MMBT5551
MMBT5551
    JSMSEMI(杰盛微)
    SOT-23
    通用三极管 50nA 160V 250mW 80@10mA,5V 600mA 100MHz 200mV@50mA,5mA -55℃~+150℃@(Tj) SOT-23
MMBT5551 数据手册
MMBT5551 NPN General Purpose Transistor FEATURES z Epitaxial planar die construction. z Complementary PNP type available (MMBT5401). or Also available in lead free version. z G ct APPLICATIONS Ideal for medium power amplification and switching. SOT-23 mi c on du z 1 MAXIMUM RATING @ Ta=25℃ unless otherwise specified Value UNIT VCBO collector-base voltage 180 V VCEO collector-emitter voltage 160 V VEBO emitter-base voltage 6 V IC collector current (DC) 0.6 A Collector dissipation 0.35 W Se Parameter MI C RO   Symbol JS PC RθJA Thermal resistance,Junction to ambient 357 °C/W Tj ,Tstg junction and storage temperature -55 to +150 °C www.jsmsemi.com 第1/4页 MMBT5551 NPN General Purpose Transistor ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified Parameter Test MIN. V(BR)CBO Collector-base breakdown voltage IC=100μA,IE=0 180 V(BR)CEO Collector-emitter breakdown voltage IC=0.1mA,IB=0 160 V(BR)EBO Emitter-base breakdown voltage IE=10μA,IC=0 6 ICBO collector cut-off current IE = 0; VCB = 120V IEBO emitter cut-off current IC = 0; VEB = 4V hFE MAX. to conditions UNIT r Symbol 50 nA - 50 nA DC current gain VCE = 5V; IC= 1mA VCE = 5V;IC = 10mA VCE = 5V;IC = 50mA 80 100 30 300 - VCE(sat) collector-emitter saturation voltage IC = 10mA; IB=1mA IC = 50mA; IB = 5mA - 0.15 0.2 V VBE(sat) base-emitter saturation voltage IC=10mA; IB=1mA IC=50mA; IB=5mA - 1 1 V fT transition frequency IC=10mA; VCB=10V; f=100MHz 100 300 MHz Cobo Output capacitance 6.0 pF CR O  Se mi co nd uc - IE=10mA; VCE =10V; f=1.0MHz JS MI TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified www.jsmsemi.com 第2/4页 JS MI CR O  Se mi co nd uc to r MMBT5551 NPN General Purpose Transistor www.jsmsemi.com 第3/4页 MMBT5551 NPN General Purpose Transistor PACKAGE OUTLINE Plastic surface mounted package SOT-23 SOT-23 Dim Min Max A 2.70 3.10 B 1.10 r A K B C D 0.48 G 1.80 2.00 H 0.02 0.1 J 2.60 All Dimensions in mm CR O  0.95 2.20 Se SOLDERING FOOTPRINT 0.95 K 0.1 Typical mi co H 0.4 Typical 0.35 nd G C 1.0 Typical uc E J D 1.50 to E JS MI 2.00 0.90 Unit : mm 0.80 PACKAGE INFORMATION Device Package Shipping MMBT5551 SOT-23 3000/Tape&Reel www.jsmsemi.com 第4/4页
MMBT5551 价格&库存
很抱歉,暂时无法提供与“MMBT5551”相匹配的价格&库存,您可以联系我们找货
MMBT5551
  • 50+0.04013
  • 600+0.03093
  • 1200+0.03047
  • 3000+0.02527
库存:960
