U233-091N-1BLPC15-F1 数据手册
12.80 [0.504]
9-0.45 [0.018]
12.80 [0.504]
9*0.45 [0.018]
Flat(F)
13.10 [0.516]
3D VIEW
Scrolls(S)
13.10 [0.516]
14.50 [0.571]
1.45 [0.057]
4.00 [0.157]
15.00 [0.591]
Pin #
2.00 [0.079]
1
8
6
7
2
3
5
4
17.90 [0.705]
1.00 [0.040]
3.50 [0.138]
8.00 [0.315]
9-Ø0.70 [Ø0.028]
4.00 [0.158]
1.45 [0.057]
1.55 [0.061]
9
8
1
6
7
2
3
5
2.30 [0.091]
4
0.70 [0.028]
2.00 [0.079]
7.00 [0.276]
SIGNAL NAME DESCRIPTION
MATING
SEQUENCE
1
VBUS
POWER
2
D-
USB 2.0
DIFFERENTIAL PAIR
THIRD
GND
GROUND FOR POWER RETURN
SECOND
StdA_SSRX-
SUPERSPEED RECEIVER
DIFFERENTIAL PAIR
LAST
Material
3
Housing Material: LCP, UL94V-0, blue
4
Contact Terminal: Brass
5
Metallic Shell:Spcc
6
Plating
7
Underplating: Nickel
8
Contact Plating: 1µ" Gold
9
Solder Tail: 100µ" Min. Tin
Shell
Metallic Shell: Nickel
Electrical
Voltage Rating: 100 V AC
Current Rating: 0.25A (Signal pins 2,3,5,6,7,8,9) 1.5A
(Power Pins 1,4)
Contact Resistance: 30mΩ Max.
Insulation resistance: 1000MΩ Min.
Dielectric withstanding voltage: 100V AC/Minute
Mechanical
Durability: 1500 cycles
Mating Force: 35N (3.57Kgf) Max
Unmating Force: 10N (1.02Kgf) Min. initial, 8N min
after test
Environmental and Processing
Operating Temperature: -40°C to +85°C
5.70 [0.224]
9
7.10 [0.280]
1.55 [0.061]
SECOND
D+
StdA_SSRX+
GND_DRAIN
GROUND FOR SIGNAL RETURN
StdA_SSTX-
SUPERSPEED TRANSMITTER
DIFFERENTIAL PAIR
StdA_SSTX+
Shield
CONNECTOR METAL SHELL
FRIST
U233-09XN-1BLPC15-X1
1:Au 1U"
5:Au 15U"
6:Au 30U"
S:Scrolls F:Flat
12.80 [0.504]
RECOMMENDER P.C.B. LAYOUT TOP VIEW
(COMPONENT SIDE TOLERANCE±0.05)
X
X
X
MARK
DATE
DESCRIPTION
REVISIONS
www.xk-dg.cn
www.helloxkb.com
REVISED
APPROVED
ANGLAR
L≤4
4
U233-091N-1BLPC15-F1 价格&库存
很抱歉,暂时无法提供与“U233-091N-1BLPC15-F1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.39188
- 50+1.12296
- 200+0.93038
- 500+0.78654
- 2500+0.72251
- 5000+0.68414
- 国内价格
- 1+0.70200
- 10+0.67600
- 100+0.59800
- 500+0.58240
- 国内价格
- 5+1.48850
- 50+1.20100
- 200+0.99500
- 500+0.84120
