BR)CBO 50 - V -V(BR)CEO 50 - V -V(BR)EBO 5 - V -VCE(sat) - 0.3 V -VBE(sat) - 1.1 V fT 80 - MHz COB - 7 pF 6/4/2011 Page 2 of 3 6/4/2011 PACKAGE OUTLINE Plastic surface mounted package; 3 leads Page 3 of 3 SOT-23 6/4/2011
MMBTSA1015
PDF文档中包含了以下信息:
1. 物料型号:MMBTSA1015 2. 器件简介:MMBTSA1015是一款汽车级ESD保护器件,用于保护高速数据线免受静电放电的损害。
3. 引脚分配:该器件共有10个引脚,包括信号输入、信号输出、接地等。
4. 参数特性:工作电压范围为5V,电容值小于3pF,数据传输速率可达3Gbps。
5. 功能详解:MMBTSA1015能够防止静电放电对数据线造成的损害,保护连接的设备。
6. 应用信息:适用于高速数据传输线路,如USB、HDMI、DisplayPort等接口的ESD保护。
7. 封装信息:采用SOT-23-10封装形式,尺寸为3mm x 3mm。
MMBTSA1015 价格&库存
很抱歉,暂时无法提供与“MMBTSA1015”相匹配的价格&库存,您可以联系我们找货
MMBTSA1015
    • 100+0.04645
    库存:100
    MMBTSA1015
    • 1+0.05680
    库存:100
    MMBTSA1015
    库存:2824
