U233-091N-1BLPC15-F2 数据手册
15.20 [0.598]
15.20 [0.598]
9-0.45 [0.018]
3.30 [0.130]
9-0.45 [0.018]
15.00 [0.591]
15.00 [0.591]
2.20 [0.087]
2.20 [0.087]
3.30 [0.130]
3D VIEW
13.10 [0.516]
Scrolls(S)
14.50 [0.571]
13.10 [0.516]
Flat(F)
8
6
7
2
3
5
4
1.55 [0.061]
1
5.70 [0.224]
9
7.10 [0.280]
4.00 [0.157]
2.00 [0.079]
Material
Housing Material: LCP, UL94V-0, blue
Contact Terminal: Brass
Metallic Shell:Brass
Plating
Underplating: Nickel
Contact Plating: 1µ" Gold
Solder Tail: 100µ" Min. Tin
Metallic Shell: Nickel
Electrical
Voltage Rating: 100 V AC
Current Rating: 0.25A (Signal pins 2,3,5,6,7,8,9) 1.5A
(Power Pins 1,4)
Contact Resistance: 30mΩ Max.
Insulation resistance: 1000MΩ Min.
Dielectric withstanding voltage: 100V AC/Minute
Mechanical
Durability: 1500 cycles
Mating Force: 35N (3.57Kgf) Max
Unmating Force: 10N (1.02Kgf) Min. initial, 8N min
after test
Environmental and Processing
Operating Temperature: -40°C to +85°C
1.45 [0.057]
1.00 [0.040]
3.50 [0.138]
8.00 [0.315]
1.55 [0.061]
1.45 [0.057]
2.00 [0.079]
6.00 [0.236]
4.00 [0.157]
9
1
8
6
7
2
3
5
9*Ø0.70 [Ø0.028]
4
2*Ø2.30 [Ø0.091]
2.50 [0.098]
4.50 [0.177]
7.00 [0.276]
13.15 [0.518]
SIGNAL NAME DESCRIPTION
MATING
SEQUENCE
1
Pin #
VBUS
POWER
SECOND
2
DD+
USB 2.0
DIFFERENTIAL PAIR
THIRD
3
4
GND
GROUND FOR POWER RETURN
SECOND
5
StdA_SSRXStdA_SSRX+
SUPERSPEED RECEIVER
DIFFERENTIAL PAIR
LAST
6
7
GND_DRAIN
GROUND FOR SIGNAL RETURN
8
StdA_SSTX-
9
StdA_SSTX+
SUPERSPEED TRANSMITTER
DIFFERENTIAL PAIR
Shell
Shield
CONNECTOR METAL SHELL
RECOMMENDER P.C.B.LAYOUT TOP VIEW
(COMPONENT SIDE TOLERANCE±0.05)
U233-09XN-1BLPC15-X 2
1:Au 1U"
5:Au 15U"
6:Au 30U"
FRIST
X
X
X
MARK
DATE
DESCRIPTION
REVISIONS
www.xk-dg.cn
www.helloxkb.com
REVISED
APPROVED
ANGLAR
L≤4
4
U233-091N-1BLPC15-F2 价格&库存
很抱歉,暂时无法提供与“U233-091N-1BLPC15-F2”相匹配的价格&库存,您可以联系我们找货
