TM-T07A-2
TM-T07A-2
    XKB(中国星坤)
    SMD,6.4x3mm
    检测开关 SMD,6.4x3mm 双刀单掷-常开 操作寿命10万次 DC30V
TM-T07A-2 数据手册
1.65[0.065] 0.3 MAX 0.15 MAX 0.75±0.25 ON Starting Position B Terminal NO. A 2.3±0.2 Full Position 0.8[0.031] 0.2[0.008] 4.9[0.193] H 0.8 [0.031] 3[0.118] Detail of P (SCALE:2:1) 1[0.039] 1.5[0.059]1.75[0.069] P Ø1.1[0.043] 5[0.197] PC Board mounting face 2.3[0.09] 6.4[0.252] 2.3[0.09] 3.3[0.13] 3.3[0.13] 4-1.4[0.055] H 8.3 8.5 8.7 9.3 11.0 12.3 13.7 TM-T07A-2 NOTE RATING:DC 30V 0.1A Operating Force: 40±10gf Lifetime:100,000 Cycles 1.5[0.06] 1.75[0.069] PART NO TM-T07A-1 TM-T07A-3 TM-T07A-4 TM-T07A-5 2[0.079] 2-Ø1.3 holes 6.8[0.268] 0.7[0.028] 2[0.079] TM-T07A-6 C D A B TM-T07A-7 5 Contact Spring Terminal 4 Base 3 Cover 2 Keystake 1 ITEM PAPT NAMF TER‚NO Circuit Diagram PCB Layout(Pattern side) X X X MARK DATE DESCRIPTION REVISIONS www.xk-dg.cn www.helloxkb.com REVISED APPROVED units: tolerance: X.X X.XX X.XXX QTY Phosphor Bronze Phosphor Bronze Nylon Plating silver Plating silver Nylon Nylon MATERIAL FINISHING REMARK DSND DATE SCALE: N/A MODEL TYPE: mm DWN DATE VIEW: ±0.2mm ±0.1mm ±0.05mm CHKD DATE UNIT: mm/in APPD DATE UNSPECIFIED TOLERANCES www.helloxkb.cn 1 4 1 1 1 DETECT SWITCH PART NO.: DWG NO.: SIZE: A4 XKB INDUSTRIAL PRECISION CO.,LIMITED WEIGHT 1.0g TM-T07A-X SHEET 1/1 REVISION A0
TM-T07A-2 价格&库存
很抱歉,暂时无法提供与“TM-T07A-2”相匹配的价格&库存,您可以联系我们找货
TM-T07A-2
  • 1+0.32340
  • 30+0.31115
  • 100+0.29890
  • 500+0.27440
  • 1000+0.26215
  • 2000+0.25480
TM-T07A-2
  • 1+1.80250
  • 50+1.07530
  • 200+0.75270
  • 600+0.53760
  • 1200+0.51070
  • 6000+0.47310
TM-T07A-2
  • 5+0.84019
  • 50+0.67275
  • 150+0.58903
  • 600+0.48530
  • 2400+0.43503
  • 4800+0.40990
库存:130
