深圳市金航标电子有限公司
客戶名稱
CUSTOMER :
客戶料號
CUSTOMER’S P/N :
料號
PART NUMBER : KH-3216F245W36
規格
DESCRIPTION : Chip Antenna 3216 M-Ant 2.45G Type 36
版本
VERSION : V2.2
日期
ISSUE DATE : 2018/01/30
客 戶 承 認
CUSTOMER APPROVED
工
程
部
承 認
APPROVAL
R&D CENTER
確 認
CHECKED
製 作
DRAWN
Ray
James
Thor
深圳市金航标电子有限公司
深圳市龙华区民治大道1079号展滔科技大厦C座809室
3216 Chip antenna
For Bluetooth / WLAN Applications
P/N:
KH3216F245W36
Dimension (mm)
L
3.23 ± 0.20
W
1.66 ± 0.20
T
1.23 ± 0.20
Shenzhen Kinghelm Elcetron Co, Ltd
2/11
Part Number Information
A
B
C
D
E
F
KH 3216
F
245
W
36
A
C
D
E
F
B
Product Series
Dimension L x W
Material
Working Frequency
Feeding mode
Antenna type
Antenna
3.2X1.6mm (+-0.2mm)
High K material
2.4 ~ 2.5GHz
Monopole & Single Feeding
Type=36
1. Electrical Specification
Specification
Part Number
KH3216F245W36
Central Frequency
2450
MHz
Bandwidth
100 (Min.)
MHz
Return Loss
-6.5 (Max)
dB
Peak Gain
2.71
dBi
Impedance
50
Ohm
Operating Temperature
-40~+85
Maximum Power
4
W
Resistance to Soldering Heats
10 ( @ 260℃)
sec.
Polarization
Linear
Azimuth Beamwidth
Omni-directional
Termination
Cu / Sn (Leadless)
Remark : Bandwidth & Peak Gain was measured under evaluation board of next page
3/11
2. Recommended PCB Pattern
1.Evaluation Board Dimension
2.Evaluation Board Dimension
(若淨空區夠大,建議使用此 Layout,效能較佳)
Unit : mm
Suggested Matching Circuit
重要資訊 :
匹配元件建議使用精準度±1%以下的電感、電容、電阻
4/11
1.Layout Dimensions in Clearance area(Size=5.2*5.0mm)
50 ohm transmission Line
Matching Circuit
2.Layout Dimensions in Clearance area(Size=8.2*5.0mm)
Matching Circuit
FootPrint
(Unit : mm)
5/11
3. Measurement Results
Return Loss
6/11
Radiation Pattern
Y
X
Z
Efficiency
Peak Gain
Directivity
2400MHz
55.21 %
1.45 dBi
5.32 dBi
2450MHz
66.45 %
2.71 dBi
5.21 dBi
2500MHz
57.53 %
1.98 dBi
5.29 dBi
Chamber Coordinate System
7/11
4.Reliability and Test Condictions
ITEM
REQUIREMENTS
TEST CONDITION
Solderability
1. Wetting shall exceed 90% coverage
2. No visible mechanical damage
Pre-heating temperature:150℃/60sec.
Solder temperature:230±5℃
Duration:4±1sec.
Solder:Sn-Ag3.0-Cu0.5
Flux for lead free: rosin
TEMP (℃)
4±1 sec.
230℃
150℃
60sec
Solder heat
Resistance
1. No visible mechanical damage
2. Central Freq. change :within ± 6%
TEMP (℃)
10±0.5 sec.
260℃
Solder temperature:260±5℃
Duration:10±0.5sec.
150℃
60sec
Component
Adhesion
(Push test)
Component
Adhesion
(Pull test)
Thermal shock
2. Central Freq. change :within ±6%
Phase
Temperature(℃)
Time(min)
1
+85±5℃
Room
Temperature
30±3
Within
3sec
-40±2℃
Room
Temperature
30±3
Within
3sec
2
3
4
Resistance to
High
Temperature
Resistance to
Low
Temperature
Humidity
3. No disconnection or short circuit.
The device should be reflow
soldered(230±5℃ for 10sec.) to a tinned
copper substrate A dynometer force
gauge should be applied the side of the
component. The device must with-ST-F
0.5 Kg without failure of the termination
attached to component.
Insert 10cm wire into the remaining open
eye bend ,the ends of even wire lengths
upward and wind together.
Terminal shall not be remarkably
damaged.
+85℃=>30±3min
-40℃=>30±3min
Test cycle:10 cycles
The chip shall be stabilized at normal
condition for 2~3 hours before
measuring.
Temperature: 85±5℃
Duration: 1000±12hrs
measuring.
Temperature:-40±5℃
measuring.
Temperature: 40±2℃
Humidity: 90% to 95% RH
measuring.
8/11
5.Soldering and Mounting
Mildly activated rosin fluxes are preferred. The minimum amount of solder can
lead to damage from the stresses caused by the difference in coefficients of
expansion between solder, chip and substrate. The terminations are suitable
for all wave and re-flow soldering systems. If hand soldering cannot be
avoided, the preferred technique is the utilization of hot air soldering tools.
Iron Soldering
Reflow Soldering
PRE-HEATING
SOLDERING
TEMPERATURE(°C)
10s max.
NATURAL
COOLING
250~260
230
180
150
60~120 s
30~60s
SOLDERING
within 3s
TEMPERATURE(°C)
PRE-HEATING
NATURAL
COOLING
350
300
150
Gradual cooling
Over 60s
TIME(sec.)
TIME(sec.)
Recommended temperature profiles for re-flow soldering in Figure 1.
Products attachment with a soldering iron is discouraged due to the inherent
process control limitations. In the event that a soldering iron must be
employed the following precautions are recommended.
‧Preheat circuit and products to 150℃
‧Never contact the ceramic with the iron tip
‧Use a 20 watt soldering iron with tip diameter of 1.0mm
‧280℃ tip temperature (max)
‧1.0mm tip diameter (max)
‧Limit soldering time to 3 sec.
9/11
6.Packaging Information
Tape Specification:
W
8.0
±0.30
Ao
1.80
±0.05
Bo
3.51
±0.10
Ko
1.59
±0.10
P
4.00
±0.05
F
3.50
±0.05
E
1.75
±0.10
D
1.50
±0.10
D1
0.00
±0.10
Po
4.00
±0.10
P2
2.00
±0.05
t
0.25
±0.05
Reel Specification: (7’’, Φ180 mm)
Tape Width(mm) A(mm) B(mm)
8
9.0±0.5
60±2
C(mm)
13.5±0.5
D(mm) Chip/Reel(pcs)
178±2
3000
10/11
7.Storage and Transportation Information
Storage Conditions
To maintain the solderability of terminal electrodes:
1. Temperature and humidity conditions: -10~ 40℃ and 30~70% RH.
2. Recommended products should be used within 6 months from the time of
delivery.
3. The packaging material should be kept where no chlorine or sulfur exists
in the air.
Transportation Conditions
1. Products should be handled with care to avoid damage or contamination
from perspiration and skin oils.
2. The use of tweezers or vacuum pick up is strongly recommended for
individual components.
3. Bulk handling should ensure that abrasion and mechanical shock are
minimized.
11/11
很抱歉,暂时无法提供与“KH-3216F245W36”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.14048
- 50+0.89554
- 150+0.79056
- 500+0.65956
- 3000+0.60124
- 6000+0.56625
- 国内价格
- 1+0.78320
- 200+0.53900
- 1500+0.49060
- 3000+0.45870
