3.20 [0.126]
Ø0.70 [Ø0.028]
0.90 [0.035]
3
9.70 [0.382]
6.90 [0.272]
1
6.20 [0.244]
6.20 [0.244]
3.10 [0.122]
1.25 [0.049]
4.75 [0.187]
0.80 [0.032]
7.40 [0.291]
Material
Housing Material: LCP, UL94V-0, black
Contact Terminal: Phosphor bronze, T=0.25mm
Metallic Shell: Brass, T=0.4mm
Plating
Contact Terminal
Underplating: Nickel all over
Contact Plating: 1µ" gold
Solder Tail: Bright Tin
Metallic Shell
Underplating: Nickel 50µ" all over
Metallic Shell: Matte Tin 50µ" all over
Electrical
Voltage Rating: 30VDC
Current Rating: 1A
Contact Resistance: 50mΩ Max
Insulation resistance: 100MΩ Min (Apply 100 VDC)
Dielectric withstanding voltage: No discharge or flash (100V AC is applied for 1 minute)
Mechanical
Durability: 5,000 cycles
Mating Force: 35N (3.57Kgf) Max
Unmating Force: Initial - 7N (0.71KgF) Min., 5001st cycle - 3N (0.31KgF) Min.
Environmental and Processing
Operating Temperature: -50°C to +85°C
8.10 [0.319]
3.85 [0.152]
U214-05XN-4BR84
9.20 [0.362]
1:Au 1U"
6:Au 30U"
X
X
X
DATE
DESCRIPTION
REVISIONS
www.xk-dg.cn
0.80 [0.032]
5.86 [0.231]
9.50 [0.374]
MARK
1.60 [0.063]
R0.40
0.80 [0.032]
5
5
4
RECOMMENDED PCB LAYOUT
1.20 [0.047]
0.40 [0.016]
1.90 [0.075]
1.20 [0.047]
2
4.75 [0.187]
1
www.helloxkb.com
REVISED
APPROVED
ANGLAR
L≤4
4
很抱歉,暂时无法提供与“U214-051N-4BR84”相匹配的价格&库存,您可以联系我们找货
